Z_axis_go down after homing_and_print_in_the_air
1) I have a problem with zhe z-axis after homing it goes down 15mm and print start in the air.
2) After change the value of Endstop settings ... z-homing does not work and pressing by the Z-endstop.
3) How to connect the extruder-cooler in the Repetier-Firmware ? Hardware: extruder-cooler ist connected on Servos-Pin D11 (two wires)
Firmware: Repetier 0.92.9 , online generated.
My board: Ramps1.4 with Arduino Mega 2560
My Printer: Tronxy X5
Endstops:
(have all the same endstops nornal open with two wires connected onboard to +5V and GND, S(Signal) connector onboard ist free)
X-endstop position is right => must be X_MAX, on board is connected to the X_MAX
Y-endstop position is behind => must be Y_MIN, on board is connected to the Y_MIN
Z-endstop position is above => must be Z_MAX, on board is connected to the Z_MAX
No Autoleveling.
No Probe.
Can somebody check my configuration.h : Thank's for your help !!!
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
generator: http://www.repetier.com/firmware/v092/
as you expect.
#define NUM_EXTRUDER 1 // Gibt die Anzahl der Extruder an
#define MOTHERBOARD 33 // Nr.33 = Ramps 1.4
#include "pins.h"
#undef FAN_BOARD_PIN
#define FAN_BOARD_PIN -1
#define BOARD_FAN_SPEED 255
#define FAN_THERMO_PIN -1
#undef X_MAX_PIN
#define X_MAX_PIN -1
#undef Y_MAX_PIN
#define Y_MAX_PIN -1
#undef Z_MAX_PIN
#define Z_MAX_PIN -1
//#define COMPAT_PRE1
#define BLUETOOTH_SERIAL -1
#define BLUETOOTH_BAUD 115200
#define MIXING_EXTRUDER 0
#define DRIVE_SYSTEM 0
#define XAXIS_STEPS_PER_MM 80
#define YAXIS_STEPS_PER_MM 80
#define ZAXIS_STEPS_PER_MM 400
#define PDM_FOR_EXTRUDER 0
#define PDM_FOR_COOLER 0
#define RETRACT_ON_PAUSE 2
#define PAUSE_END_COMMANDS ""
#define EXT0_X_OFFSET 0
#define EXT0_Y_OFFSET 0
#define EXT0_Z_OFFSET 0 // 04.02.2020: ? Abstand des Endschalterns der Z-Achse von Oben angeben ? Damit Abstand Z-Achse zu Hotbed verschwindet.
#define EXT0_STEPS_PER_MM 101.91 /*stock default=370 */
#define EXT0_INVERSE 0 // Extruder-Motor-Drehrichtung invertieren mit 1
#define EXT0_ENABLE_ON 0
#define EXT0_MIRROR_STEPPER 0
#define EXT0_INVERSE2 0
#define EXT0_MAX_FEEDRATE 50 // Geschwindigkeit des 1.Extruders
#define EXT0_MAX_START_FEEDRATE 40 // empfohlen: 20
#define EXT0_MAX_ACCELERATION 5000 // empfohlen: 5000, default: 10000 */
#define EXT0_HEAT_MANAGER 3 // Type of heat manager for this extruder.
// 0 = Simply switch on/off if temperature is reached. Works always.
// 1 = PID Temperature control. Is better but needs good PID values. Defaults are a good start for most extruder.
// 3 = Dead-time control. PID_P becomes dead-time in seconds. Overridden if EEPROM activated.
#define EXT0_WATCHPERIOD 1
#define EXT0_PID_I 2
#define EXT0_PID_D 40
#define EXT0_PID_MAX 255
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define EXT0_EXTRUDER_COOLER_PIN -1 /* The extruder cooler is a fan to cool the extruder when it is heating. If you turn the extruder on, the fan goes on. */
#define EXT0_JAM_PIN -1
#define EXT0_JAM_PULLUP 0
#define FEATURE_RETRACTION 1
#define AUTORETRACT_ENABLED 0
#define RETRACTION_LENGTH 3
#define RETRACTION_SPEED 40
#define RETRACTION_Z_LIFT 0
#define JAM_STEPS 220
#define JAM_SLOWDOWN_TO 70
#define JAM_ERROR_STEPS 500
#define JAM_MIN_STEPS 10
#define JAM_ACTION 0
#define PID_CONTROL_RANGE 20
#define SKIP_M109_IF_WITHIN 2
#define SCALE_PID_TO_MAX 0
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 160
#define GENERIC_THERM_VREF 5
#define HEATER_PWM_SPEED 0
#define HAVE_HEATED_BED 1
#define SKIP_M190_IF_WITHIN 3
#define MIN_EXTRUDER_TEMP 150
#define MAXTEMP 230
#define MAX_DEFECT_TEMPERATURE 230
// ## Laser configuration ##
automatically disabled.
#define SUPPORT_LASER 0
#define LASER_PIN -1
#define LASER_ON_HIGH 1
// ## CNC configuration ##
#define SUPPORT_CNC 0
#define CNC_WAIT_ON_DISABLE 0
#define CNC_ENABLE_PIN -1
#define CNC_ENABLE_WITH 1
#define CNC_DIRECTION_PIN -1
#define CNC_DIRECTION_CW 1
#define MIN_HARDWARE_ENDSTOP_X true // true definiert wo der Endschalter beim Homing ist richtig
#define ENDSTOP_PULLUP_Y_MIN true // true mechanischer Endschalter
#define ENDSTOP_Z_MIN_INVERTING false //war true => geändert auf false wie im Forum im Repetier Configuration bei eimem Nutzer.
#define MAX_HARDWARE_ENDSTOP_Z true // 03.02.2020 war false => auf true geändert wie beim Nutzer im Forum im Repetier FW => war Fehler "Z_MAX_PIN eingeben !!! " => zurück auf false.
// 04.02.2020 auf true geändert und auf dem board auf max umgesteckt
#define min_software_endstop_x false // Definiert Softwareendstopps die sich aus der Bauraumgröße berechnen. Default: false
#define ENDSTOP_X_BACK_MOVE 5 // Gibt die Entfernung vor die der Endstopp ein zweites mal angefahren wird
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 2
#define ENDSTOP_X_RETEST_REDUCTION_FACTOR 3 // Reduziert die Geschwindigkeit beim zweiten Anfahren um genauer zu sein
#define ENDSTOP_Z_BACK_ON_HOME 0 // war 0 => habe 1 eingetragen.03.02.2020 = > wieder zurück auf 0
#define X_ENABLE_ON 0 // 1 für RAPS128/Silencioso 0 für alle anderen Treiber
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 0
#define INVERT_Y_DIR 0
#define INVERT_Z_DIR 0
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR 0
#define X_MAX_LENGTH 195
#define Y_MAX_LENGTH 170
#define Z_MAX_LENGTH 220
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define DISTORTION_XMIN 0
#define DISTORTION_YMIN 0
#define DISTORTION_XMAX 195
#define DISTORTION_YMAX 170
// ## Movement settings ##
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_HOME_ON_POWER 0
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 200
#define MAX_FEEDRATE_Y 200
#define MAX_FEEDRATE_Z 2
#define HOMING_FEEDRATE_X 40
#define HOMING_FEEDRATE_Y 40
#define HOMING_FEEDRATE_Z 2
#define HOMING_ORDER HOME_ORDER_XYZ
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 999999
#define ZHOME_Y_POS 999999
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 0
#define DIRECTION_DELAY 0
#define ALLOW_QUADSTEPPING 1
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 1000 // Beschleunigung der Achsen beim Druck
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 1000 // Beschleunigung der Achsen beim Fahren
#define MAX_JERK 20 // Die Eckenbeschleunigung von X und Y-Achse
#define MAX_ZJERK 0.3
#define MOVE_CACHE_LOW 10
#define DUAL_X_AXIS 0
#define FEATURE_TWO_XSTEPPER 0 //Mit 1 ist ein zweiter X Stepper (Schrittmotor aktiviert, der zum ersten gespiegelt wird)
#define FEATURE_TWO_YSTEPPER 0 //Mit 1 ist ein zweiter Y Stepper (Schrittmotor aktiviert, der zum ersten gespiegelt wird)
#define FEATURE_TWO_ZSTEPPER 0 //Mit 1 ist ein zweiter Z Stepper (Schrittmotor aktiviert, der zum ersten gespiegelt wird)
#define FEATURE_THREE_ZSTEPPER 0 //Mit 1 ist ein dritter Z Stepper (Schrittmotor aktiviert, der zum ersten gespiegelt wird)
#define USE_ADVANCE 0
#define BAUDRATE 115200
#define POWER_INVERTING 0
#define KILL_METHOD 1
#define ACK_WITH_LINENUMBER 1
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 1
#undef PS_ON_PIN
#define JSON_OUTPUT 0
/* ======== Servos =======
Control the servos with
#define FEATURE_SERVO 0 // Hier können Servos aktiviert und angesteuert werden
#define SERVO0_PIN 11
#define SERVO1_PIN -1
#define SERVO2_PIN -1
#define SERVO3_PIN -1
#define SERVO0_NEUTRAL_POS -1
#define SERVO1_NEUTRAL_POS -1
#define SERVO2_NEUTRAL_POS -1
#define SERVO3_NEUTRAL_POS -1
#define UI_SERVO_CONTROL 0
#define FEATURE_WATCHDOG 0 // Sicherheitseinrichtung bei Filamentstörung
#define Z_PROBE_Z_OFFSET 0 // Hier wird das Autoleveling aktiviert und eingestellt
#define UI_BED_COATING 1
#define FEATURE_Z_PROBE 0
#define Z_PROBE_BED_DISTANCE 0
#define Z_PROBE_PIN -1
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_REPETITIONS 1
#define Z_PROBE_HEIGHT 40
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 20
#define Z_PROBE_Y1 20
#define Z_PROBE_X2 160
#define Z_PROBE_Y2 20
#define Z_PROBE_X3 100
#define Z_PROBE_Y3 160
#define BED_LEVELING_METHOD 0
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
#define SDSUPPORT 0
#undef SDCARDDETECT
#define SDCARDDETECT -1
#endif
#define SD_EXTENDED_DIR 1 /* Show extended directory including file length. Don't use this with Pronterface! */
#define SD_RUN_ON_STOP ""
#define ARC_SUPPORT 1
#define FEATURE_FAN_CONTROL 1
#define FEATURE_CONTROLLER 11
#define ADC_KEYPAD_PIN -1
#define LANGUAGE_EN_ACTIVE 0
#define LANGUAGE_DE_ACTIVE 1
#define LANGUAGE_NL_ACTIVE 0
#define LANGUAGE_PT_ACTIVE 0
#define LANGUAGE_IT_ACTIVE 0
#define LANGUAGE_ES_ACTIVE 0
#define LANGUAGE_FI_ACTIVE 0
#define LANGUAGE_SE_ACTIVE 0
#define LANGUAGE_FR_ACTIVE 0
#define LANGUAGE_CZ_ACTIVE 0
#define LANGUAGE_PL_ACTIVE 0
#define LANGUAGE_TR_ACTIVE 0
#define UI_PRINTER_NAME "AF-Repetier"
#define UI_PRINTER_COMPANY "Tronxy X5"
#define UI_ANIMATION 0
#define UI_AUTORETURN_TO_MENU_AFTER 30000 // LCD-Menu springt zum Wurzelmenu in (ms) Milisekunden
#define FEATURE_UI_KEYS 0
#define UI_ENCODER_SPEED 1
#define UI_REVERSE_ENCODER 0
#define UI_KEY_BOUNCETIME 10
#define UI_KEY_MIN_REPEAT 50
#define FEATURE_BEEPER 0
#define CASE_LIGHTS_PIN -1
#define UI_SET_PRESET_EXTRUDER_TEMP_PLA 200
#define UI_SET_PRESET_EXTRUDER_TEMP_ABS 230
#define UI_SET_EXTRUDER_FEEDRATE 2 // Geschwindigkeit des Extruder-Motors
#define NUM_MOTOR_DRIVERS 0
#endif
as you expect.
#include "pins.h"
#undef X_MAX_PIN
#undef Y_MAX_PIN
#undef Z_MAX_PIN
#define MAXTEMP 230
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
// Delta settings
#undef PS_ON_PIN
#define SDSUPPORT 0
#undef SDCARDDETECT
#endif
#endif
This is a good way to destroy the 5 volt regulator on the arduino when a endstop is triggered.
