Deleting file from SD card
When I try to delete a gcode file from an inserted SD card, the printer starts printing it right after confirming to delete it.
Repetier firmware 1.0.4.
M30 Filename
Did it write file deleted before starting?
If you check the code
If you are using lcd to delete - after delete it goes up a menu I think so could it be that the click was counted several times so it selected print and first file? I mean after delete it would be impossible to print the same file. If it is the multiple click it would print the first file in list. Not that I have encountered that so far.
If not does selecting file to print work as expected. Don't see the issue in code so unsure what else could cause it.
