Setting PID values without using the EEPROM?
I've run the PID autotune function via Repetier Host and now I want to save the calculated kp, ki, kd values on the printer, but without using the EEPROM (which is normally deactivated on my machine). Is there a way to do this with the firmware configurator?
  • Yes, in config tool you enter the default values used if no eeprom is available and also first values for eeprom. So just put the values in extruder definition.
  • Thank you!
  • hi also I don't have EEPROM active but I don't understand exactly where to insert the Pk Pd Pi values
    in configuration.h I can't find the above entries found with M303
  • In config tool here:
    https://share.cleanshot.com/mS7il2
    you also see the macro names for config files.
