crash detection, power panic, and runout filament sensor Prusa mk3s
Hi.
Does the prusa detect these things when connected to repetier server? crash detection, power panic, and runout filament sensor
power panic - it emits a signal that server can read and if you have recovery on in server you might be able to continue. Main probelm on reconnect is that prusa will move z a bit up, but you can correct that.
Filament sensor was no problem as far as I remember. I think it just block communication until you have switched filament using the lcd menu.
