Problem with Z max Home
Hi everybody !
I made a DIY CNC milling machine and i would like that Z axis homes to Z-Max, but he doesn't work.
Wen i ask a Z homing (G28 Z), Z goes down of 2/3mm and stops instead go up until the Z-max enstop.
I have 4 endstops on my machine, X-, Y-,Z-,Z+. X and Y min homing works perfectly.
I set Z_HOME_DIR 1
M119 is ok : X- L, Y- L, Z- L, Z+ L when they are not triggered.
On Repetier host, when i hit Home Z, Z goes down of 2/3mm and stops, and the console says me " X 0, Y 0, Z 80"
(80 is the Z-max length on my CNC)
Thank you for your help, i'm looking for a solution for 4 days, that make me crazy !
Romain
#define SUPPORT_CNC 1
#define CNC_WAIT_ON_DISABLE 0
#define CNC_ENABLE_PIN ORIG_FAN_PIN
#define CNC_ENABLE_WITH 1
#define CNC_DIRECTION_PIN -1
#define CNC_DIRECTION_CW 1
#define CNC_PWM_MAX 255
#define CNC_RPM_MAX 8000
#define CNC_SAFE_Z 100
#define DEFAULT_PRINTER_MODE 2
#define ENDSTOP_Z_MAX_INVERTING true
#define X2_MIN_PIN -1
#define X2_MAX_PIN -1
#define Y2_MIN_PIN -1
#define Y2_MAX_PIN -1
#define Z2_MINMAX_PIN -1
#define DOOR_PIN -1
#define DOOR_PULLUP 1
#define DOOR_INVERTING 0
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 2
#define ENDSTOP_X_BACK_ON_HOME 0
#define ENDSTOP_Y_BACK_ON_HOME 0
#define MOVE_X_WHEN_HOMED 0
#define MOVE_Y_WHEN_HOMED 0
#define MOVE_Z_WHEN_HOMED 0
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 1
#define INVERT_X2_DIR 0
#define INVERT_Y_DIR 1
#define INVERT_Y2_DIR 0
#define INVERT_Z_DIR 0
#define INVERT_Z2_DIR 0
#define INVERT_Z3_DIR 0
#define INVERT_Z4_DIR 0
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR 1
#define X_MAX_LENGTH 1000
#define Y_MAX_LENGTH 1000
#define Z_MAX_LENGTH 80
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define PARK_POSITION_X 0
#define PARK_POSITION_Y 10
#define DISTORTION_LIMIT_TO 2
#define DISTORTION_XMIN 10
#define DISTORTION_YMIN 10
#define DISTORTION_XMAX 190
#define DISTORTION_YMAX 190
// ## Movement settings ##
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_HOME_ON_POWER 0
#define STEPPER_INACTIVE_TIME 1000L
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 180
#define MAX_FEEDRATE_Y 180
#define MAX_FEEDRATE_Z 5
#define HOMING_FEEDRATE_X 100
#define HOMING_FEEDRATE_Y 100
#define HOMING_FEEDRATE_Z 5
#define ZHOME_PRE_RAISE 0
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 999999
#define ZHOME_Y_POS 999999
#define X_BACKLASH 0.05
#define Y_BACKLASH 0.05
#define Z_BACKLASH 0.03
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 0
#define DIRECTION_DELAY 0
#define ALLOW_QUADSTEPPING 1
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 100
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 100
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 20
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 150
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 150
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 30
#define MAX_JERK 4
#define MAX_ZJERK 0.4
#define MOVE_CACHE_LOW 10
#define DUAL_X_AXIS 0
#define DUAL_X_RESOLUTION 0
#define Z4_STEP_PIN ORIG_E3_STEP_PIN
#define Z4_DIR_PIN ORIG_E3_DIR_PIN
#define USE_ADVANCE 0
#define BAUDRATE 250000
#define POWER_INVERTING 0
#define AUTOMATIC_POWERUP 0
#define KILL_METHOD 1
#define ACK_WITH_LINENUMBER 1
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 0
#undef PS_ON_PIN
#define JSON_OUTPUT 0
