Configurator can't set ENDSTOP_Z_MIN_INVERTING
Hi seems that I found a bug in the online firmware configurator:
When I upload a Configuration.h with ENDSTOP_Z_MIN_INVERTING = false in the online configurator and download it again, ENDSTOP_Z_MIN_INVERTING will be set from false to true automatically in the downloaded config file.
This makes the Z axis stop working completely. The configurator only allows to set Z_ENABLE_ON, but not ENDSTOP_Z_MIN_INVERTING.
In my case I need both to make it work:
Z_ENABLE_ON = 0
When I use the online configurator I have to fix the resulting config by hand every time.
So either the online configurator should have another checkbox for ENDSTOP_Z_MIN_INVERTING, or it should just keep the uploaded value instead of overwriting it.
Thanks!
Z_ENABLE_ON = 0
Thanks!
Nevertheless it is not set approprieately after uploading an old Configuration.h Possibly in my case it wasn't read back, because I edited the file manually. Anyways this is a bit confusing behaviour. After uploading a changed file, the configurator sticks with a value magically stored in browser instead of reading the value from the uploaded config
So probably this is not a bug, but a bit annoying.
