Some problems in repetier dev version
I using repetier firmware with an arduino due, smart ramps and AZSMZ 12864 LCD.
I can not use the stable version because it was not the option of the lcd and smart ramps with epprom, only the dev version was this.
I reporting saveral problem with the auto leveling in the dev version.
1) the X offset and Y offset is not apply during the auto leveling process. For exemple my sensor X offset = 25 and Y offset = 10 in relatation to the hotend. the last corner of the autolevel level is configured to be X=200 Y=300. the possition of the hotend sould be X=175 Y=290. Instead the hotend position is X=200 Y=300.
2) before starting the autoleve the Z move like 10 or more mm up for some reason unkown. Pre raise Z axis was set to "never"
I used the stable version with a ramps and never have any type of problem. It possible to add in the stable version the LCD option "AZSMZ 12864" and the board "smart ramps with epprom"? this way i could continue to use the stable version.
br,
Filipe
br,
Filipe
I'm pretty sure z probing still works, but you should check the log when doing it. It has some cases where it just stops if you would need to move to illegal positions.So e.g. you need to start at x > 25, y > 10 or it will not activate correctly with offset.
I defined P1 and P2 outside the reach in the auto level.
Z_PROBE_BED_DISTANCE [mm] = Max. distance to go back for next test
