Radds + raps128 Delta optimal advance settings
Hi everyone!
I was playing with the
advance mechanic settings and I was I little confuse… Everything print well but
there is probably an optimal setting set for the radds and raps128 combination.
So what are you guys settings,
I am talking here of :
DELTA_SEGMENTS_PER_SECOND_PRINT
DELTA_SEGMENTS_PER_SECOND_MOVE
DELTASEGMENTS_PER_PRINTLINE
STEPPER_HIGH_DELAY
STEP_DOUBLER_FREQUENCY
PRINTLINE_CACHE_SIZE
lowTicksPerMove
thx!
DELTA_SEGMENTS_PER_SECOND_PRINT 600
DELTA_SEGMENTS_PER_SECOND_MOVE 600
DELTASEGMENTS_PER_PRINTLINE 80
STEPPER_HIGH_DELAY 1
STEP_DOUBLER_FREQUENCY 80000
PRINTLINE_CACHE_SIZE 24
Thank you so much! I
am having one more related question. What is you maximum achievable speed without
losing step? I know there is a lot of variable but I can’t get pass 100mm/s is
it normal. Here’s my setup
Stepper : 640 step/mm
motors : 92 oz-in, 200step/rev
The stepper voltage
potentiometer is is at max.
Ps I am currently
printing well at 9000 mm/s2 and 100mm/s. (home made printer)
Merci!
