Setting PID values without using the EEPROM?
I've run the PID autotune function via Repetier Host and now I want to save the calculated kp, ki, kd values on the printer, but without using the EEPROM (which is normally deactivated on my machine). Is there a way to do this with the firmware configurator?
  • Yes, in config tool you enter the default values used if no eeprom is available and also first values for eeprom. So just put the values in extruder definition.
  • Thank you!
