Ultratronics V1 Pro - Ardunio Due for Repetier (Programming Port) - Compilation errors
Windows 10, Arduino 1.6.13, SAMS 1.6.11 installed, modified boards.txt and variants added to folder shown in readme.txt. Repetier Firmware Configutator 1.0.0dev (https://www.repetier.com/firmware/dev/index.php).
Board selected as above, COM7 Programming Port. Compilation errors are:-
C:\Users\#####\AppData\Local\Temp\arduino_build_783006/core\core.a(wiring_analog.c.o): In function `analogWrite':
C:\Users\#####\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\cores\arduino/wiring_analog.c:349: undefined reference to `g_pinStatus'
C:\Users\#####\AppData\Local\Temp\arduino_build_783006/core\core.a(wiring_digital.c.o): In function `pinMode':
C:\Users\#####\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\cores\arduino/wiring_digital.c:82: undefined reference to `g_pinStatus'
C:\Users\#####\AppData\Local\Temp\arduino_build_783006/core\core.a(wiring_digital.c.o): In function `digitalWrite':
C:\Users\#####\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\cores\arduino/wiring_digital.c:113: undefined reference to `g_pinStatus'
C:\Users\#####\AppData\Local\Temp\arduino_build_783006/core\core.a(wiring_digital.c.o): In function `digitalRead':
C:\Users\#####\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\cores\arduino/wiring_digital.c:136: undefined reference to `g_pinStatus'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino Due for Repetier (Programming port).
Tried with #define FEATURE_WATCHDOG 1 and 0 in configuration.h no difference.
When I use Ardunio Due (Programming Port) I have no issues. Pointers please...
Line 295 uint8_t g_pinStatus[PINS_COUNT] = {0}; /// Added
