Melzi 2.0 BLTouch Servo Pin A4 how to define the PIN ?
first thanks to this great printer firmware, with the Online Conifgurator it's easy for beginner as me.
First a few facts which hardware and whats my problem:
Melzi 2.0 Board + 5 Button LCD
Repetier 0.92.9 (working good without Z-Probing&Servo)
BLTouch Probe
I want Z-probing with the BLTouch probe:
1. Wired is the BLTouch as in this post: https://plus.google.com/113792662927481823969/posts/DBkfSkQArGG (BLTouch Endstop wire is on Z-Endstop on the Melzi + Servo Signal on the PIN A4)
2.Configuration.h is setup with the configuration tool as in this thread: https://forum.repetier.com/discussion/2477/bltouch-configuration-on-makergear-m2-with-rambo
3. The problem is the PIN A4 (the producer of the BLTouch said: Please add below at "pins_SANGUINOLOLU_11.h"
#define SERVO0_PIN A4 )
I know this is for marlin. But how should i define the PINs ? In the configuration tool i can't select Analog Input PINs.Only Digital PINs and when i select Digital PIN 4, my fan doesn't work after this change.
Here is the schematic from the Melzi board:
http://images.google.de/imgres?imgurl=http://reprap.org/mediawiki/images/thumb/7/7d/Melzi-circuit.png/1000px-Melzi-circuit.png&imgrefurl=http://reprap.org/wiki/Melzi&h=584&w=1000&tbnid=CgJhB7tB_1MuFM:&vet=1&tbnh=90&tbnw=154&docid=yvtyFcNEsY_LJM&usg=__Okaa0NT5-3dpBojazLHvK5bgTSE=&sa=X&ved=0ahUKEwinldHkrLDRAhVX-2MKHeg3BCIQ9QEIIjAC
Can someone help me ?
BLTouch Probe
Sorry for bumping this, but I had somewhat the same problem.
The only pin which was left unconnected from the Zonestart LCD2004 display is the A4, for which the mapping is the pin 27:
https://github.com/Lauszus/Sanguino/blob/master/variants/sanguino/pins_arduino.h#L82
