Mirrored Extruder spins with Z on Home and Raise
Hi, I run two extruders to double my output using a RamBo board. When first connecting, (when up to temp) and I extrude, only #0 spins. Once I start a print, the #1 extruder spins and continues to mirror until disconnected. The same with manually heating, I need to click both extruders on startup but after a print is started, the control mirrors. Both of those I can deal with but my real problem is that when I home the Z, the #1 (mirrored) extruder spins in retraction direction When raising Z, it extrudes. The only thing I can't have is the retraction. It pulls hot plastic up and clogs. (I use pellet extruders and the pellets form a ring new pellets can't get past). Is there any way to disconnect Z from #1?
  • First z moves should not move extruder. For me it never happened, also I had some users claiming it did. Never found out if they had a hardware/config failure or if it was something different. This error seems to go away often when using a newer firmware version. So first I'd try using dev version.
    Your description is not clear. You always say mirror but talk as if you have 2 extruders. Now we have motor mirroring which is for 1 extruder with 2 motors. Then we have ditto printing meant to copy temperatures/extrusions to a second extruder. This only happens of course after enabling the ditto mode, so at startup only extruder 0 will react until you turn on ditto mode. So which of both are you using here.
  • I have two motors, each running it's own extruder and they both need to do the same thing always.
    Here's a part of config.h that may help explain.
    I think it's mirror although under the DELTA section:
    #define FEATURE_DITTO_PRINTING 1
    That's the only place I see Ditto. Are the two conflicting?
    If so, which should I change to get what I want?
    define DRIVE_SYSTEM 0
    #define XAXIS_STEPS_PER_MM 64.24
    #define YAXIS_STEPS_PER_MM 64.24
    #define ZAXIS_STEPS_PER_MM 631.56
    #define PDM_FOR_EXTRUDER 0
    #define PDM_FOR_COOLER 0
    #define RETRACT_ON_PAUSE 2
    #define PAUSE_END_COMMANDS ""
    #define EXT0_X_OFFSET 0
    #define EXT0_Y_OFFSET 0
    #define EXT0_Z_OFFSET 0
    #define EXT0_STEPS_PER_MM 370
    #define EXT0_INVERSE 0
    #define EXT0_ENABLE_ON 0
    #define EXT0_MIRROR_STEPPER 1
    #define EXT0_INVERSE2 0
    #define EXT0_MAX_FEEDRATE 40
    #define EXT0_MAX_ACCELERATION 3000
    #define EXT0_HEAT_MANAGER 3
    #define EXT0_PREHEAT_TEMP 230
    #define EXT0_WATCHPERIOD 1
    #define EXT0_PID_I 2
    #define EXT0_PID_D 40
    #define EXT0_PID_MAX 255
    #define EXT0_ADVANCE_K 0
    #define EXT0_ADVANCE_L 0
    #define EXT0_DECOUPLE_TEST_PERIOD 24000
    #define EXT0_JAM_PIN -1
    #define EXT0_JAM_PULLUP 0
    #define EXT1_X_OFFSET 0
    #define EXT1_Y_OFFSET 0
    #define EXT1_Z_OFFSET 0
    #define EXT1_STEPS_PER_MM 370
    #define EXT1_TEMPSENSOR_TYPE 1
    #define EXT1_INVERSE 0
    #define EXT1_ENABLE_ON 0
    #define EXT1_MIRROR_STEPPER 1
    #define EXT1_STEP2_PIN ORIG_E0_STEP_PIN
    #define EXT1_DIR2_PIN ORIG_E0_DIR_PIN
    #define EXT1_INVERSE2 0
    #define EXT1_ENABLE2_PIN ORIG_E0_ENABLE_PIN
    #define EXT1_MAX_FEEDRATE 40
    #define EXT1_MAX_ACCELERATION 3000
    #define EXT1_HEAT_MANAGER 3
    #define EXT1_PREHEAT_TEMP 230
    #define EXT1_WATCHPERIOD 1
    #define EXT1_PID_I 2
    #define EXT1_PID_D 40
    #define EXT1_PID_MAX 255
    #define EXT1_ADVANCE_K 0
    #define EXT1_ADVANCE_L 0
    #define EXT1_DECOUPLE_TEST_PERIOD 24000
    #define EXT1_JAM_PIN -1
    #define EXT1_JAM_PULLUP 0
  • Here's a video, the machine is up to temp #1 moves with the Homing of Z and #0 does not move. Sound is LOUD!
    https://wp.me/P4oYKc-eY
  • E0 mirrors to it self
    while E1 mirrors to E0 so that is why E1 is not moving when you start with E0.
    Could it be that you also mirrored Z axis - it uses normally E1 extruder I think so would explain why it moves during Z moves.
    Not sure why you do that - is E1 the pellet extruder?
    When you fix the E0->E0 mapping which makes E0 move twice as fast instead of M1 it should work. Especially if I'm right that you mirror z axis as well.
  • I'm not that smart to know, I stmuble through hoping to get things to work.
    Is this what you expect the code to be?
    now:
    change to:
    #define EXT0_STEP2_PIN ORIG_E1_STEP_PIN
    #define EXT0_DIR2_PIN ORIG_E1_DIR_PIN
    #define EXT0_INVERSE2 1
    #define EXT0_ENABLE2_PIN ORIG_E1_ENABLE_PIN
    Thank you for your help and patience.
  • Yes that was the E0->E0 mirror fixed to E0->E1.
    So you only need to check now if z axis is also mirrored to E0 or E1.
  • #define FEATURE_TWO_ZSTEPPER 1
    changed to
    Now, should
    #define FEATURE_DITTO_PRINTING      be 1 OR 0  ? Right now it is 1
  • Aaarg. I made the changes, uploaded OK. Cut power, pulled the USB and restarted.
    The only difference is that the E1 turns when prompted before running a print, before it wouldn't until printing.
    E1 is still connected to Z and always goes retraction direction when Homing or Raising Z.
    It turns the correct direction when printing.
    I'd be OK with it if it just would never go retraction - ever. I don't need it.
    Here's all Config h.
    along with Repetier-Firmware. If not, see <http://www.gnu.org/licenses/>.
    #ifndef CONFIGURATION_H
    #define CONFIGURATION_H
    This file is optimized for version 1.0.3
    as you expect.
    #define NUM_EXTRUDER 2
    #define MOTHERBOARD 301
    #include "pins.h"
    // Microstepping mode of your RAMBO board
    #define MICROSTEP_MODES { 8,8,8,8,8 } // [1,2,4,8,16]
    // Motor Current setting (Only functional when motor driver current ref pins are connected to a digital trimpot on supported boards)
    #define MOTOR_CURRENT_PERCENT { 55,55,50,60,60 }
    #undef FAN_BOARD_PIN
    #define FAN_BOARD_PIN -1
    #define BOARD_FAN_SPEED 255
    #define BOARD_FAN_MIN_SPEED 0
    #define FAN_THERMO_PIN -1
    //#define COMPAT_PRE1
    #define BLUETOOTH_SERIAL -1
    #define BLUETOOTH_BAUD 115200
    #define MIXING_EXTRUDER 0
    #define DRIVE_SYSTEM 0
    #define FEATURE_RETRACTION 1
    #define AUTORETRACT_ENABLED 0
    #define RETRACTION_LENGTH 3
    #define RETRACTION_SPEED 40
    #define RETRACTION_Z_LIFT 0
    #define JAM_METHOD 1
    #define JAM_STEPS 220
    #define JAM_SLOWDOWN_TO 70
    #define JAM_ERROR_STEPS 500
    #define JAM_MIN_STEPS 10
    #define JAM_ACTION 1
    #define PID_CONTROL_RANGE 20
    #define SKIP_M109_IF_WITHIN 2
    #define SCALE_PID_TO_MAX 0
    #define TEMP_HYSTERESIS 2
    #define EXTRUDE_MAXLENGTH 160
    #define GENERIC_THERM_VREF 5
    #define HEATER_PWM_SPEED 0
    #define COOLER_PWM_SPEED 0
    #define HAVE_HEATED_BED 1
    #define HEATED_BED_PREHEAT_TEMP 75
    #define HEATED_BED_MAX_TEMP 135
    #define SKIP_M190_IF_WITHIN 3
    #define MIN_EXTRUDER_TEMP 180
    #define MAXTEMP 275
    // ## Laser configuration ##
    automatically disabled.
    #define SUPPORT_LASER 0
    #define LASER_PIN -1
    #define LASER_ON_HIGH 1
    #define LASER_WARMUP_TIME 0
    #define LASER_PWM_MAX 255
    #define LASER_WATT 2
    // ## CNC configuration ##
    #define SUPPORT_CNC 0
    #define CNC_WAIT_ON_DISABLE 0
    #define CNC_ENABLE_PIN -1
    #define CNC_ENABLE_WITH 1
    #define CNC_DIRECTION_PIN -1
    #define CNC_DIRECTION_CW 1
    #define CNC_PWM_MAX 255
    #define CNC_RPM_MAX 8000
    #define CNC_SAFE_Z 150
    #define X2_MIN_PIN -1
    #define X2_MAX_PIN -1
    #define Y2_MIN_PIN -1
    #define Y2_MAX_PIN -1
    #define Z2_MINMAX_PIN -1
    #define DOOR_PIN -1
    #define DOOR_PULLUP 1
    #define DOOR_INVERTING 1
    #define ENDSTOP_X_BACK_MOVE 5
    #define ENDSTOP_Y_BACK_MOVE 5
    #define ENDSTOP_Z_BACK_MOVE 2
    #define MOVE_X_WHEN_HOMED 1
    #define MOVE_Y_WHEN_HOMED 1
    #define MOVE_Z_WHEN_HOMED 1
    #define X_ENABLE_ON 0
    #define Y_ENABLE_ON 0
    #define Z_ENABLE_ON 0
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define INVERT_X_DIR 0
    #define INVERT_X2_DIR 0
    #define INVERT_Y_DIR 0
    #define INVERT_Y2_DIR 0
    #define INVERT_Z_DIR 0
    #define INVERT_Z2_DIR 0
    #define INVERT_Z3_DIR 0
    #define INVERT_Z4_DIR 0
    #define X_HOME_DIR -1
    #define Y_HOME_DIR -1
    #define Z_HOME_DIR -1
    #define X_MAX_LENGTH 324
    #define Y_MAX_LENGTH 195
    #define Z_MAX_LENGTH 420
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    #define PARK_POSITION_X 0
    #define PARK_POSITION_Y 5
    #define PARK_POSITION_Z_RAISE 5
    #define DISTORTION_LIMIT_TO 2
    #define DISTORTION_XMIN 10
    #define DISTORTION_YMIN 10
    #define DISTORTION_XMAX 190
    #define DISTORTION_YMAX 190
    // ## Movement settings ##
    #define EXACT_DELTA_MOVES 1
    // Delta settings
    #define DELTA_HOME_ON_POWER 0
    #define MAX_INACTIVE_TIME 0L
    #define MAX_FEEDRATE_X 400
    #define MAX_FEEDRATE_Y 400
    #define MAX_FEEDRATE_Z 10
    #define HOMING_FEEDRATE_X 50
    #define HOMING_FEEDRATE_Y 50
    #define HOMING_FEEDRATE_Z 0.05
    #define HOMING_ORDER HOME_ORDER_YXZ
    #define ZHOME_PRE_RAISE 0
    #define ZHOME_PRE_RAISE_DISTANCE 5
    #define ZHOME_HEAT_ALL 1
    #define ZHOME_HEAT_HEIGHT 5
    #define ZHOME_X_POS 999999
    #define ZHOME_Y_POS 999999
    #define X_BACKLASH 0
    #define Y_BACKLASH 0
    #define Z_BACKLASH 0
    #define RAMP_ACCELERATION 1
    #define STEPPER_HIGH_DELAY 0
    #define DIRECTION_DELAY 0
    #define ALLOW_QUADSTEPPING 1
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 50
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 50
    #define MAX_JERK 20
    #define MAX_ZJERK 0.3
    #define MOVE_CACHE_LOW 10
    #define DUAL_X_AXIS 0
    #define DUAL_X_RESOLUTION 0
    #define Z4_STEP_PIN ORIG_E3_STEP_PIN
    #define Z4_DIR_PIN ORIG_E3_DIR_PIN
    #define USE_ADVANCE 0
    #define BAUDRATE 250000
    #define POWER_INVERTING 0
    #define AUTOMATIC_POWERUP 0
    #define KILL_METHOD 1
    #define ACK_WITH_LINENUMBER 1
    #define ECHO_ON_EXECUTE 1
    #define EEPROM_MODE 1
    #undef PS_ON_PIN
    #define JSON_OUTPUT 0
    /* ======== Servos =======
    Control the servos with
    #define FEATURE_SERVO 0
    #define SERVO0_PIN 11
    #define SERVO1_PIN -1
    #define SERVO2_PIN -1
    #define SERVO3_PIN -1
    #define SERVO0_NEUTRAL_POS -1
    #define SERVO1_NEUTRAL_POS -1
    #define SERVO2_NEUTRAL_POS -1
    #define SERVO3_NEUTRAL_POS -1
    #define UI_SERVO_CONTROL 0
    #define MAX_FAN_PWM 255
    #define FEATURE_WATCHDOG 1
    #define Z_PROBE_Z_OFFSET 0
    #define UI_BED_COATING 1
    #define FEATURE_Z_PROBE 0
    #define EXTRUDER_IS_Z_PROBE 0
    #define Z_PROBE_PIN -1
    #define Z_PROBE_PULLUP 0
    #define Z_PROBE_ON_HIGH 0
    #define Z_PROBE_X_OFFSET 0
    #define Z_PROBE_Y_OFFSET 0
    #define Z_PROBE_SPEED 2
    #define Z_PROBE_XY_SPEED 150
    #define Z_PROBE_REPETITIONS 1
    #define Z_PROBE_USE_MEDIAN 0
    #define Z_PROBE_HEIGHT 40
    #define Z_PROBE_DELAY 0
    #define FEATURE_AUTOLEVEL 0
    #define Z_PROBE_X1 20
    #define Z_PROBE_Y1 20
    #define Z_PROBE_X2 160
    #define Z_PROBE_Y2 20
    #define Z_PROBE_X3 20
    #define Z_PROBE_Y3 160
    #define BED_LEVELING_METHOD 0
    #define BED_MOTOR_1_X 0
    #define BED_MOTOR_1_Y 0
    #define BED_MOTOR_2_X 200
    #define BED_MOTOR_2_Y 0
    #define BED_MOTOR_3_X 100
    #define BED_MOTOR_3_Y 200
    #define FEATURE_AXISCOMP 0
    #define AXISCOMP_TANXY 0
    #define AXISCOMP_TANYZ 0
    #define AXISCOMP_TANXZ 0
    #define SDSUPPORT 0
    #undef SDCARDDETECT
    #define SDCARDDETECT -1
    #undef SDCARDDETECTINVERTED
    #endif
    #define SD_RUN_ON_STOP ""
    #define ARC_SUPPORT 1
    #define FEATURE_FAN_CONTROL 1
    #define FEATURE_FAN2_CONTROL 1
    #define FEATURE_CONTROLLER 0
    #define ADC_KEYPAD_PIN -1
    #define LANGUAGE_EN_ACTIVE 1
    #define LANGUAGE_DE_ACTIVE 1
    #define LANGUAGE_NL_ACTIVE 0
    #define LANGUAGE_PT_ACTIVE 1
    #define LANGUAGE_IT_ACTIVE 1
    #define LANGUAGE_ES_ACTIVE 1
    #define LANGUAGE_FI_ACTIVE 0
    #define LANGUAGE_SE_ACTIVE 0
    #define LANGUAGE_FR_ACTIVE 1
    #define LANGUAGE_CZ_ACTIVE 0
    #define LANGUAGE_PL_ACTIVE 1
    #define LANGUAGE_TR_ACTIVE 1
    #define FEATURE_UI_KEYS 0
    #define UI_ENCODER_SPEED 1
    #define UI_REVERSE_ENCODER 0
    #define UI_KEY_BOUNCETIME 10
    #define UI_KEY_MIN_REPEAT 50
    #define FEATURE_BEEPER 0
    #define CASE_LIGHTS_PIN -1
    #define UI_SET_MAX_EXTRUDER_TEMP 260
    #define NUM_MOTOR_DRIVERS 0
    #endif
  • Ditto mod eis not allowed. You already have configured it for permanent mirroring. Ditto mode is the alternative if you do not mirror E0->E1 and E1->E0. With that you could select if you want only one or both extruders.
    Here is also why z moves also extrudes:
    You said you have 2 z axis and second z axis is E1.
    will solve the extruder move problem.
  • Seems that putting the code into the documentation isn't the same as changing the code. (:~)
    I finally changed the #define FEATURE_TWO_ZSTEPPER 0 and the Z is decoupled (yay).
    Thanks again for the help.
