Z_axis_go down after homing_and_print_in_the_air
1) I have a problem with zhe z-axis after homing it goes down 15mm and print start in the air.
2) After change the value of Endstop settings ... z-homing does not work and pressing by the Z-endstop.
3) How to connect the extruder-cooler in the Repetier-Firmware ? Hardware: extruder-cooler ist connected on Servos-Pin D11 (two wires)
Firmware: Repetier 0.92.9 , online generated.
My board: Ramps1.4 with Arduino Mega 2560
My Printer: Tronxy X5
Endstops:
(have all the same endstops  nornal open with two wires connected onboard to +5V and GND, S(Signal) connector onboard ist free)
X-endstop position is right => must be X_MAX, on board is connected to the X_MAX
Y-endstop position is behind => must be Y_MIN, on board is connected to the Y_MIN
Z-endstop position is above => must be Z_MAX, on board is connected to the Z_MAX
No Autoleveling.
No Probe.
Can somebody check my configuration.h :   Thank's for your help !!!
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
   generator: http://www.repetier.com/firmware/v092/
   as you expect.
#define NUM_EXTRUDER 1    // Gibt die Anzahl der Extruder an
#define MOTHERBOARD 33    // Nr.33 = Ramps 1.4
#include "pins.h"
#undef FAN_BOARD_PIN
#define FAN_BOARD_PIN -1
#define BOARD_FAN_SPEED 255
#define FAN_THERMO_PIN -1
#undef X_MAX_PIN
#define X_MAX_PIN -1
#undef Y_MAX_PIN
#define Y_MAX_PIN -1
#undef Z_MAX_PIN
#define Z_MAX_PIN -1
//#define COMPAT_PRE1
#define BLUETOOTH_SERIAL  -1
#define MIXING_EXTRUDER 0
#define DRIVE_SYSTEM 0
#define XAXIS_STEPS_PER_MM 80
#define YAXIS_STEPS_PER_MM 80
#define ZAXIS_STEPS_PER_MM 400
#define PDM_FOR_EXTRUDER 0
#define PDM_FOR_COOLER 0
#define RETRACT_ON_PAUSE 2
#define PAUSE_END_COMMANDS ""
#define EXT0_X_OFFSET 0
#define EXT0_Y_OFFSET 0
#define EXT0_Z_OFFSET 0   //   04.02.2020:    ? Abstand des Endschalterns der Z-Achse von Oben angeben ? Damit Abstand Z-Achse zu Hotbed verschwindet.
#define EXT0_STEPS_PER_MM 101.91  /*stock default=370 */
#define EXT0_INVERSE 0                  // Extruder-Motor-Drehrichtung invertieren mit 1
#define EXT0_ENABLE_ON 0
#define EXT0_MIRROR_STEPPER 0
#define EXT0_INVERSE2 0
#define EXT0_MAX_FEEDRATE 50          // Geschwindigkeit des 1.Extruders
#define EXT0_MAX_START_FEEDRATE 40    // empfohlen: 20
#define EXT0_MAX_ACCELERATION 5000   // empfohlen: 5000, default: 10000 */
#define EXT0_HEAT_MANAGER 3         //  Type of heat manager for this extruder.
                                //  0 = Simply switch on/off if temperature is reached. Works always.
                                //  1 = PID Temperature control. Is better but needs good PID values. Defaults are a good start for most extruder.
                                //  3 = Dead-time control. PID_P becomes dead-time in seconds. Overridden if EEPROM activated.
#define EXT0_WATCHPERIOD 1
#define EXT0_PID_I 2
#define EXT0_PID_D 40
#define EXT0_PID_MAX 255
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define EXT0_EXTRUDER_COOLER_PIN -1  /* The extruder cooler is a fan to cool the extruder when it is heating. If you turn the extruder on, the fan goes on. */
#define EXT0_JAM_PIN -1
#define EXT0_JAM_PULLUP 0
#define FEATURE_RETRACTION 1
#define AUTORETRACT_ENABLED 0
#define RETRACTION_LENGTH 3
#define RETRACTION_SPEED 40
#define RETRACTION_Z_LIFT 0
#define JAM_STEPS 220
#define JAM_SLOWDOWN_TO 70
#define JAM_ERROR_STEPS 500
#define JAM_MIN_STEPS 10
#define JAM_ACTION 0
#define PID_CONTROL_RANGE 20
#define SKIP_M109_IF_WITHIN 2
#define SCALE_PID_TO_MAX 0
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 160
#define GENERIC_THERM_VREF 5
#define HEATER_PWM_SPEED 0
#define HAVE_HEATED_BED 1
#define SKIP_M190_IF_WITHIN 3
#define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   196
#define HEATED_BED_PID_IGAIN   33
#define MIN_EXTRUDER_TEMP 150
#define MAXTEMP 230
#define MAX_DEFECT_TEMPERATURE 230
// ##                             Laser configuration                                      ##
automatically disabled.
#define SUPPORT_LASER 0
#define LASER_PIN -1
#define LASER_ON_HIGH 1
// ##                              CNC configuration                                       ##
#define SUPPORT_CNC 0
#define CNC_WAIT_ON_DISABLE 0
#define CNC_ENABLE_PIN -1
#define CNC_ENABLE_WITH 1
#define CNC_DIRECTION_PIN -1
#define CNC_DIRECTION_CW 1
#define ENDSTOP_PULLUP_X_MIN    true
#define MIN_HARDWARE_ENDSTOP_X  true    // true definiert wo der Endschalter beim Homing ist  richtig
#define ENDSTOP_PULLUP_Y_MIN    true      // true mechanischer Endschalter
#define MIN_HARDWARE_ENDSTOP_Y  true
#define ENDSTOP_PULLUP_Z_MIN    true
#define ENDSTOP_Z_MIN_INVERTING false     //war true => geändert auf false wie im Forum im Repetier Configuration bei eimem Nutzer.
#define MIN_HARDWARE_ENDSTOP_Z  true
#define ENDSTOP_PULLUP_X_MAX    true
#define MAX_HARDWARE_ENDSTOP_X  false
#define ENDSTOP_PULLUP_Y_MAX    true
#define MAX_HARDWARE_ENDSTOP_Y  false
#define ENDSTOP_PULLUP_Z_MAX    true
#define MAX_HARDWARE_ENDSTOP_Z  true       // 03.02.2020 war false => auf true geändert wie beim Nutzer im Forum im Repetier FW => war Fehler "Z_MAX_PIN eingeben !!! " => zurück auf false.
                                           // 04.02.2020 auf true geändert und auf dem board auf max umgesteckt
#define min_software_endstop_x  false      // Definiert Softwareendstopps die sich aus der Bauraumgröße berechnen. Default: false
#define min_software_endstop_y  false
#define min_software_endstop_z  false
#define max_software_endstop_x  true
#define max_software_endstop_y  true
#define max_software_endstop_z  false
#define ENDSTOP_X_BACK_MOVE 5             // Gibt die Entfernung vor die der Endstopp ein zweites mal angefahren wird
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 2
#define ENDSTOP_X_RETEST_REDUCTION_FACTOR 3   // Reduziert die Geschwindigkeit beim zweiten Anfahren um genauer zu sein
#define ENDSTOP_Z_BACK_ON_HOME 0      // war 0 => habe 1 eingetragen.03.02.2020 = > wieder zurück auf 0
#define X_ENABLE_ON 0     //  1 für RAPS128/Silencioso 0 für alle anderen Treiber
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 0
#define INVERT_Y_DIR 0
#define INVERT_Z_DIR 0
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR 0
#define X_MAX_LENGTH 195
#define Y_MAX_LENGTH 170
#define Z_MAX_LENGTH 220
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define DISTORTION_XMIN 0
#define DISTORTION_YMIN 0
#define DISTORTION_XMAX 195
#define DISTORTION_YMAX 170
// ##                           Movement settings                                          ##
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_HOME_ON_POWER 0
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 200
#define MAX_FEEDRATE_Y 200
#define MAX_FEEDRATE_Z 2
#define HOMING_FEEDRATE_X 40
#define HOMING_FEEDRATE_Y 40
#define HOMING_FEEDRATE_Z 2
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 999999
#define ZHOME_Y_POS 999999
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 0
#define DIRECTION_DELAY 0
#define ALLOW_QUADSTEPPING 1
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 1000   // Beschleunigung der Achsen beim Druck
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 1000    // Beschleunigung der Achsen beim Fahren
#define MAX_JERK 20                         //  Die Eckenbeschleunigung von X und Y-Achse
#define MAX_ZJERK 0.3
#define MOVE_CACHE_LOW 10
#define DUAL_X_AXIS 0
#define FEATURE_TWO_XSTEPPER 0              //Mit 1 ist ein zweiter X Stepper (Schrittmotor aktiviert, der zum ersten gespiegelt wird)
#define X2_STEP_PIN   ORIG_E1_STEP_PIN
#define X2_DIR_PIN    ORIG_E1_DIR_PIN
#define FEATURE_TWO_YSTEPPER 0              //Mit 1 ist ein zweiter Y Stepper (Schrittmotor aktiviert, der zum ersten gespiegelt wird)
#define Y2_STEP_PIN   ORIG_E1_STEP_PIN
#define Y2_DIR_PIN    ORIG_E1_DIR_PIN
#define FEATURE_TWO_ZSTEPPER 0              //Mit 1 ist ein zweiter Z Stepper (Schrittmotor aktiviert, der zum ersten gespiegelt wird)
#define Z2_STEP_PIN   ORIG_E1_STEP_PIN
#define Z2_DIR_PIN    ORIG_E1_DIR_PIN
#define FEATURE_THREE_ZSTEPPER 0            //Mit 1 ist ein dritter Z Stepper (Schrittmotor aktiviert, der zum ersten gespiegelt wird)
#define Z3_STEP_PIN   ORIG_E2_STEP_PIN
#define Z3_DIR_PIN    ORIG_E2_DIR_PIN
#define USE_ADVANCE 0
#define BAUDRATE 115200
#define POWER_INVERTING 0
#define KILL_METHOD 1
#define ACK_WITH_LINENUMBER 1
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 1
#undef PS_ON_PIN
#define JSON_OUTPUT 0
/* ======== Servos =======
Control the servos with
M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
#define FEATURE_SERVO 0           // Hier können Servos aktiviert und angesteuert werden
#define SERVO0_PIN 11
#define SERVO1_PIN -1
#define SERVO2_PIN -1
#define SERVO3_PIN -1
#define UI_SERVO_CONTROL 0
    #define FEATURE_WATCHDOG 0          // Sicherheitseinrichtung bei Filamentstörung
#define Z_PROBE_Z_OFFSET 0              // Hier wird das Autoleveling aktiviert und eingestellt
#define UI_BED_COATING 1
#define FEATURE_Z_PROBE 0
#define Z_PROBE_BED_DISTANCE 0
#define Z_PROBE_PIN -1
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_REPETITIONS 1
#define Z_PROBE_HEIGHT 40
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 20
#define Z_PROBE_Y1 20
#define Z_PROBE_X2 160
#define Z_PROBE_Y2 20
#define Z_PROBE_X3 100
#define Z_PROBE_Y3 160
#define BED_LEVELING_METHOD 0
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
#ifndef SDSUPPORT             // Some boards have sd support on board. These define the values already in pins.h
#define SDSUPPORT 0
#undef SDCARDDETECT
#define SDCARDDETECT -1
#endif
#define SD_EXTENDED_DIR 1     /* Show extended directory including file length. Don't use this with Pronterface! */
#define SD_RUN_ON_STOP ""
#define ARC_SUPPORT 1
#define FEATURE_FAN_CONTROL 1
#define FEATURE_CONTROLLER 11
#define ADC_KEYPAD_PIN -1
#define LANGUAGE_EN_ACTIVE 0
#define LANGUAGE_DE_ACTIVE 1
#define LANGUAGE_NL_ACTIVE 0
#define LANGUAGE_PT_ACTIVE 0
#define LANGUAGE_IT_ACTIVE 0
#define LANGUAGE_ES_ACTIVE 0
#define LANGUAGE_FI_ACTIVE 0
#define LANGUAGE_SE_ACTIVE 0
#define LANGUAGE_FR_ACTIVE 0
#define LANGUAGE_CZ_ACTIVE 0
#define LANGUAGE_PL_ACTIVE 0
#define LANGUAGE_TR_ACTIVE 0
#define UI_PRINTER_NAME "AF-Repetier"
#define UI_PRINTER_COMPANY "Tronxy X5"
#define UI_ANIMATION 0
#define UI_AUTORETURN_TO_MENU_AFTER 30000     // LCD-Menu springt zum Wurzelmenu in (ms) Milisekunden
#define FEATURE_UI_KEYS 0
#define UI_ENCODER_SPEED 1
#define UI_REVERSE_ENCODER 0
#define UI_KEY_BOUNCETIME 10
#define UI_KEY_MIN_REPEAT 50
#define FEATURE_BEEPER 0
#define CASE_LIGHTS_PIN -1
#define UI_SET_PRESET_EXTRUDER_TEMP_PLA   200
#define UI_SET_PRESET_EXTRUDER_TEMP_ABS   230
#define UI_SET_MIN_EXTRUDER_TEMP   170
#define UI_SET_MAX_EXTRUDER_TEMP   260
#define UI_SET_EXTRUDER_FEEDRATE 2    // Geschwindigkeit des Extruder-Motors
#define NUM_MOTOR_DRIVERS 0
#endif
  • Guess your endstop wiring is not correct.
    if it´s mechanical endstops , normally open connected with two wires you have  to connect 1 wire to S(Signal),
    the other one to GND. +5V is not connected in this case.
  • (have all the same endstops  nornal open with two wires connected onboard to +5V and GND, S(Signal) connector onboard ist free)
    This is a good way to destroy the 5 volt regulator on the arduino when a endstop is triggered.
    Thank you RAyWB,
    your answer move me to check all wires again.
    All endstops are now right connected to each GND and Signal plug, (+5V plugs are not connected).
    Problem-1:  stepper motors - are only "knocking on heavens door" and no go forward.
    Solution-1:
    stepper-wiring was wrong connected. The speppers works now right and i can move them !!!
    Original cable-wiring was different connected ... i separated each stepper cable, checked all steppers phases with multimeter new and draw wiring diagram for me new .... and it helps me to start all steppers.
    I checked all 4 original tronxy nema17 steppers with each 6 pins with multimeter -  they all are unipolar stepper motors with 3 phase:
    1 wire = Phase 1A
    2 wire = Phase 2A
    3 wire = Phase 1B
    4 wire = Phase 3A
    5 wire = Phase 2B
    6 wire = Phase 3B
    On my Ramps 1.4 - 4 plugs for stepper :
    2B
    2A
    1A
    1B
    Stepper cable was different connected ..... I checked new the stepper-cable wiring and draw my wiring diagram.
    Now all the steppers are right connected and works.
    Thank you MartinH for your solution.
  • Hi,
    I install now the inductive z-probe sersor LJ12A3-4-Z/BY (NO Normal open) 6-36V DC for hotbed-autoleveling to PIN 63 on Ramps1.4 ( AUX-2):
    brown: +5V
    blue: GND
    black: PIN 63 on Ramps1.4 bei AUX-2
    Problem-2:
    z-probe-sensor  red-diode light on if i put metal under them by 1.6-2mm.
    If i home-z .... z-endstop does not work and z-probe does not stop z-homing.
    I checked z-endstop on Y .... it works.
    Question:
    Can i use the z-min-endstop on z-min-plug an ramps1.4 and use z-probe-inductive sensor on pin 63 together  ?
  • My new setups:
    Firmware: Repetier 1.0.3 , online generated.
    Endstops:
    (have all the same endstops  nornal open with two wires connected onboard to GND and  S(Signal) , (+5V plug onboard is not connected).
    z-probe-Bed-Autoleveling : inductive sensor LJ12A3-4-Z/BY normal open 6-36vdc, works on +5V on ramps1.4/mega2560.
  • LJ12A3-4-Z/BY   PNP
