crash detection, power panic, and runout filament sensor Prusa mk3s
Hi.
Does the prusa detect these things when connected to repetier server? crash detection, power panic, and runout filament sensor
  • crash detection is independent - it just rehomes xy and continues what I saw that correctly.
    power panic - it emits a signal that server can read and if you have recovery on in server you might be able to continue. Main probelm on reconnect is that prusa will move z a bit up, but you can correct that.
    Filament sensor was no problem as far as I remember. I think it just block communication until you have switched filament using the lcd menu.
