Using Due Without EEPROM
  I am using an Arduino Due with no external EEPROM to run a CNC Delta. I just have my motor drivers wired directly with no RADDS or other card.
  Is there an option for simulating EEPROM so I can remember Z-Probe results after power cycling?
  How would I configure that?
Thank you.
  • There are only 2 ways for permanent storage - EEPROM or sd card. You can wire quite easy the eeprom chip to power and I2C pins as one possible solution.
    I would like to wire in the EEPROM as my preferred solution.
    Would this wiring such as the RADDS uses be easy to configure support for in firmware?
  • Yes, you see it in pins.h for board 402 on what to add to your board/config to make it use the eeprom. So if you wire exactly as on radds schematics all you need is the settings from radds board definition for eeprom - meaning address and eeprom type.
  • edited June 2019
    G
    Great, thank you for the quick answer.
