Setting PID values without using the EEPROM?
I've run the PID autotune function via Repetier Host and now I want to save the calculated kp, ki, kd values on the printer, but without using the EEPROM (which is normally deactivated on my machine). Is there a way to do this with the firmware configurator?
https://share.cleanshot.com/mS7il2
you also see the macro names for config files.
