Disabling in Configuration.h DECOUPLE_TEST ????
HI, morning.  I am having the problem of stopped printing beacause of message:
 "Error:One heater seems decoupled from thermistor". The problem is randomly sometimes I get 7 hours printing without problems and sometime 30 min. I have verified wiring and it´s ok
It Is the extruder´s heater beacause i don´t use heatbed.  I have seen in others threats where is recomended disabling the decouple_test for testing porpouses, but I dont find the line in order to deactivate this feacture.
So I have modified the parameter Decouple hold variance  to 999 but there is no diference.
Could you tell me how is disabled  Decoupled_Test ?
Thanks in advanced
  • Setting decouple time 0 disables the test.
  • Thanks a lot of.
    I have read this phrase sometime in anothers threads but there is no parameters in configuration.h .
    So I have arrived to conclusion the line to modify in Configuration.h is  this
    #define EXT0_DECOUPLE_TEST_PERIOD 0          -----> Disabled
    Could you confirm that my  assumption is correct ?
    Thanks in advanced
  • Yes, that is the one supposed to work.
  • Thanks a lot of.
    It worked like a champ
