MKS GEN L V2.1 + DRV8825 + Smart controller full graphic
Hello,
I've tried evrything, 3 days now, no stop but with no result![:( :(](/resources/emoji/frowning.png)
I've modified the pins of X,Y and Z in RAMPS.H. chosing the cartasian mood, and try to test one stepper motor of X axis just to check if it's working or not, but nothings happen!
the x sensonr is not triggered.
Please find attached pronterface messages:
Connecting...
start
Printer is now online.
Marlin 2.0.9.3
echo: Last Updated: 2021-12-25 | Author: (none, default config)
echo: Compiled: Mar 8 2022
echo: Free Memory: 3543 PlannerBufferBytes: 1200
echo:Hardcoded Default Settings Loaded
echo:; Linear Units:
echo: G21 ; (mm)
echo:; Temperature Units:
echo: M149 C ; Units in Celsius
echo:; Filament settings (Disabled):
echo: M200 S0 D1.75
echo:; Steps per unit:
echo: M92 X80.00 Y80.00 Z1600.00 E95.00
echo:; Max feedrates (units/s):
echo: M203 X500.00 Y500.00 Z15.00 E25.00
echo:; Max Acceleration (units/s2):
echo: M201 X3000.00 Y3000.00 Z100.00 E10000.00
echo:; Acceleration (units/s2) (P<print-accel> R<retract-accel> T<travel-accel>):
echo: M204 P500.00 R500.00 T1000.00
echo:; Advanced (B<min_segment_time_us> S<min_feedrate> T<min_travel_feedrate> J<junc_dev>):
echo: M205 B20000.00 S0.00 T0.00 J0.01
echo:; Home offset:
echo: M206 X0.00 Y0.00 Z0.00
echo:; Auto Bed Leveling:
echo: M420 S0 Z10.00 ; Leveling OFF
echo:; Material heatup parameters:
echo: M145 S0 H180.00 B70.00 F0
echo: M145 S1 H240.00 B110.00 F0
echo:; Hotend PID:
echo: M301 P22.20 I1.08 D114.00
echo:; Z-Probe Offset:
echo: M851 X0 Y0 Z0.00 ; (mm)
>>>M119
SENDING:M119
Reporting endstop status
x_min: open
y_min: TRIGGERED
z_min: TRIGGERED
z_probe: TRIGGERED
>>>G1 X10
SENDING:G1 X10
echo:busy: processing
echo:Homing Failed
Error:Printer halted. kill() called!
[ERROR] Error:Printer halted. kill() called!
Disconnected.
I've tried evrything I found in the net , but it seems like I still have an issue that I don't know where..
Thank you.
Regards,
Could u show me how?
Thank u
Das Display wird unterstützt, problem ist daher nur das wir keine vordefinierten pins haben fürs board.
