PB : This site can't be reached
Hello,
I had not turned on my PI3B+ for 2 weeks and I was in pro version 0.92.1 but since today when I turn my PI I fall on this page :
I have not touched any settings since the last connection, the server is connected for a few minutes then told me that it had lost the connection I saw that it was automatically changed to version 0.92.3
what should I do ? ???
Thank you for your help
Jeremy L.
Jeremy L.
If it does not help it is likely that server is not running. So login to ssh console and run
ps aux | grep tier
and see if repetier-server is running. If not start it manually
sudo service RepetierServer restart
and reload screen. If it still does not work check server log
tail -300 /var/lib/Repetier-Server/logs/server.log
for hints.
Updating 0.92.3 is not done on it self. If you have it you did at least hit the autoupdate button. Maybe there was a problem during update that broke the system, e.g. disk full? You can reinstall it manually as described in manual for first installation. Will preserve old settings.
I keep you informed in the day
Update time depends on download speed, but after you loose connection seeing upps it should be around 2 minutes until it is restarted and reconnects on a pi3. On slow sd cards maybe a bit longer.
Did it happen again? I have just run autoupdate on one of my PIs from 92.2 to 92.3 and it worked.
Tks
Jérémy
