Won't let me cancel Recording?
Had an object that has been a PAIN to print, I suspect that the motion to take the photo is catching something, and then Spaghetti...
Wanted to turn off the recording during the print, and it won't let me.
I have turned off recording before, so what has changed?
  • What version are you using? Just tested with current 1.4.10 and it was disabled on hitting the disable button in webcam tab. Haven't changed it for a while so not sure if it did not work, was just delayed or for some reason you had a javascript issue preventing the command to be send. If it happens again with current release check browser javascript console for any errors giving a hint (right click in window, select inspect or inspect element and then switch to console).
