Dual axis X2 feedrate limitation?
in Bug Reports
I am using repetier firmware dev version with a dual X axis printer.
I've found that it seems that the X2 feedrate is limited and does not depend on the feedrate defined using the configuration tool. For X1 I have the maximum feedrate set to 400 mm/s but the X2 does not get any close to that. I seems to be around 100 mm/s or less.
Looking at the firmware there is only one value for the X axis feedrate so I guess they share it.
Is it correct or is there another feedrate value to define somewhere else?
Thanks in advance!
Thanks in advance!
Thanks for the quick reply.
I use an Arduino Due, so the maximum frequency is higher.
Anyway, I already found the problem. It guess it was the motor that was damaged as when I have replaced it the problem is gone.
Now I've realised that both X motors do not go over 150 mm/s while the Y motors go up to 400 mm/s as limited in the settings.
I don't know what it can be. The hardware is the same for X and Y and I've not found any difference between the X and Y settings.
I'll keep investigating. Any idea will be welcome.
Thanks!
