Problems with moving X and Y
Hi
I have a fiew problems with "Repetier Host" and "Cartesian Printer".
1. I made changes in my construction, and now:
- the "X" axis theoretically can travel 290 mm
- the "Y" axis theoretically can travel 250 mm
My work area is clear 240 mm * 240 mm.
I use Repetier Firmware v.0.92 and the last version of Repetier Host.
My hardware is: Arduino Mega 2560 + RAMPS 1.4 + Discount LCD controler
Before changes my work area was: 240 mm * 240 mm and all was OK.
Now I can't move "X" and "Y" more than 240 mm. Some Ideas where can this values be stored (240 mm) ?
When I tell the printer: G1 X250, it moves to 240 ans stops, but in the manual control, the value for X is 250 ?!?!? If I want to move it with another 10 mm (for example) it do not moves, but the value raises to 260...
In Printer Shape section in Printer Settings, my physical "Bed left" value is 35mm. I tried to change it, to change X min, even with a negative values, but nothing changed.
When I set X min for example as "-15", and I press "Home X", the value in the X cell changes to -15, but when the exruder hit the End Stop, this value changes to "0".
It doesnot mater what value I use, and where I put it, every time the maximum travel for "X" stais 240 mm.
The same is for "Y"
