Is it possible to use Repetier-host with Klipper firmware ?
I'm trying to connect Repetier-host with Klipper firmware for tests. Both are installed under the latest version of Debian Stretch.
Repetier-host and klipper seems to work fine, klipper service is running.
I read this https://forum.repetier.com/discussion/comment/23099/#Comment_23099 and this https://github.com/KevinOConnor/klipper/issues/348 .
I have configured printer connection like this :
But in printer tab, Klipper doesn't exist in firmware type list.
I have check permissions for tty group and it's normally ok.
But when i try to connect Repetier-host to klipper, this doesn't work.
What can be the causes of this problem?
Thanks.
Seki
Thanks.
If not, any chance to see Klipper integration like other firmwares (Marlin, Smoothieware.. )?
Did you test if klipper it self works correctly? I mean uploaded firmware to board, connection works an dit connects fine.
