Toggle navigation
Categories
Discussions
About Us
Privacy Policy
Sign In
Home
Repetier-Host
Questions & Answers
Log file
cliquot22
December 2014
in
Questions & Answers
How do I create a log file? I want to see the results of commands like M114 position. Where does this get written in Repetier Host software?
Repetier
December 2014
If you disable easy mode you can enable the log in the toolbar and see it then at the bottom. For a full log you can enable it in general settings and it will write it to a log file in work directory.
zefred
January 2018
Hey !
What does the "*#" (where # is a number) mean at the end of command lines in the log file ?
THanks
Repetier
January 2018
*xxx are checksums you would use if you send command in ascii mode. You can ignore this.
Sign In
or
Register
to comment.
