Due firmware won't compile out of the box with Arduino SAM board package 1.6.7
I am no programmer, so sorry if I misunderstood things.
I installed the AdditionalArduinoFiles as per instructions, but the Arduino compiler complains about an "undefined reference to `g_pinStatus'" for several of the standard files (wiring_analog.c etc.)
I checked the original (1.6.7) variant.cpp file, it has an extra definition:
 uint8_t g_pinStatus[PINS_COUNT] = {0};
When I add this to the "variant.cpp" file in the arduino_due_repetier folder, it does compile.
I hope this helps.
  • Will check it, thanks.
    Latest arduinos do not need the repetier version as tests showed. They now have a new way to handle watchdog initialization that allows it to enable watchdog.
