second UART for Bluetooth isnt working after upgrade from 0.9.2 to 1.0.1
in Bug Reports
Hello,
i do have tried a setup with ESP3D serial to tcp/ip connection on one of my 3d-printers.
My hardware is the classic reprap hardware with arduino mega2560 and ramps 1.4.
After a quick view in the pins.h for ramps motherboard i have seen the D16/D17 pins for UART2 are not used.
Then after activation of the "Bluetooth UART 2" the fullgraphic 12864 smartcontroller was not working, so after some search in the sources i found the places where the pins are defined.
for 0.9.2 its in "ui.h" UI_DISPLAY_RS_PIN and UI_DISPLAY_ENABLE_PIN on 16/17. On the AUX4 connector are some spare pins so i changed the signals of the display to 39 and 43 and modified the display adapter pcb. (line 801/803)
for rev 1.0.1 the right place for the same thing is "displaylist.h" (line 326/328) with same signals and pin definition.
After changing the signal lines as described and switch to the modified display adapter the smartcontroller is working now.
But i cant get a serial connection on UART2 with repetier fw 1.0.1
On version 0.9.2 it is working.
I tried different baudrate too, and a usb-serial(TTL) adapter on the pins, but doesnt work with 1.0.1
Sorry, 18 and 19 pins of course.
And i try to connect PUTTY terminal via bluetooth - empty, no one symbol after flashing new firmware. I try to short rx\tx pins on ramps 1.4 and terminal have echo but still no comunnication with board. After flashing old firmware with the same config i see on terminal "welcome" and activity and connection work properly.
This isn't a permanent fix but it achieved what I needed for now.
https://github.com/repetier/Repetier-Firmware/issues/799
