E-axis STEP-signal and advance algorithm
in Bug Reports
I mentioned this in another thread, but I can confirm this as a bug that is why i am re-posting the issue in this section.
Setup:
CoreXY machine
latest Repetier FW 0923
Problem:
With advance enabled, the STEP-signal of the E-axis becomes a flat line after a few layers of printing. This does NOT happen when advance is disabled and was verified several times in a row. Extrusion STEP-signal is measured using an oscilloscope throughout the entire procedure.
I look forward on your thoughts on this!
Best,
andi.
