Using Due Without EEPROM
I am using an Arduino Due with no external EEPROM to run a CNC Delta. I just have my motor drivers wired directly with no RADDS or other card.
Is there an option for simulating EEPROM so I can remember Z-Probe results after power cycling?
How would I configure that?
Thank you.
Thank you.
Would this wiring such as the RADDS uses be easy to configure support for in firmware?
