Connect Repetier Server to Klipper firmware
2»
  • Also it seems the Klipper Extended G-Code Commands are not working.
  • Did you prefix them with a #? I guess you mean the gcodes that do not follow gcode syntax and therefore are no gcodes. In server if you prefix a line with
    The content will be send 1:1 without checksum etc. That should work on all firmwares.
  • Yes. It works. Thanks !
