* DANGEROUS * Laser turns ON while homing
Hello Repetier and anyone reading this.
After finishing my laser machine build, I did the laser control in hardware properly:
- High signal on Laser Enable pin -> Laser ON
- Low -> OFF
- High Impendance state (like when burning the firmware) -> OFF
Of course, during config I set the high signal to enable the laser.
So, I figured out that after enabling the laser with M3 it operates as supposed to on G0 and G1 moves. BUT after these I may want to home the machine (G28), and at this point the laser goes ON again! This is definitely not the behavior you would expect.
I'm sure it is a bug, it is dangerous and needs fixing.
I'm running Repetier V0.92.8
Can post Configuration.h if needed.
Thanks in advance.
