Radds + raps128 Delta optimal advance settings
Hi everyone!
I was playing with the
advance mechanic settings and I was I little confuse… Everything print well but
there is probably an optimal setting set for the radds and raps128 combination.
So what are you guys settings,
I am talking here of :
DELTA_SEGMENTS_PER_SECOND_PRINT
DELTA_SEGMENTS_PER_SECOND_MOVE
DELTASEGMENTS_PER_PRINTLINE
STEPPER_HIGH_DELAY
STEP_DOUBLER_FREQUENCY
PRINTLINE_CACHE_SIZE
lowTicksPerMove
thx!
  • DELTA_SEGMENTS_PER_SECOND_PRINT 600
    DELTA_SEGMENTS_PER_SECOND_MOVE 600
    DELTASEGMENTS_PER_PRINTLINE 80
    STEPPER_HIGH_DELAY 1
    STEP_DOUBLER_FREQUENCY 80000
    PRINTLINE_CACHE_SIZE 24
  • Thank you so much! I
    am having one more related question. What is you maximum achievable speed without
    losing step? I know there is a lot of variable but I can’t get pass 100mm/s is
    it normal. Here’s my setup
    Stepper : 640 step/mm
    motors  : 92 oz-in, 200step/rev
    The stepper voltage
    potentiometer is is at max.
    Ps I am currently
    printing well at 9000 mm/s2 and 100mm/s. (home made printer)
    Merci!
  • I can run 200mm/s without loosing steps. If I go towards 500mm/s I start loosing steps on small problems. Key for high speed is
    - Good current setting. Maximum is not always the best. RAPS can deliver 2.1A and that might be too much for some motors reducing force.
    - Moderate jerk.
    - Moderate acceleration. I normally accelerate between 1000 and 1500mm/s^2
    These parameter create extra forces that can cause loosing steps if you exceed limits. Slow motors are stronger so what works with slow speeds might fail at higher speeds for that reason.
