for the interior temp it would perhaps need a new g-code command,
but would be an interresent tool to display the interior temperature ...
In principle my request is for the name of the extruder in the
main window (repetier host V2.0.5).
thank you
Regarding board temperature - that was never really interesting and relevant. If build correctly it stays in good range and you can add a fan that gets enabled. I think we even do not measure this explicitly. You can use the heated chamber function for this in the future. That temperature will get reported and you can configure it to a dummy heater.
