LEDs control in the LCD menu doesnt work with 1.0.3DEV and RuRamps
I've connected my LEDs strip to "Heater 3" (PIN 11), and declared in the Configuration.h:
#define CASE_LIGHTS_PIN 11
<command type="caseLightsOn">M42 P11 S255</command>
Please fix it.
The LEDs goes on during boot but i can't turn it ON/OFF from the LCD display menu, only from Repetier Server with a modded "repetier.xml":
<command type="caseLightsOff">M42 P11 S0</command>
Please fix it.
Cheers,
Marco
M355 S0
M355 S1
work and report the right light state?
My guess is that the TOGGLE command does not work for due. In that case it would be interesting to see if M355 reports the state correctly, otherwise I would need to waste some memory to store the light state.
Yes, with the M355 the light go off and on (S0 and S1), the problem is in the toggle.
