motors just vibrate
HI   i just flashed Repetier on my prusa I3 running a mega 2560 and ramps 1.4 .The  Extruder motor does extrude/retract although reversed. The X,Y,Z steppers just vibrate loudly . Bed heater and nozzle heater both function normally too . Any Ideas ? Thanks in Advance
  • For extruder invert direction. There is a checkbox for this in config tool.
    Motors vibrating have either not enough current (there is a poti to set proper current, see docs of driver) or it gets blocked or acceleration is too high (microstepping not set as you think?) steps per mm too high, jerk too high or only one circuit has a connection, also it is unlikely to have the same contact problem on 3 motors.
  • Allso make sure you have fitted the 3 jumpers under each stepper driver on the ramps board, this sets them to 1/16 microstepping.
  • edited December 2021
    I have similar problem, using Rumba+ board and DRV8825 step drivers on my delta. I previously had this board and drivers working with different firmware, so am relatively certain the problem is not hardware. I've also temporarily swapped out the drivers with A4988's I had on printer originally (the Rumba is replacing a MKS Gen with a fried mosfet).
    The 8825's are nominally toggled for 1/32 microstepping, but I've tried other settings with no success. Here is my current configuration.h motion settings:
    #define NUM_EXTRUDER 1
    #define MOTHERBOARD 80
    #include "pins.h"
    #define HOST_RESCUE 1
    #undef FAN_PIN
    #define FAN_PIN ORIG_FAN2_PIN
    #undef FAN2_PIN
    #define FAN2_PIN -1
    #undef FAN_BOARD_PIN
    #define FAN_BOARD_PIN -1
    #define BOARD_FAN_SPEED 255
    #define BOARD_FAN_MIN_SPEED 0
    #define FAN_THERMO_PIN ORIG_FAN_PIN
    #define FAN_THERMO_THERMISTOR_PIN TEMP_0_PIN
    #undef X_MIN_PIN
    #define X_MIN_PIN -1
    #undef Y_MIN_PIN
    #define Y_MIN_PIN -1
    #undef Z_MIN_PIN
    #define Z_MIN_PIN -1
    #define BLUETOOTH_SERIAL  -1
    #define BLUETOOTH_BAUD  115200
    #define MIXING_EXTRUDER 0
    #define DRIVE_SYSTEM 3
    #define XAXIS_STEPS_PER_MM 80
    #define YAXIS_STEPS_PER_MM 80
    #define ZAXIS_STEPS_PER_MM 80
    #define PDM_FOR_EXTRUDER 0
    #define PDM_FOR_COOLER 0
    #define RETRACT_ON_PAUSE 2
    #define PAUSE_END_COMMANDS ""
    #define EXT0_X_OFFSET 0
    #define EXT0_Y_OFFSET 0
    #define EXT0_Z_OFFSET 0
    #define EXT0_STEPS_PER_MM 100
    #define EXT0_INVERSE 0
    #define EXT0_ENABLE_ON 1
    #define EXT0_MIRROR_STEPPER 0
    #define EXT0_INVERSE2 0
    #define EXT0_MAX_FEEDRATE 50
    #define EXT0_HEAT_MANAGER 1
    #define EXT0_PREHEAT_TEMP 190
    #define EXT0_WATCHPERIOD 1
    #define EXT0_PID_PGAIN_OR_DEAD_TIME 5
    #define EXT0_PID_I 1
    #define EXT0_PID_D 40
    #define EXT0_PID_MAX 255
    #define EXT0_ADVANCE_K 0
    #define EXT0_ADVANCE_L 0
    #define EXT0_EXTRUDER_COOLER_PIN ORIG_FAN_PIN
    #define EXT0_JAM_PIN ORIG_X_MIN_PIN
    #define EXT0_JAM_PULLUP 1
    #define FEATURE_RETRACTION 1
    #define AUTORETRACT_ENABLED 0
    #define RETRACTION_LENGTH 6
    #define RETRACTION_SPEED 50
    #define RETRACTION_Z_LIFT 0.1
    #define FILAMENTCHANGE_Z_ADD  2
    #define FILAMENTCHANGE_REHOME 2
    #define JAM_METHOD 3
    #define JAM_STEPS 220
    #define JAM_SLOWDOWN_TO 70
    #define JAM_ERROR_STEPS 500
    #define JAM_MIN_STEPS 10
    #define JAM_ACTION 1
    #define PID_CONTROL_RANGE 20
    #define SKIP_M109_IF_WITHIN 5
    #define SCALE_PID_TO_MAX 0
    #define TEMP_HYSTERESIS 0
    #define EXTRUDE_MAXLENGTH 160
    #define GENERIC_THERM_VREF 5
    #define TEMP_GAIN 1
    #define HEATER_PWM_SPEED 0
    #define COOLER_PWM_SPEED 0
    #define HAVE_HEATED_BED 1
    #define SKIP_M190_IF_WITHIN 3
    #define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   196
    #define HEATED_BED_PID_IGAIN   33
    #define MIN_EXTRUDER_TEMP 180
    #define MAXTEMP 260
    #define MAX_DEFECT_TEMPERATURE 265
    #define X2_MIN_PIN -1
    #define X2_MAX_PIN -1
    #define Y2_MIN_PIN -1
    #define Y2_MAX_PIN -1
    #define Z2_MINMAX_PIN -1
    #define DOOR_PIN -1
    #define DOOR_PULLUP 1
    #define DOOR_INVERTING 0
    #define ENDSTOP_X_BACK_MOVE 5
    #define ENDSTOP_Y_BACK_MOVE 5
    #define ENDSTOP_Z_BACK_MOVE 5
    #define ENDSTOP_X_BACK_ON_HOME 0
    #define ENDSTOP_Y_BACK_ON_HOME 0
    #define MOVE_X_WHEN_HOMED 0
    #define MOVE_Y_WHEN_HOMED 0
    #define MOVE_Z_WHEN_HOMED 0
    #define X_ENABLE_ON 1
    #define Y_ENABLE_ON 0
    #define Z_ENABLE_ON 1
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 1
    #define INVERT_X_DIR 0
    #define INVERT_X2_DIR 0
    #define INVERT_Y_DIR 0
    #define INVERT_Y2_DIR 0
    #define INVERT_Z_DIR 0
    #define INVERT_Z2_DIR 0
    #define INVERT_Z3_DIR 0
    #define INVERT_Z4_DIR 0
    #define X_HOME_DIR 1
    #define Y_HOME_DIR 1
    #define Z_HOME_DIR 1
    #define X_MAX_LENGTH 200
    #define Y_MAX_LENGTH 200
    #define Z_MAX_LENGTH 602.725
    #define X_MIN_POS -150
    #define Y_MIN_POS -150
    #define Z_MIN_POS 0
    #define PARK_POSITION_X 0
    #define PARK_POSITION_Y 0
    // ##                           Movement settings                                          ##
    #define EXACT_DELTA_MOVES 1
    // Delta settings
    #define DELTA_DIAGONAL_ROD 342 // mm
    #define DELTA_ALPHA_A 209.5525
    #define DELTA_ALPHA_B 329.39314
    #define DELTA_ALPHA_C 90
    #define DELTA_MAX_RADIUS 150
    #define ROD_RADIUS 178.37
    #define PRINTER_RADIUS 178.37
    #define DELTA_HOME_ON_POWER 1
    #define STEP_COUNTER
    #define DELTA_FLOOR_SAFETY_MARGIN_MM 15
    //#define SOFTWARE_LEVELING
    #define MAX_INACTIVE_TIME 600L
    #define MAX_FEEDRATE_X 100
    #define MAX_FEEDRATE_Y 100
    #define MAX_FEEDRATE_Z 5
    #define HOMING_FEEDRATE_X 40
    #define HOMING_FEEDRATE_Y 40
    #define HOMING_FEEDRATE_Z 40
    #define ZHOME_PRE_RAISE 0
    #define ZHOME_HEAT_ALL 1
    #define ZHOME_HEAT_HEIGHT 20
    #define ZHOME_X_POS 999999
    #define ZHOME_Y_POS 999999
    #define X_BACKLASH 0
    #define Y_BACKLASH 0
    #define Z_BACKLASH 0
    #define RAMP_ACCELERATION 1
    #define STEPPER_HIGH_DELAY 0
    #define DIRECTION_DELAY 0
    #define ALLOW_QUADSTEPPING 1
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 100
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 100
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 100
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 100
    #define ACCELERATION_FACTOR_TOP 10
    #define MAX_JERK 10
    #define MAX_ZJERK 0.3
    #define MOVE_CACHE_LOW 10
    #define DUAL_X_AXIS 0
    #define DUAL_X_RESOLUTION 0
    #define X2_STEP_PIN   ORIG_E1_STEP_PIN
    #define X2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Y2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Y2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Z2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z3_STEP_PIN   ORIG_E2_STEP_PIN
    #define Z3_DIR_PIN    ORIG_E2_DIR_PIN
    #define Z4_STEP_PIN   ORIG_E3_STEP_PIN
    #define Z4_DIR_PIN    ORIG_E3_DIR_PIN
    #define USE_ADVANCE 0
    #define BAUDRATE 115200
    #define ENABLE_POWER_ON_STARTUP 0
    #define POWER_INVERTING 0
    #define AUTOMATIC_POWERUP 0
    #define KILL_METHOD 1
    #define EMERGENCY_PARSER 1
    #define ACK_WITH_LINENUMBER 1
    #define ECHO_ON_EXECUTE 1
    #define EEPROM_MODE 1
    #undef PS_ON_PIN
    #define PS_ON_PIN -1
    #define JSON_OUTPUT 0
    #define FEATURE_WATCHDOG 1
    #define NUM_MOTOR_DRIVERS
    I need a sanity check. My accel and jerk setting don't look high to me, I've tried tuning pots. Why won't my motors go? They just freeze and buzz. Drivers get hot and buzz.
  • Does printer start with motors disabled or does disabling motor gcode disable them s you can move them freely? This is to check if enable signal is defined correctly. Buzzing should indicate that is ok as you loose steps on moves. Check eeprom settings - maybe you have there invalid or too high values - config only replaces them on different EEPROM_VALUE. Otherwise use
    M502
    M500
    to copy them to eeprom so config values get used again.
    What is strange is
    This setting is driver dependent so it means y axis uses different driver.
    The low acceleration should be no problem if used.
  • DRV 8825 should have
    #define STEPPER_HIGH_DELAY 1
    also as repetier mentioned:
    What is strange is
    usually the DRV8825 should all have 0 to get enabled
    I have tried both ways.
  • Buzzing should indicate that is ok as you loose steps on moves. Check eeprom settings - maybe you have there invalid or too high values - config only replaces them on different EEPROM_VALUE. Otherwise use
    M502
    M500
    Will need to check EEPROM. Good suggestion!
  • What is strange is
    This was an experiment to see if a) one would work- none did , and b) if anyone would catch it- congratulations!
    What is strange is
    Changed STEPPER_HIGH_DELAY to 1. Motors stopped buzzing, but still did not engage. It may be that there is something in the EEPROM still as @Repetier suggested.
  • So why not simply check eeprom for values:-)
