Unnecessary move during home
My Z axis is at home 230mm, it then will approach the build plate and return to home. It also skips steps during the acceleration periods. How can I stop this extra move?
  • I tried x8 steps, different drivers, and a bunch of different feedrates/accelerations. It wont stop skipping until the feedrate is <5.
  • Z axis is often very sensitive to z acceleration and max z speed. Reason is you often split on 2 motors so both have less force plus friction from rotation.
    What are your z homing parameters? Normally z max home will not move down. But if you have configured z min home with up move 230 for example that would happen. But can't say without seeing your parameter what could be causing it.
