FLSUN QQ-S running Repetier firmware?
I got an information that my FLSUN QQ-S printer (32 bit miniRambo board I think) came actually with Repetier firmware. Is that possible? I thought it was Marlin. Is there any easy way to check that? On the card, there were some binary files and the configuration.h file, I do not have them at hand at the moment. Thanks!
M115
you should see what it is. Also the configuration.h file would show it easily.
Edit: I actually messed up the name - it is MKS ROBIN MINI (not Rambo).
As I do not get any non Repetier related links with this function it is pretty sure that they have used Repetier when making that firmware.
It is still there in latest mks robin mini fw but that is relative old, https://github.com/makerbase-mks/MKS-Robin-mini/tree/master/mks%20firmware
Recently MKS have started beeing more open so now they make Marlin based firmwares and contribute to it also so current boards are Marlin based and fully open source.
Oh, and M115 doesn't help as they only say FIRMWARE_NAME: Robin
M115 is in deed not a good test as you can change the name there.
which settings do you use to connect the printer to the Repetier-Server?
