Problem with Z max Home
Hi everybody !
I made a DIY CNC milling machine and i would like that Z axis homes to Z-Max, but he doesn't work.
Wen i ask a Z homing (G28 Z), Z goes down of 2/3mm and stops instead go up until the Z-max enstop.
I have 4 endstops on my machine, X-, Y-,Z-,Z+. X and Y min homing works perfectly.
I set Z_HOME_DIR 1
M119 is ok : X- L, Y- L, Z- L, Z+ L when they are not triggered.
On Repetier host, when i hit Home Z, Z goes down of 2/3mm and stops, and the console says me " X 0, Y 0, Z 80"
(80 is the Z-max length on my CNC)
Thank you for your help, i'm looking for a solution for 4 days, that make me crazy !
Romain
  • What direction do you get if you move z up after connection? Home dir and endstops look good, but maybe z direction it self is set wrong, so you need to invert z axis in config. That it only goes 2-3mm might be a bad steps per mm setting, see eeprom values set.
  • edited May 2018
    Hi Repetier ! Thank you for your reply, My Z direction is ok, when i click on the up arrow on Repetier Host, Z goes up, when i click on the down arrow, Z goes down !
    The CNC job is ok, my only issue is the Z home direction :(
  • // ##                              CNC configuration                                       ##
    #define SUPPORT_CNC 1
    #define CNC_WAIT_ON_DISABLE 0
    #define CNC_ENABLE_PIN ORIG_FAN_PIN
    #define CNC_ENABLE_WITH 1
    #define CNC_DIRECTION_PIN -1
    #define CNC_DIRECTION_CW 1
    #define CNC_PWM_MAX 255
    #define CNC_RPM_MAX 8000
    #define CNC_SAFE_Z 100
    #define DEFAULT_PRINTER_MODE 2
    #define ENDSTOP_Z_MAX_INVERTING true
    #define X2_MIN_PIN -1
    #define X2_MAX_PIN -1
    #define Y2_MIN_PIN -1
    #define Y2_MAX_PIN -1
    #define Z2_MINMAX_PIN -1
    #define DOOR_PIN -1
    #define DOOR_PULLUP 1
    #define DOOR_INVERTING 0
    #define ENDSTOP_X_BACK_MOVE 5
    #define ENDSTOP_Y_BACK_MOVE 5
    #define ENDSTOP_Z_BACK_MOVE 2
    #define ENDSTOP_X_BACK_ON_HOME 0
    #define ENDSTOP_Y_BACK_ON_HOME 0
    #define MOVE_X_WHEN_HOMED 0
    #define MOVE_Y_WHEN_HOMED 0
    #define MOVE_Z_WHEN_HOMED 0
    #define X_ENABLE_ON 0
    #define Y_ENABLE_ON 0
    #define Z_ENABLE_ON 0
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define INVERT_X_DIR 1
    #define INVERT_X2_DIR 0
    #define INVERT_Y_DIR 1
    #define INVERT_Y2_DIR 0
    #define INVERT_Z_DIR 0
    #define INVERT_Z2_DIR 0
    #define INVERT_Z3_DIR 0
    #define INVERT_Z4_DIR 0
    #define X_HOME_DIR -1
    #define Y_HOME_DIR -1
    #define Z_HOME_DIR 1
    #define X_MAX_LENGTH 1000
    #define Y_MAX_LENGTH 1000
    #define Z_MAX_LENGTH 80
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    #define PARK_POSITION_X 0
    #define PARK_POSITION_Y 10
    #define DISTORTION_LIMIT_TO 2
    #define DISTORTION_XMIN 10
    #define DISTORTION_YMIN 10
    #define DISTORTION_XMAX 190
    #define DISTORTION_YMAX 190
    // ##                           Movement settings                                          ##
    #define EXACT_DELTA_MOVES 1
    // Delta settings
    #define DELTA_HOME_ON_POWER 0
    #define STEPPER_INACTIVE_TIME 1000L
    #define MAX_INACTIVE_TIME 0L
    #define MAX_FEEDRATE_X 180
    #define MAX_FEEDRATE_Y 180
    #define MAX_FEEDRATE_Z 5
    #define HOMING_FEEDRATE_X 100
    #define HOMING_FEEDRATE_Y 100
    #define HOMING_FEEDRATE_Z 5
    #define ZHOME_PRE_RAISE 0
    #define ZHOME_HEAT_ALL 1
    #define ZHOME_HEAT_HEIGHT 20
    #define ZHOME_X_POS 999999
    #define ZHOME_Y_POS 999999
    #define X_BACKLASH 0.05
    #define Y_BACKLASH 0.05
    #define Z_BACKLASH 0.03
    #define RAMP_ACCELERATION 1
    #define STEPPER_HIGH_DELAY 0
    #define DIRECTION_DELAY 0
    #define ALLOW_QUADSTEPPING 1
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 100
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 100
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 20
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 150
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 150
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 30
    #define MAX_JERK 4
    #define MAX_ZJERK 0.4
    #define MOVE_CACHE_LOW 10
    #define DUAL_X_AXIS 0
    #define DUAL_X_RESOLUTION 0
    #define X2_STEP_PIN   ORIG_E1_STEP_PIN
    #define X2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Y2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Y2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Z2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z3_STEP_PIN   ORIG_E2_STEP_PIN
    #define Z3_DIR_PIN    ORIG_E2_DIR_PIN
    #define Z4_STEP_PIN   ORIG_E3_STEP_PIN
    #define Z4_DIR_PIN    ORIG_E3_DIR_PIN
    #define USE_ADVANCE 0
    #define BAUDRATE 250000
    #define POWER_INVERTING 0
    #define AUTOMATIC_POWERUP 0
    #define KILL_METHOD 1
    #define ACK_WITH_LINENUMBER 1
    #define ECHO_ON_EXECUTE 1
    #define EEPROM_MODE 0
    #undef PS_ON_PIN
    #define JSON_OUTPUT 0
  • edited May 2018
    Hi !
    I fixed the issue !
    The firmware was good, the issue was interferences in my cables that sent high signal !
    I wired the switch normaly closed and inverted the logic of the switch in the firmware and now all works perfectly :)
