Mirrored Extruder spins with Z on Home and Raise
Hi, I run two extruders to double my output using a RamBo board. When first connecting, (when up to temp) and I extrude, only #0 spins. Once I start a print, the #1 extruder spins and continues to mirror until disconnected. The same with manually heating, I need to click both extruders on startup but after a print is started, the control mirrors. Both of those I can deal with but my real problem is that when I home the Z, the #1 (mirrored) extruder spins in retraction direction When raising Z, it extrudes. The only thing I can't have is the retraction. It pulls hot plastic up and clogs. (I use pellet extruders and the pellets form a ring new pellets can't get past). Is there any way to disconnect Z from #1?
Your description is not clear. You always say mirror but talk as if you have 2 extruders. Now we have motor mirroring which is for 1 extruder with 2 motors. Then we have ditto printing meant to copy temperatures/extrusions to a second extruder. This only happens of course after enabling the ditto mode, so at startup only extruder 0 will react until you turn on ditto mode. So which of both are you using here.
Here's a part of config.h that may help explain.
I think it's mirror although under the DELTA section:
#define FEATURE_DITTO_PRINTING 1
That's the only place I see Ditto. Are the two conflicting?
If so, which should I change to get what I want?
define DRIVE_SYSTEM 0
#define XAXIS_STEPS_PER_MM 64.24
#define YAXIS_STEPS_PER_MM 64.24
#define ZAXIS_STEPS_PER_MM 631.56
#define PDM_FOR_EXTRUDER 0
#define PDM_FOR_COOLER 0
#define RETRACT_ON_PAUSE 2
#define PAUSE_END_COMMANDS ""
#define EXT0_X_OFFSET 0
#define EXT0_Y_OFFSET 0
#define EXT0_Z_OFFSET 0
#define EXT0_STEPS_PER_MM 370
#define EXT0_INVERSE 0
#define EXT0_ENABLE_ON 0
#define EXT0_MIRROR_STEPPER 1
#define EXT0_INVERSE2 0
#define EXT0_MAX_FEEDRATE 40
#define EXT0_MAX_ACCELERATION 3000
#define EXT0_HEAT_MANAGER 3
#define EXT0_PREHEAT_TEMP 230
#define EXT0_WATCHPERIOD 1
#define EXT0_PID_I 2
#define EXT0_PID_D 40
#define EXT0_PID_MAX 255
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define EXT0_DECOUPLE_TEST_PERIOD 24000
#define EXT0_JAM_PIN -1
#define EXT0_JAM_PULLUP 0
#define EXT1_X_OFFSET 0
#define EXT1_Y_OFFSET 0
#define EXT1_Z_OFFSET 0
#define EXT1_STEPS_PER_MM 370
#define EXT1_TEMPSENSOR_TYPE 1
#define EXT1_INVERSE 0
#define EXT1_ENABLE_ON 0
#define EXT1_MIRROR_STEPPER 1
#define EXT1_STEP2_PIN ORIG_E0_STEP_PIN
#define EXT1_DIR2_PIN ORIG_E0_DIR_PIN
#define EXT1_INVERSE2 0
#define EXT1_ENABLE2_PIN ORIG_E0_ENABLE_PIN
#define EXT1_MAX_FEEDRATE 40
#define EXT1_MAX_ACCELERATION 3000
#define EXT1_HEAT_MANAGER 3
#define EXT1_PREHEAT_TEMP 230
#define EXT1_WATCHPERIOD 1
#define EXT1_PID_I 2
#define EXT1_PID_D 40
#define EXT1_PID_MAX 255
#define EXT1_ADVANCE_K 0
#define EXT1_ADVANCE_L 0
#define EXT1_DECOUPLE_TEST_PERIOD 24000
#define EXT1_JAM_PIN -1
#define EXT1_JAM_PULLUP 0
https://wp.me/P4oYKc-eY
while E1 mirrors to E0 so that is why E1 is not moving when you start with E0.Could it be that you also mirrored Z axis - it uses normally E1 extruder I think so would explain why it moves during Z moves.
Not sure why you do that - is E1 the pellet extruder?
When you fix the E0->E0 mapping which makes E0 move twice as fast instead of M1 it should work. Especially if I'm right that you mirror z axis as well.
Is this what you expect the code to be?
now:
change to:
#define EXT0_STEP2_PIN ORIG_E1_STEP_PIN
#define EXT0_DIR2_PIN ORIG_E1_DIR_PIN
#define EXT0_INVERSE2 1
#define EXT0_ENABLE2_PIN ORIG_E1_ENABLE_PIN
Thank you for your help and patience.
So you only need to check now if z axis is also mirrored to E0 or E1.
changed to
Now, should
#define FEATURE_DITTO_PRINTING be 1 OR 0 ? Right now it is 1
The only difference is that the E1 turns when prompted before running a print, before it wouldn't until printing.
E1 is still connected to Z and always goes retraction direction when Homing or Raising Z.
It turns the correct direction when printing.
I'd be OK with it if it just would never go retraction - ever. I don't need it.
Here's all Config h.
along with Repetier-Firmware. If not, see <http://www.gnu.org/licenses/>.
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
This file is optimized for version 1.0.3
as you expect.
#define NUM_EXTRUDER 2
#define MOTHERBOARD 301
#include "pins.h"
// Microstepping mode of your RAMBO board
#define MICROSTEP_MODES { 8,8,8,8,8 } // [1,2,4,8,16]
// Motor Current setting (Only functional when motor driver current ref pins are connected to a digital trimpot on supported boards)
#define MOTOR_CURRENT_PERCENT { 55,55,50,60,60 }
#undef FAN_BOARD_PIN
#define FAN_BOARD_PIN -1
#define BOARD_FAN_SPEED 255
#define BOARD_FAN_MIN_SPEED 0
#define FAN_THERMO_PIN -1
//#define COMPAT_PRE1
#define BLUETOOTH_SERIAL -1
#define BLUETOOTH_BAUD 115200
#define MIXING_EXTRUDER 0
#define DRIVE_SYSTEM 0
#define FEATURE_RETRACTION 1
#define AUTORETRACT_ENABLED 0
#define RETRACTION_LENGTH 3
#define RETRACTION_SPEED 40
#define RETRACTION_Z_LIFT 0
#define JAM_METHOD 1
#define JAM_STEPS 220
#define JAM_SLOWDOWN_TO 70
#define JAM_ERROR_STEPS 500
#define JAM_MIN_STEPS 10
#define JAM_ACTION 1
#define PID_CONTROL_RANGE 20
#define SKIP_M109_IF_WITHIN 2
#define SCALE_PID_TO_MAX 0
#define TEMP_HYSTERESIS 2
#define EXTRUDE_MAXLENGTH 160
#define GENERIC_THERM_VREF 5
#define HEATER_PWM_SPEED 0
#define COOLER_PWM_SPEED 0
#define HAVE_HEATED_BED 1
#define HEATED_BED_PREHEAT_TEMP 75
#define HEATED_BED_MAX_TEMP 135
#define SKIP_M190_IF_WITHIN 3
#define MIN_EXTRUDER_TEMP 180
#define MAXTEMP 275
// ## Laser configuration ##
automatically disabled.
#define SUPPORT_LASER 0
#define LASER_PIN -1
#define LASER_ON_HIGH 1
#define LASER_WARMUP_TIME 0
#define LASER_PWM_MAX 255
#define LASER_WATT 2
// ## CNC configuration ##
#define SUPPORT_CNC 0
#define CNC_WAIT_ON_DISABLE 0
#define CNC_ENABLE_PIN -1
#define CNC_ENABLE_WITH 1
#define CNC_DIRECTION_PIN -1
#define CNC_DIRECTION_CW 1
#define CNC_PWM_MAX 255
#define CNC_RPM_MAX 8000
#define CNC_SAFE_Z 150
#define X2_MIN_PIN -1
#define X2_MAX_PIN -1
#define Y2_MIN_PIN -1
#define Y2_MAX_PIN -1
#define Z2_MINMAX_PIN -1
#define DOOR_PIN -1
#define DOOR_PULLUP 1
#define DOOR_INVERTING 1
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 2
#define MOVE_X_WHEN_HOMED 1
#define MOVE_Y_WHEN_HOMED 1
#define MOVE_Z_WHEN_HOMED 1
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 0
#define INVERT_X2_DIR 0
#define INVERT_Y_DIR 0
#define INVERT_Y2_DIR 0
#define INVERT_Z_DIR 0
#define INVERT_Z2_DIR 0
#define INVERT_Z3_DIR 0
#define INVERT_Z4_DIR 0
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define X_MAX_LENGTH 324
#define Y_MAX_LENGTH 195
#define Z_MAX_LENGTH 420
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define PARK_POSITION_X 0
#define PARK_POSITION_Y 5
#define PARK_POSITION_Z_RAISE 5
#define DISTORTION_LIMIT_TO 2
#define DISTORTION_XMIN 10
#define DISTORTION_YMIN 10
#define DISTORTION_XMAX 190
#define DISTORTION_YMAX 190
// ## Movement settings ##
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_HOME_ON_POWER 0
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 400
#define MAX_FEEDRATE_Y 400
#define MAX_FEEDRATE_Z 10
#define HOMING_FEEDRATE_X 50
#define HOMING_FEEDRATE_Y 50
#define HOMING_FEEDRATE_Z 0.05
#define HOMING_ORDER HOME_ORDER_YXZ
#define ZHOME_PRE_RAISE 0
#define ZHOME_PRE_RAISE_DISTANCE 5
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 5
#define ZHOME_X_POS 999999
#define ZHOME_Y_POS 999999
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 0
#define DIRECTION_DELAY 0
#define ALLOW_QUADSTEPPING 1
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 50
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 50
#define MAX_JERK 20
#define MAX_ZJERK 0.3
#define MOVE_CACHE_LOW 10
#define DUAL_X_AXIS 0
#define DUAL_X_RESOLUTION 0
#define FEATURE_TWO_ZSTEPPER 1
#define Z4_STEP_PIN ORIG_E3_STEP_PIN
#define Z4_DIR_PIN ORIG_E3_DIR_PIN
#define USE_ADVANCE 0
#define BAUDRATE 250000
#define POWER_INVERTING 0
#define AUTOMATIC_POWERUP 0
#define KILL_METHOD 1
#define ACK_WITH_LINENUMBER 1
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 1
#undef PS_ON_PIN
#define JSON_OUTPUT 0
/* ======== Servos =======
Control the servos with
#define FEATURE_SERVO 0
#define SERVO0_PIN 11
#define SERVO1_PIN -1
#define SERVO2_PIN -1
#define SERVO3_PIN -1
#define SERVO0_NEUTRAL_POS -1
#define SERVO1_NEUTRAL_POS -1
#define SERVO2_NEUTRAL_POS -1
#define SERVO3_NEUTRAL_POS -1
#define UI_SERVO_CONTROL 0
#define MAX_FAN_PWM 255
#define FEATURE_WATCHDOG 1
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 1
#define FEATURE_Z_PROBE 0
#define EXTRUDER_IS_Z_PROBE 0
#define Z_PROBE_PIN -1
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_REPETITIONS 1
#define Z_PROBE_USE_MEDIAN 0
#define Z_PROBE_HEIGHT 40
#define Z_PROBE_DELAY 0
#define FEATURE_AUTOLEVEL 0
#define Z_PROBE_X1 20
#define Z_PROBE_Y1 20
#define Z_PROBE_X2 160
#define Z_PROBE_Y2 20
#define Z_PROBE_X3 20
#define Z_PROBE_Y3 160
#define BED_LEVELING_METHOD 0
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
#define SDSUPPORT 0
#undef SDCARDDETECT
#define SDCARDDETECT -1
#undef SDCARDDETECTINVERTED
#endif
#define SD_RUN_ON_STOP ""
#define ARC_SUPPORT 1
#define FEATURE_FAN_CONTROL 1
#define FEATURE_FAN2_CONTROL 1
#define FEATURE_CONTROLLER 0
#define ADC_KEYPAD_PIN -1
#define LANGUAGE_EN_ACTIVE 1
#define LANGUAGE_DE_ACTIVE 1
#define LANGUAGE_NL_ACTIVE 0
#define LANGUAGE_PT_ACTIVE 1
#define LANGUAGE_IT_ACTIVE 1
#define LANGUAGE_ES_ACTIVE 1
#define LANGUAGE_FI_ACTIVE 0
#define LANGUAGE_SE_ACTIVE 0
#define LANGUAGE_FR_ACTIVE 1
#define LANGUAGE_CZ_ACTIVE 0
#define LANGUAGE_PL_ACTIVE 1
#define LANGUAGE_TR_ACTIVE 1
#define FEATURE_UI_KEYS 0
#define UI_ENCODER_SPEED 1
#define UI_REVERSE_ENCODER 0
#define UI_KEY_BOUNCETIME 10
#define UI_KEY_MIN_REPEAT 50
#define FEATURE_BEEPER 0
#define CASE_LIGHTS_PIN -1
#define UI_SET_MAX_EXTRUDER_TEMP 260
#define NUM_MOTOR_DRIVERS 0
#endif
Here is also why z moves also extrudes:
You said you have 2 z axis and second z axis is E1.
will solve the extruder move problem.
I finally changed the #define FEATURE_TWO_ZSTEPPER 0 and the Z is decoupled (yay).
Thanks again for the help.
