You normally set a xy position to probe since you must ensure to probe above bed. So you must home x and y first. Only then you can position xy wise correctly for z position selected. So select a homing order XYZ
Can you please show complete error message. You can increase bottom window part. The marked code is ok when I compile, so I need full detail of error message to be sure. Also important is it dev version or older 1.0.4 version?
Can you please test the dev version (1.0.5) instead. In C++ you should if in doubt only check first error message so here:
In file included from E:\McDevrim\3D Printer Ayarlar ve Programlarým\Arduino Yazýlým\Repetier Version 1.0.4\Repetier-Firmware-2022-07-08 - Bedlevel\Repetier-Firmware\Repetier\Repetier.h:735:0,
from E:\McDevrim\3D Printer Ayarlar ve Programlarým\Arduino Yazýlým\Repetier Version 1.0.4\Repetier-Firmware-2022-07-08 - Bedlevel\Repetier-Firmware\Repetier\Distortion.cpp:26:
E:\McDevrim\3D Printer Ayarlar ve Programlarým\Arduino Yazýlým\Repetier Version 1.0.4\Repetier-Firmware-2022-07-08 - Bedlevel\Repetier-Firmware\Repetier\src\SdFat\SdFat.h: In member function 'void SdFileSystem<SdDriverClass>::errorPrint()':
E:\McDevrim\3D Printer Ayarlar ve Programlarým\Arduino Yazýlým\Repetier Version 1.0.4\Repetier-Firmware-2022-07-08 - Bedlevel\Repetier-Firmware\Repetier\src\SdFat\SdFat.h:121:9: error: 'Com' has not been declared
I compiled that at least in dev version lately without issue. So it is either fixed or you have an error in your configuration.h file. You might also try with a fresh configuration.h just with basic settings like board and display to test if compilation works then. Then you know there is a difference causing the error.
Ok. I will reconfigure the software for version 1.0.5. I have a few questions here too. I am using arduino mega as card. Can I choose EEPROM_MODE = 2 on this board. Does it work. For bed leveling, I don't want it to do it again with every print. I want to do this once and save it to EEPROM and use the same data all the time. Is this possible for arduino mega and ramps 1.4?
You should define homing order like
You see you only get the error message if none of the 3 homing orders is selected in configuration.h
I copied the errors in the compiler into a text document and I'm sending you the link.
Hata txt belge link: https://yadi.sk/d/b4_Xxy99FN0mkQ
M502
M500
after start.
