g32 s2 misconfig?
Hi, I'm new to printing and these forums and wll hopefully creating contnt I can share with you all soon! :)
However I'm having issues printing. I just bought a Boots Industries V2.5 Delta 2nd hand and saw it working, got it home, calibrated it, got a couple of prints out of it, but then for some reason the command G32 S2 just stopped working suddenly after going through calibration a couple of times...
I have recorded a video of it here:
Basically when hitting G32 S2 the hotend doesn't move in any z direction and just moves around in x and y, storing the height of the bed as the end's current height. I've tried reinstalling etc. I'd been having some issues with it tearing the first couple of layers but now I can't do anything with it stuck and not able to calibrate!
«1
  • Any messages from calibration in host log?
    My guess is that the z probe sensor is always returning "h" = high = triggered so it never goes down. Try M119 to see state of z probe.
  • edited October 2016
    It's returning low. Strangely, when moving with the softare controls to
    as high as it can go and doing M119, it returns H for x and y, but L for
    z - however that's always been the case since I bought it so I don't
    think that's related.
    Apologies if this is more info than you need,
    but I opened repetier (boots industries version), ran g32 s2, then m119,
    then moved the probe down to about 1cm above the bed, ran m119 again,
    then g32 s2 again.
    16:55:33.843 : OpenGL version:3.1.0 - Build 9.17.10.4229
    16:55:33.846
    : OpenGL extensions:GL_EXT_blend_minmax GL_EXT_blend_subtract
    GL_EXT_blend_color GL_EXT_abgr GL_EXT_texture3D GL_EXT_clip_volume_hint
    GL_EXT_compiled_vertex_array GL_SGIS_texture_edge_clamp
    GL_SGIS_generate_mipmap GL_EXT_draw_range_elements GL_SGIS_texture_lod
    GL_EXT_rescale_normal GL_EXT_packed_pixels GL_EXT_texture_edge_clamp
    GL_EXT_separate_specular_color GL_ARB_multitexture
    GL_EXT_texture_env_combine GL_EXT_bgra GL_EXT_blend_func_separate
    GL_EXT_secondary_color GL_EXT_fog_coord GL_EXT_texture_env_add
    GL_ARB_texture_cube_map GL_ARB_transpose_matrix GL_ARB_texture_env_add
    GL_IBM_texture_mirrored_repeat GL_EXT_multi_draw_arrays
    GL_NV_blend_square GL_ARB_texture_compression
    GL_3DFX_texture_compression_FXT1 GL_EXT_texture_filter_anisotropic
    GL_ARB_texture_border_clamp GL_ARB_point_parameters
    GL_ARB_texture_env_combine GL_ARB_texture_env_dot3
    GL_ARB_texture_env_crossbar GL_EXT_texture_compression_s3tc
    GL_ARB_shadow GL_ARB_window_pos GL_EXT_shadow_funcs GL_EXT_stencil_wrap
    GL_ARB_vertex_program GL_EXT_texture_rectangle GL_ARB_fragment_program
    GL_EXT_stencil_two_side GL_ATI_separate_stencil
    GL_ARB_vertex_buffer_object GL_EXT_texture_lod_bias
    GL_ARB_occlusion_query GL_ARB_fragment_shader GL_ARB_shader_objects
    GL_ARB_shading_language_100 GL_ARB_texture_non_power_of_two
    GL_ARB_vertex_shader GL_NV_texgen_reflection GL_ARB_point_sprite
    GL_ARB_fragment_program_shadow GL_EXT_blend_equation_separate
    GL_ARB_depth_texture GL_ARB_texture_rectangle GL_ARB_draw_buffers
    GL_ARB_color_buffer_float GL_ARB_half_float_pixel GL_ARB_texture_float
    GL_ARB_pixel_buffer_object GL_EXT_framebuffer_object
    GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_occlusion_query2
    GL_EXT_draw_buffers2 GL_WIN_swap_hint GL_EXT_texture_sRGB
    GL_ARB_multisample GL_EXT_packed_float GL_EXT_texture_shared_exponent
    GL_ARB_texture_rg GL_ARB_texture_compression_rgtc
    GL_NV_conditional_render GL_EXT_texture_swizzle GL_ARB_sync
    GL_ARB_framebuffer_sRGB GL_EXT_packed_depth_stencil
    GL_ARB_depth_buffer_float GL_EXT_transform_feedback
    GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample
    GL_ARB_framebuffer_object GL_EXT_texture_array GL_EXT_texture_integer
    GL_ARB_map_buffer_range GL_EXT_texture_snorm
    GL_INTEL_performance_queries GL_ARB_copy_buffer GL_ARB_sampler_objects
    GL_NV_primitive_restart GL_ARB_seamless_cube_map
    GL_ARB_uniform_buffer_object GL_ARB_depth_clamp GL_ARB_vertex_array_bgra
    GL_ARB_shader_bit_encoding GL_ARB_draw_buffers_blend
    GL_ARB_texture_query_lod GL_ARB_explicit_attrib_location
    GL_ARB_draw_elements_base_vertex GL_ARB_instanced_arrays
    GL_ARB_fragment_coord_conventions GL_EXT_gpu_program_parameters
    GL_ARB_texture_buffer_object_rgb32 GL_ARB_compatibility
    GL_ARB_texture_rgb10_a2ui GL_ARB_vertex_type_2_10_10_10_rev
    GL_ARB_timer_query GL_INTEL_map_texture GL_ARB_vertex_array_object
    GL_ARB_provoking_vertex
    16:55:33.846 : OpenGL renderer:Intel(R) HD Graphics
    16:55:33.846 : Using fast VBOs for rendering is possible
    16:56:13.757 : start
    16:56:16.207 : Info:External Reset
    16:56:16.211 : Info:Autoleveling enabled
    16:56:16.218 : Info: 1.000000 0.000000 0.000000 0.000000 1.000000 0.000000 0.000000 0.000000 1.000000
    16:56:16.221 : Free RAM:1322
    16:56:16.224 : X:0.00 Y:0.00 Z:0.00 E:0.00
    16:56:16.280 : Resend:1
    16:56:16.328 : Error:Wrong checksum
    16:56:16.328 : Resend:1
    16:56:16.452 : FIRMWARE_NAME:Repetier_0.91 FIRMWARE_URL:https://github.com/repetier/Repetier-Firmware/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:Delta EXTRUDER_COUNT:2 REPETIER_PROTOCOL:2
    16:56:16.452 : Printed filament:60.50m Printing time:0 days 9 hours 43 min
    16:56:16.469 : Begin file list
    16:56:16.488 : Printer Setup Files/
    16:56:16.489 : Printer Setup Files/Boots industries V2.5 for /
    16:56:16.499 : Printer Setup Files/Boots industries V2.5 for /Boots Industries V2.5.fff 21700
    16:56:16.502 : Printer Setup Files/BI_V2.5.ini.zip 1250
    16:56:16.506 : Printer Setup Files/Calibration Info.url 178
    16:56:16.510 : Printer Setup Files/Getting Started Guide.url 158
    16:56:16.515 : Printer Setup Files/setupBootsIndustriesRepeti 23209592
    16:56:16.519 : Printer Setup Files/Exported EEprom Settings/
    16:56:16.528 : Printer Setup Files/Belt Conversion Info.url 153
    16:56:16.532 : Printer Setup Files/Dual Extruder Arduino Hex /
    16:56:16.539 : Printer Setup Files/Dual Extruder Arduino Hex /Dual.hex 410791
    16:56:16.545 : Printer Setup Files/Dual Extruder Arduino Hex /XLoader.zip 694591
    16:56:16.552 : Printer Setup Files/Adjusting the probe height 169
    16:56:16.556 : Marvin_KeyChain.gco 571271
    16:56:16.564 : Thin Tube.gco 730096
    16:56:16.566 : STLS/
    16:56:16.574 : STLS/B2.5_Level Test.stl 28884
    16:56:16.577 : STLS/VaseDoubleTwist.stl 11779884
    16:56:16.579 : STLS/Thin Tube.stl 144084
    16:56:16.582 : STLS/Stretchlet.stl 2985997
    16:56:16.585 : STLS/Marvin_KeyChain.STL 674084
    16:56:16.588 : STLS/treefrog_45_cut.stl 11810826
    16:56:16.592 : TreeFrog.gco 1701380
    16:56:16.596 : End file list
    16:56:16.609 : FIRMWARE_NAME:Repetier_0.91 FIRMWARE_URL:https://github.com/repetier/Repetier-Firmware/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:Delta EXTRUDER_COUNT:2 REPETIER_PROTOCOL:2
    16:56:16.614 : Printed filament:60.50m Printing time:0 days 9 hours 43 min
    16:56:16.625 : Error:Format error
    16:56:16.626 : Resend:4
    16:56:16.634 : Error:Wrong checksum
    16:56:16.634 : Resend:4
    16:56:16.638 : Error:Format error
    16:56:16.638 : Resend:4
    16:56:16.651 : Error:Format error
    16:56:16.651 : Unknown command:
    16:56:16.651 : Error:Wrong checksum
    16:56:16.651 : Resend:4
    16:56:16.664 : skip 15
    16:56:16.664 : Begin file list
    16:56:16.668 : Printer Setup Files/
    16:56:16.676 : Printer Setup Files/Boots industries V2.5 for /
    16:56:16.685 : Printer Setup Files/Boots industries V2.5 for /Boots Industries V2.5.fff 21700
    16:56:16.689 : Printer Setup Files/BI_V2.5.ini.zip 1250
    16:56:16.693 : Printer Setup Files/Calibration Info.url 178
    16:56:16.697 : Printer Setup Files/Getting Started Guide.url 158
    16:56:16.702 : Printer Setup Files/setupBootsIndustriesRepeti 23209592
    16:56:16.706 : Printer Setup Files/Exported EEprom Settings/
    16:56:16.715 : Printer Setup Files/Belt Conversion Info.url 153
    16:56:16.719 : Printer Setup Files/Dual Extruder Arduino Hex /
    16:56:16.726 : Printer Setup Files/Dual Extruder Arduino Hex /Dual.hex 410791
    16:56:16.732 : Printer Setup Files/Dual Extruder Arduino Hex /XLoader.zip 694591
    16:56:16.738 : Printer Setup Files/Adjusting the probe height 169
    16:56:16.743 : Marvin_KeyChain.gco 571271
    16:56:16.751 : Thin Tube.gco 730096
    16:56:16.753 : STLS/
    16:56:16.761 : STLS/B2.5_Level Test.stl 28884
    16:56:16.764 : STLS/VaseDoubleTwist.stl 11779884
    16:56:16.766 : STLS/Thin Tube.stl 144084
    16:56:16.769 : STLS/Stretchlet.stl 2985997
    16:56:16.772 : STLS/Marvin_KeyChain.STL 674084
    16:56:16.775 : STLS/treefrog_45_cut.stl 11810826
    16:56:16.779 : TreeFrog.gco 1701380
    16:56:16.780 : End file list
    16:56:32.505 : Info:Autoleveling disabled
    16:56:34.213 : Z-probe:5.15 X:0.00 Y:120.00
    16:56:36.633 : Z-probe:5.15 X:116.00 Y:-64.99
    16:56:39.231 : Z-probe:5.15 X:-116.00 Y:-64.99
    16:56:39.801 : Info: 1.00000 0.00000 0.00000 0.00000 1.00000 0.00000 0.00000 0.00000 1.00000
    16:56:39.803 : Printer height:398.30
    16:56:39.805 : Info:Autoleveling enabled
    16:56:40.764 : X:-116.00 Y:-64.99 Z:0.00 E:0.00
    16:56:43.114 : X:0.00 Y:0.00 Z:398.30 E:0.00
    16:57:28.320 : x_max:H y_max:H z_max:L
    16:57:35.741 : X:0.00 Y:50.00 Z:398.30 E:0.00
    16:57:36.098 : X:0.00 Y:50.00 Z:398.30 E:0.00
    16:57:36.604 : X:0.00 Y:50.00 Z:398.30 E:0.00
    16:57:43.443 : x_max:L y_max:L z_max:L
    16:58:14.057 : Info:Autoleveling disabled
    16:58:15.344 : Z-probe:5.15 X:0.00 Y:120.00
    16:58:17.765 : Z-probe:5.15 X:116.00 Y:-64.99
    16:58:20.363 : Z-probe:5.15 X:-116.00 Y:-64.99
    16:58:20.862 : Info: 1.00000 0.00000 0.00000 0.00000 1.00000 0.00000 0.00000 0.00000 1.00000
    16:58:20.864 : Printer height:393.15
    16:58:20.866 : Info:Autoleveling enabled
    16:58:21.825 : X:-116.00 Y:-64.99 Z:10.30 E:0.00
    16:58:27.526 : X:0.00 Y:0.00 Z:393.16 E:0.00
  • M119 should always return L for all the switches when none are triggered/pressed. You can test them by running M119 when pressing one by one and see it's state is H. If this is not so they are wrongly configured of faulty.
  • Well they do all work fine - it's just that the z arm, after homing, moves down slightly which stops M119 reading as H - but as I said it's always done that so I don't think that's the issue with it not being able to calibrate with g32 s2.
    It's got something to do with the probe suddenly starting to be triggered where it's already at as opposed to moving down and being triggered by the pressure.
  • Your M119 does not return z probe state, only z endstop. So you are using a older firmware. Use G31 to test z probe signal then, which works on older firmware as well.
  • Oh I see, sorry, I got confused, I'm still getting used to differentiating the z-arm and the z-probe haha.
    You're correct, G31 returns only the z-probe state and it's always returning H regardless of where the hotend is and whether the probe has been pulled out or not.
    How do I fix this then?
    My version is 'Boots Industries Repetier-Host BI V2.5 V1.0.6'. So I think it's an up-to-date version of Repetier? Past 0.96 atleast right? But then again, if M119 is supposed to return z-probe state on newer versions and it doesn't, I guess it's not up-to-date. When I click help>check for updates, it says it "can't find a connection to the server" though, even though I definitely am streaming youtube etc.
    I also found this thread https://forum.repetier.com/discussion/1204/z-probing-trouble which I read but where do I find the '#define Z_PROBE_ON_HIGH' settings? I looked for a config file in program files, but could only find custom.ini
  • I'm using windows 8.1 btw if it makes a difference. :)
  • Since it worked before I think it is a hardware defect. So maybe probe is just stuck on high or a short. But that is your problem. As soon as it switches between H and L it should work again.
  • Okay, but how do I find the '#define Z_PROBE_ON_HIGH' etc settings so I can atleast make sure it's not that before I start taking the thing apart and potentially making it worse?
  • @saskwatch : in referencce to  your question, "define Z_PROBE_ON_HIGH' should be in the configuration.h file in your firmware directory that you use the Arduino program to flash the EEPROM on your board with. You might not have those files. I did a Google search for that printer and went to the Wikipage for it which had calibration info, but like it's been said if the probe is not working, i.e.  "switching states"., you won't get anywhere.
    There are links to firmware  and HEX files on that page (dated 2014) along with directions to upload them, but the  probe needs to be working first !
  • Hey just an update for maybe others with the same problem - I fixed it! The culprit was a wire that had become disconnected to the probe so I soldered it back on. :)
    Thanks for your help guys, you were right!
    I now have an issue of not being able to get the print to stick on the first 1 or 2 or 3 layers (let me know if I should post this somewhere else). Heated bed + hairspray etc, I just have no idea what's wrong. When I look horizontally at the extruder when it's printing I can see that the gap between end and bed changes on 1 side of the bed so obviously there's a calibration issue at the very least.
    1. When I try using the height map (following the video at https://www.repetier.com/documentation/repetier-firmware/z-probing/), I can make the map, but G33 does nothing, and G29 only measures 3 points on the bed and doesn't correct anything (log pasted at the bottom).
    2. This is all after doing manual calibration by getting the extruder to pinch a piece of paper - just how tightly do I want it to pinch the paper btw? Just so I can feel it pulling slightly? Or so that it's gripping the paper and I can't move it without tugging?
    23:53:01.536 : Info:Autoleveling disabled
    23:53:04.695 : Z-probe:10.14 X:0.00 Y:120.00
    23:53:07.899 : Z-probe:11.10 X:116.00 Y:-64.99
    23:53:11.270 : Z-probe:10.68 X:-116.00 Y:-64.99
    23:53:12.145 : Z-probe average height:10.64
    23:53:12.147 : Info:Autoleveling enabled
    23:53:12.150 : X:-116.02 Y:-64.96 Z:7.08 E:25.37
    Side note:
    When doing the height map, I don't get any mention of 'zCorr' like the guy in the video does, I instead get 'E' - what does 'E' represent?
    Random section from z-probe pasted here as example:
    23:36:35.642 : Info:Autoleveling disabled
    23:36:36.593 : Z-probe:10.48 X:17.16 Y:85.68
    23:36:36.955 : Info:Autoleveling enabled
    23:36:36.957 : X:17.14 Y:85.71 Z:7.46 E:25.37
  • Forget about G29. It is 3 point leveling and might even disable rotation correction etc. What was G29 with distortion correction is now G33!
    E is extruder position. It just comes from reporting current position, you can ignore that line.
    G33 only corrects until a defined hight (see your configuration) and reduces correction to 0 then. So if you test that feature make sure you are in 100% correction range.
    zCorr only appears if you have distortion correction enabled and compiled. Since you said G33 does nothing you do not seem to have compiled firmware with distortion correction.
  • I've tried looking for a setting in eeprom config and printer config for G33 correcting until a defined height but couldn't see any - I'm probably missing it - where exactly is the setting?
    And do you know if it would matter much if I downloaded and used the most up-to-date repetier software even though my printer has a dedicated (though seemingly outdated at this point...) version with custom settings?
    Or would I be able to export all relevant settings to the new repetier version? I know I can export eeprom and and slic3r settings, are they only settings that would matter or is there something that I might not be able to copy over?
  • Go to
    and in general tab at bottom you can define distortion map.
    eeprom only covers a big part of settings but many values have to be defined in Configuration.h as well. Replacing a vendor solution is normally no problem if you know the right settings. You should check your vendor homepage for the configuration.h he used. That makes it easy to make a new version.
  • I couldn't find one on their page and they haven't responded to emails, so I think I'm stuck for that.
    I'm not sure how to use that tool you linked me - I don't know what most of the settings should be on my printer, and it says that uploaded current settings need to have been made by that tool so I'm assuming that means I can't upload my current configuration.h?
    Also I've run into another problem whilst trying to get the height map sorted (which I've been able to approximate by changing the z-probe coordinates to a smaller area which I'm actually using for a typical print), which is that 1 of the arms is missing steps (or seems like it), here is a video:
    What are your thoughts?
    Thank you for the help by the way - I would've probably quit and sold the printer without it haha
  • The setup for config tool is a Configuration.h file with a special comment with json string containing the settings, so maybe your config matches. If not the config tool always shows the name of te setting as it is named in configuration.h so you could look there.
    In video I see a vibrating belt. That is very bad for quality. Don't see missing steps looks more like tension is not high enough and the bottom pulley maybe has the teeth going over the end of the gear causing it to swing.
  • Hmm, how do I fix the tension then? I can't find anything about it on the manufacturer's website.
  • Move motor up or bottom pulley down and fix screws. Or check where belt is fixed if that has a tension mechanism.
    Also maybe you need to rotate lower pulley a bit up so the belt does not spring over the end - at least it looked a bit like that to me. You might move very slow to see if it is really pushing belt outside until it springs back. But that was my impression for the reason of it.
  • I fixed it by adding some 3d-printed washers to the screws on the top of the belt - essentially pulling up and tightening, so it was the belt tightness, thanks! :)
    I've now run into another weird problem...
    Basically I'm getting  the extruded lines be wonky - except it only happens when the extruder is traveling a certain direction.
    I made a video - you can skip through most of it until the end where I show it compared, but it's harder to tell with the yellow.
    I took a photo of the same thing but on a red print so it might be easier to see
    Any idea what's causing this? I just can't think that it can be the filament or something (been having issues with the feeder skipping) because it only happens at a certain direction. Though occasionally it changes - sometimes it's only wobbly left-to-right and then halfway through the print it changes to forwards-to-backwards.
    Video:
    Pic:
    https://s14.postimg.org/uj41afd7l/20161123_004219.jpg
  • It's just strange because the 'wobbly bits' are raised up and sometimes side to side but the vast majority of the time they're raised up only
  • The only reason I know is if the gap between nozzle and ground is too high. Then you start getting waves. So maybe you are printing not enough filament for your choosen height or extruder is underextruding from your settings. Just try increasing flow while printing and see if it then gets better.
  • I don't think it can be the gap because it's only on patches (such as next to the left corner in the photo) and isn't over the whole surface, so the extruder underextruding seems more likely - but why would it only be underextruding on a certain patch, or only sometimes at all for that matter?
  • Maybe you are already near the volume wher eit works and sometime it's ok and sometimes not.
  • Hm. I printed at a smaller height and it seemed to go away for the most part so I suppose it doesn't matter at small heights
    I'm also now having an issue with my heated bed - its just stopped working for no reason (it was working a few hours ago and hasn't been moved or even touched other than to take a print off the bed), which isn't a huge deal in itself, but now I can't start prints because the print is waiting for the bed to heat up, which never happens. I've tried changing the bed temperate for 'first layer' and 'other layers' in filament settings configuration in slic3r to disable bed, but when I reset everything and try again with the new settings, the heat bed is still activated and the same issue persists with never starting the print
    Is there another setting that I'm missing for disabling (or even fixing) the bed?
    Btw do you guys accept bitcoin as donations?
  • First thing is to check log files. It will switch to dry run if heating fails. It will also write out many other information depending on error. So if you see it want to heat and temp. graph shows full heating power and it does not get warm it might have no power - so bed could be defect, fuse burned, mosfet defect  - all assuming it worked before making a hardware failure the typical reason.
  • The temperature graph shows full power to the bed and it doesn't heat, but the log (toggle log button at the top?) doesn't add anything when I start the print - the latest thing in it is info from slic3r.
    I'm assuming the bed has become defected, but is there a way to disable the bed as a work-around for the print never starting?
    I've tried changing the bed temperate for 'first layer' and 'other layers' in filament settings in configuration in slic3r, and set 'default heated bed temperature' in repetier>printer settings> printer - but when I reset everything and try to print, it still tries to heat the bed.
    How can I disable the bed other than what I've already done? Btw repetier version is 0.91.
  • I had the log set to not show some things, so I was wrong about it not saying anything when the print starts, log is:
    13:36:18.449 : N24 M105 *49
    13:36:18.450 : ok 24
    13:36:18.673 : N25 M117 ETE 00s *20
    13:36:18.688 : ok 25
    13:36:18.745 : N26 G21 *14
    13:36:18.746 : N27 M107 *48
    13:36:18.749 : N28 M190 S50 *71
    13:36:18.752 : N29 M104 T1 S190 *51
    13:36:18.752 : N30 G28 *0
    13:36:18.752 : N31 G1 Z5 F5000 *22
    13:36:18.753 : N32 M109 T1 S190 *52
    13:36:18.753 : N33 G90 *0
    13:36:18.753 : N34 M83 *15
    13:36:18.753 : N35 T1 *45
    13:36:18.753 : N36 G1 E-8 F3600 *46
    13:36:18.753 : N37 G1 Z5.015 F4800 *3
    13:36:18.781 : ok 26
    13:36:18.781 : ok 27
    13:36:18.782 : N38 G1 X-26.984 Y64.635 F4800 *118
    13:36:18.782 : ok 28
    13:36:18.886 : TargetBed:50
    13:36:21.513 : N39 M105 *61
    I just don't know how to stop it trying to heat the bed other than what I've done already?
  • TL;DR
    Update: I found the faulty wire with the heated bed so I've fixed the issue and there's no need to waste more of your time on this, but now I'm just curious how you're supposed to disable the bed after the settings I tried didn't work haha
    You also didn't tell me if you accept bitcoins as donation?
  • No we have no bitcoin wallet, only paypal:-(
    YOu can recompile firmware with HAVE_HEATED_BED 0 so it does not try to use bed. Or in slicer just say to not use bed if the temp.sensor is still working.
