Random crashes after upgrade to Windows 10 AND latest 1.5
I made a mistake. I updated both the OS from Win7 to Win10 and the Repetier from 1.0.5 (I think) to 1.5.4.
Before it was nice and stable. Now I get crashes ("Repetier-host has stopped responding") at various times. Its crashing viewing the model, it randomly crashes positioning things, it randomly crashes during prints (with no one touching anything) and I do not see any pattern to the crashes.
- Should it work with Win10?
- Is there any special settings I should use (for example I DO have it running in Admin Mode- could that be an issue)?? Should I be setting a compatibility mode for running it??
- I am using a Win 8.1 Graphics Driver (Intel HD 3000) as there is not a true Win 10 driver planned for my 2nd Gen Core I5.)- should that work?
- Anything else I might be doing wrong? I do want to keep the Win 10 as Win 7 is basically EOL).
Thanks!! Kirk
I *frequently* and I mean ever other print, get issues where RH will just stop doing anything. Stops registering temp changes, wont print, wont start a print, starts but wont really start printing (does the home dance, warm up the hot end, then stops.)
All this started after I updated to 1.5.5 and windows 10.
i think I will go back to windows 8.1 anyway.
Nothing else in my setup has changed.
home,
g1 x0 y0 z0 f7000 (no problem)
then move to a tower (im using a kossel)...1 command waiting (doest move)
move to the other tower (2 commands waiting) doesnt move
emergency restart
do it again, maybe it will work maybe not.
