g32 s2 misconfig?
Hi, I'm new to printing and these forums and wll hopefully creating contnt I can share with you all soon!
However I'm having issues printing. I just bought a Boots Industries V2.5 Delta 2nd hand and saw it working, got it home, calibrated it, got a couple of prints out of it, but then for some reason the command G32 S2 just stopped working suddenly after going through calibration a couple of times...
I have recorded a video of it here:
Basically when hitting G32 S2 the hotend doesn't move in any z direction and just moves around in x and y, storing the height of the bed as the end's current height. I've tried reinstalling etc. I'd been having some issues with it tearing the first couple of layers but now I can't do anything with it stuck and not able to calibrate!
as high as it can go and doing M119, it returns H for x and y, but L for
z - however that's always been the case since I bought it so I don't
think that's related.
Apologies if this is more info than you need,
but I opened repetier (boots industries version), ran g32 s2, then m119,
then moved the probe down to about 1cm above the bed, ran m119 again,
then g32 s2 again.
16:55:33.843 : OpenGL version:3.1.0 - Build 9.17.10.4229
16:55:33.846
: OpenGL extensions:GL_EXT_blend_minmax GL_EXT_blend_subtract
GL_EXT_blend_color GL_EXT_abgr GL_EXT_texture3D GL_EXT_clip_volume_hint
GL_EXT_compiled_vertex_array GL_SGIS_texture_edge_clamp
GL_SGIS_generate_mipmap GL_EXT_draw_range_elements GL_SGIS_texture_lod
GL_EXT_rescale_normal GL_EXT_packed_pixels GL_EXT_texture_edge_clamp
GL_EXT_separate_specular_color GL_ARB_multitexture
GL_EXT_texture_env_combine GL_EXT_bgra GL_EXT_blend_func_separate
GL_EXT_secondary_color GL_EXT_fog_coord GL_EXT_texture_env_add
GL_ARB_texture_cube_map GL_ARB_transpose_matrix GL_ARB_texture_env_add
GL_IBM_texture_mirrored_repeat GL_EXT_multi_draw_arrays
GL_NV_blend_square GL_ARB_texture_compression
GL_3DFX_texture_compression_FXT1 GL_EXT_texture_filter_anisotropic
GL_ARB_texture_border_clamp GL_ARB_point_parameters
GL_ARB_texture_env_combine GL_ARB_texture_env_dot3
GL_ARB_texture_env_crossbar GL_EXT_texture_compression_s3tc
GL_ARB_shadow GL_ARB_window_pos GL_EXT_shadow_funcs GL_EXT_stencil_wrap
GL_ARB_vertex_program GL_EXT_texture_rectangle GL_ARB_fragment_program
GL_EXT_stencil_two_side GL_ATI_separate_stencil
GL_ARB_vertex_buffer_object GL_EXT_texture_lod_bias
GL_ARB_occlusion_query GL_ARB_fragment_shader GL_ARB_shader_objects
GL_ARB_shading_language_100 GL_ARB_texture_non_power_of_two
GL_ARB_vertex_shader GL_NV_texgen_reflection GL_ARB_point_sprite
GL_ARB_fragment_program_shadow GL_EXT_blend_equation_separate
GL_ARB_depth_texture GL_ARB_texture_rectangle GL_ARB_draw_buffers
GL_ARB_color_buffer_float GL_ARB_half_float_pixel GL_ARB_texture_float
GL_ARB_pixel_buffer_object GL_EXT_framebuffer_object
GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_occlusion_query2
GL_EXT_draw_buffers2 GL_WIN_swap_hint GL_EXT_texture_sRGB
GL_ARB_multisample GL_EXT_packed_float GL_EXT_texture_shared_exponent
GL_ARB_texture_rg GL_ARB_texture_compression_rgtc
GL_NV_conditional_render GL_EXT_texture_swizzle GL_ARB_sync
GL_ARB_framebuffer_sRGB GL_EXT_packed_depth_stencil
GL_ARB_depth_buffer_float GL_EXT_transform_feedback
GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample
GL_ARB_framebuffer_object GL_EXT_texture_array GL_EXT_texture_integer
GL_ARB_map_buffer_range GL_EXT_texture_snorm
GL_INTEL_performance_queries GL_ARB_copy_buffer GL_ARB_sampler_objects
GL_NV_primitive_restart GL_ARB_seamless_cube_map
GL_ARB_uniform_buffer_object GL_ARB_depth_clamp GL_ARB_vertex_array_bgra
GL_ARB_shader_bit_encoding GL_ARB_draw_buffers_blend
GL_ARB_texture_query_lod GL_ARB_explicit_attrib_location
GL_ARB_draw_elements_base_vertex GL_ARB_instanced_arrays
GL_ARB_fragment_coord_conventions GL_EXT_gpu_program_parameters
GL_ARB_texture_buffer_object_rgb32 GL_ARB_compatibility
GL_ARB_texture_rgb10_a2ui GL_ARB_vertex_type_2_10_10_10_rev
GL_ARB_timer_query GL_INTEL_map_texture GL_ARB_vertex_array_object
GL_ARB_provoking_vertex
16:55:33.846 : OpenGL renderer:Intel(R) HD Graphics
16:55:33.846 : Using fast VBOs for rendering is possible
16:56:13.757 : start
16:56:16.207 : Info:External Reset
16:56:16.211 : Info:Autoleveling enabled
16:56:16.218 : Info: 1.000000 0.000000 0.000000 0.000000 1.000000 0.000000 0.000000 0.000000 1.000000
16:56:16.221 : Free RAM:1322
16:56:16.224 : X:0.00 Y:0.00 Z:0.00 E:0.00
16:56:16.280 : Resend:1
16:56:16.328 : Error:Wrong checksum
16:56:16.328 : Resend:1
16:56:16.452 : FIRMWARE_NAME:Repetier_0.91 FIRMWARE_URL:https://github.com/repetier/Repetier-Firmware/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:Delta EXTRUDER_COUNT:2 REPETIER_PROTOCOL:2
16:56:16.452 : Printed filament:60.50m Printing time:0 days 9 hours 43 min
16:56:16.469 : Begin file list
16:56:16.488 : Printer Setup Files/
16:56:16.489 : Printer Setup Files/Boots industries V2.5 for /
16:56:16.499 : Printer Setup Files/Boots industries V2.5 for /Boots Industries V2.5.fff 21700
16:56:16.502 : Printer Setup Files/BI_V2.5.ini.zip 1250
16:56:16.506 : Printer Setup Files/Calibration Info.url 178
16:56:16.510 : Printer Setup Files/Getting Started Guide.url 158
16:56:16.515 : Printer Setup Files/setupBootsIndustriesRepeti 23209592
16:56:16.519 : Printer Setup Files/Exported EEprom Settings/
16:56:16.528 : Printer Setup Files/Belt Conversion Info.url 153
16:56:16.532 : Printer Setup Files/Dual Extruder Arduino Hex /
16:56:16.539 : Printer Setup Files/Dual Extruder Arduino Hex /Dual.hex 410791
16:56:16.545 : Printer Setup Files/Dual Extruder Arduino Hex /XLoader.zip 694591
16:56:16.552 : Printer Setup Files/Adjusting the probe height 169
16:56:16.556 : Marvin_KeyChain.gco 571271
16:56:16.564 : Thin Tube.gco 730096
16:56:16.566 : STLS/
16:56:16.574 : STLS/B2.5_Level Test.stl 28884
16:56:16.577 : STLS/VaseDoubleTwist.stl 11779884
16:56:16.579 : STLS/Thin Tube.stl 144084
16:56:16.582 : STLS/Stretchlet.stl 2985997
16:56:16.585 : STLS/Marvin_KeyChain.STL 674084
16:56:16.588 : STLS/treefrog_45_cut.stl 11810826
16:56:16.592 : TreeFrog.gco 1701380
16:56:16.596 : End file list
16:56:16.609 : FIRMWARE_NAME:Repetier_0.91 FIRMWARE_URL:https://github.com/repetier/Repetier-Firmware/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:Delta EXTRUDER_COUNT:2 REPETIER_PROTOCOL:2
16:56:16.614 : Printed filament:60.50m Printing time:0 days 9 hours 43 min
16:56:16.625 : Error:Format error
16:56:16.626 : Resend:4
16:56:16.634 : Error:Wrong checksum
16:56:16.634 : Resend:4
16:56:16.638 : Error:Format error
16:56:16.638 : Resend:4
16:56:16.651 : Error:Format error
16:56:16.651 : Unknown command:
16:56:16.651 : Error:Wrong checksum
16:56:16.651 : Resend:4
16:56:16.664 : skip 15
16:56:16.664 : Begin file list
16:56:16.668 : Printer Setup Files/
16:56:16.676 : Printer Setup Files/Boots industries V2.5 for /
16:56:16.685 : Printer Setup Files/Boots industries V2.5 for /Boots Industries V2.5.fff 21700
16:56:16.689 : Printer Setup Files/BI_V2.5.ini.zip 1250
16:56:16.693 : Printer Setup Files/Calibration Info.url 178
16:56:16.697 : Printer Setup Files/Getting Started Guide.url 158
16:56:16.702 : Printer Setup Files/setupBootsIndustriesRepeti 23209592
16:56:16.706 : Printer Setup Files/Exported EEprom Settings/
16:56:16.715 : Printer Setup Files/Belt Conversion Info.url 153
16:56:16.719 : Printer Setup Files/Dual Extruder Arduino Hex /
16:56:16.726 : Printer Setup Files/Dual Extruder Arduino Hex /Dual.hex 410791
16:56:16.732 : Printer Setup Files/Dual Extruder Arduino Hex /XLoader.zip 694591
16:56:16.738 : Printer Setup Files/Adjusting the probe height 169
16:56:16.743 : Marvin_KeyChain.gco 571271
16:56:16.751 : Thin Tube.gco 730096
16:56:16.753 : STLS/
16:56:16.761 : STLS/B2.5_Level Test.stl 28884
16:56:16.764 : STLS/VaseDoubleTwist.stl 11779884
16:56:16.766 : STLS/Thin Tube.stl 144084
16:56:16.769 : STLS/Stretchlet.stl 2985997
16:56:16.772 : STLS/Marvin_KeyChain.STL 674084
16:56:16.775 : STLS/treefrog_45_cut.stl 11810826
16:56:16.779 : TreeFrog.gco 1701380
16:56:16.780 : End file list
16:56:32.505 : Info:Autoleveling disabled
16:56:34.213 : Z-probe:5.15 X:0.00 Y:120.00
16:56:36.633 : Z-probe:5.15 X:116.00 Y:-64.99
16:56:39.231 : Z-probe:5.15 X:-116.00 Y:-64.99
16:56:39.801 : Info: 1.00000 0.00000 0.00000 0.00000 1.00000 0.00000 0.00000 0.00000 1.00000
16:56:39.803 : Printer height:398.30
16:56:39.805 : Info:Autoleveling enabled
16:56:40.764 : X:-116.00 Y:-64.99 Z:0.00 E:0.00
16:56:43.114 : X:0.00 Y:0.00 Z:398.30 E:0.00
16:57:28.320 : x_max:H y_max:H z_max:L
16:57:35.741 : X:0.00 Y:50.00 Z:398.30 E:0.00
16:57:36.098 : X:0.00 Y:50.00 Z:398.30 E:0.00
16:57:36.604 : X:0.00 Y:50.00 Z:398.30 E:0.00
16:57:43.443 : x_max:L y_max:L z_max:L
16:58:14.057 : Info:Autoleveling disabled
16:58:15.344 : Z-probe:5.15 X:0.00 Y:120.00
16:58:17.765 : Z-probe:5.15 X:116.00 Y:-64.99
16:58:20.363 : Z-probe:5.15 X:-116.00 Y:-64.99
16:58:20.862 : Info: 1.00000 0.00000 0.00000 0.00000 1.00000 0.00000 0.00000 0.00000 1.00000
16:58:20.864 : Printer height:393.15
16:58:20.866 : Info:Autoleveling enabled
16:58:21.825 : X:-116.00 Y:-64.99 Z:10.30 E:0.00
16:58:27.526 : X:0.00 Y:0.00 Z:393.16 E:0.00
It's got something to do with the probe suddenly starting to be triggered where it's already at as opposed to moving down and being triggered by the pressure.
You're correct, G31 returns only the z-probe state and it's always returning H regardless of where the hotend is and whether the probe has been pulled out or not.
How do I fix this then?
My version is 'Boots Industries Repetier-Host BI V2.5 V1.0.6'. So I think it's an up-to-date version of Repetier? Past 0.96 atleast right? But then again, if M119 is supposed to return z-probe state on newer versions and it doesn't, I guess it's not up-to-date. When I click help>check for updates, it says it "can't find a connection to the server" though, even though I definitely am streaming youtube etc.
I also found this thread https://forum.repetier.com/discussion/1204/z-probing-trouble which I read but where do I find the '#define Z_PROBE_ON_HIGH' settings? I looked for a config file in program files, but could only find custom.ini
Thanks for your help guys, you were right!
I now have an issue of not being able to get the print to stick on the first 1 or 2 or 3 layers (let me know if I should post this somewhere else). Heated bed + hairspray etc, I just have no idea what's wrong. When I look horizontally at the extruder when it's printing I can see that the gap between end and bed changes on 1 side of the bed so obviously there's a calibration issue at the very least.
1. When I try using the height map (following the video at https://www.repetier.com/documentation/repetier-firmware/z-probing/), I can make the map, but G33 does nothing, and G29 only measures 3 points on the bed and doesn't correct anything (log pasted at the bottom).
2. This is all after doing manual calibration by getting the extruder to pinch a piece of paper - just how tightly do I want it to pinch the paper btw? Just so I can feel it pulling slightly? Or so that it's gripping the paper and I can't move it without tugging?
23:53:01.536 : Info:Autoleveling disabled
23:53:04.695 : Z-probe:10.14 X:0.00 Y:120.00
23:53:07.899 : Z-probe:11.10 X:116.00 Y:-64.99
23:53:11.270 : Z-probe:10.68 X:-116.00 Y:-64.99
23:53:12.145 : Z-probe average height:10.64
23:53:12.147 : Info:Autoleveling enabled
23:53:12.150 : X:-116.02 Y:-64.96 Z:7.08 E:25.37
Side note:
When doing the height map, I don't get any mention of 'zCorr' like the guy in the video does, I instead get 'E' - what does 'E' represent?
Random section from z-probe pasted here as example:
23:36:35.642 : Info:Autoleveling disabled
23:36:36.593 : Z-probe:10.48 X:17.16 Y:85.68
23:36:36.955 : Info:Autoleveling enabled
23:36:36.957 : X:17.14 Y:85.71 Z:7.46 E:25.37
And do you know if it would matter much if I downloaded and used the most up-to-date repetier software even though my printer has a dedicated (though seemingly outdated at this point...) version with custom settings?
Or would I be able to export all relevant settings to the new repetier version? I know I can export eeprom and and slic3r settings, are they only settings that would matter or is there something that I might not be able to copy over?
I'm not sure how to use that tool you linked me - I don't know what most of the settings should be on my printer, and it says that uploaded current settings need to have been made by that tool so I'm assuming that means I can't upload my current configuration.h?
Also I've run into another problem whilst trying to get the height map sorted (which I've been able to approximate by changing the z-probe coordinates to a smaller area which I'm actually using for a typical print), which is that 1 of the arms is missing steps (or seems like it), here is a video:
What are your thoughts?
Thank you for the help by the way - I would've probably quit and sold the printer without it haha
I've now run into another weird problem...
Basically I'm getting the extruded lines be wonky - except it only happens when the extruder is traveling a certain direction.
I made a video - you can skip through most of it until the end where I show it compared, but it's harder to tell with the yellow.
I took a photo of the same thing but on a red print so it might be easier to see
Any idea what's causing this? I just can't think that it can be the filament or something (been having issues with the feeder skipping) because it only happens at a certain direction. Though occasionally it changes - sometimes it's only wobbly left-to-right and then halfway through the print it changes to forwards-to-backwards.
Video:
Pic:
https://s14.postimg.org/uj41afd7l/20161123_004219.jpg
I'm also now having an issue with my heated bed - its just stopped working for no reason (it was working a few hours ago and hasn't been moved or even touched other than to take a print off the bed), which isn't a huge deal in itself, but now I can't start prints because the print is waiting for the bed to heat up, which never happens. I've tried changing the bed temperate for 'first layer' and 'other layers' in filament settings configuration in slic3r to disable bed, but when I reset everything and try again with the new settings, the heat bed is still activated and the same issue persists with never starting the print
Is there another setting that I'm missing for disabling (or even fixing) the bed?
Btw do you guys accept bitcoin as donations?
I'm assuming the bed has become defected, but is there a way to disable the bed as a work-around for the print never starting?
I've tried changing the bed temperate for 'first layer' and 'other layers' in filament settings in configuration in slic3r, and set 'default heated bed temperature' in repetier>printer settings> printer - but when I reset everything and try to print, it still tries to heat the bed.
How can I disable the bed other than what I've already done? Btw repetier version is 0.91.
13:36:18.449 : N24 M105 *49
13:36:18.450 : ok 24
13:36:18.673 : N25 M117 ETE 00s *20
13:36:18.688 : ok 25
13:36:18.745 : N26 G21 *14
13:36:18.746 : N27 M107 *48
13:36:18.749 : N28 M190 S50 *71
13:36:18.752 : N29 M104 T1 S190 *51
13:36:18.752 : N30 G28 *0
13:36:18.752 : N31 G1 Z5 F5000 *22
13:36:18.753 : N32 M109 T1 S190 *52
13:36:18.753 : N33 G90 *0
13:36:18.753 : N34 M83 *15
13:36:18.753 : N35 T1 *45
13:36:18.753 : N36 G1 E-8 F3600 *46
13:36:18.753 : N37 G1 Z5.015 F4800 *3
13:36:18.781 : ok 26
13:36:18.781 : ok 27
13:36:18.782 : N38 G1 X-26.984 Y64.635 F4800 *118
13:36:18.782 : ok 28
13:36:18.886 : TargetBed:50
13:36:21.513 : N39 M105 *61
I just don't know how to stop it trying to heat the bed other than what I've done already?
Update: I found the faulty wire with the heated bed so I've fixed the issue and there's no need to waste more of your time on this, but now I'm just curious how you're supposed to disable the bed after the settings I tried didn't work haha
You also didn't tell me if you accept bitcoins as donation?
