Log file
How do I create a log file?  I want to see the results of commands like M114 position.  Where does this get written in Repetier Host software?
  • If you disable easy mode you can enable the log in the toolbar and see it then at the bottom. For a full log you can enable it in general settings and it will write it to a log file in work directory.
  • Hey !
    What does the "*#" (where # is a number) mean at the end of command lines in the log file ?
    THanks
  • *xxx are checksums you would use if you send command in ascii mode. You can ignore this.
