Core XY - one axis is always wrong
2»
  • den von Repetier Server? hab noch mal alle Felder geprüft. ich finde da leider nix.
  • Server hat auch ein eepom button. Da siehst du die aktuellen werte. Ansonsten gib M205 in der Konsole ein dann spuckt er die werte auch alle aus.
  • also ich sehe da nix.
    Recv:19:18:32.900: EPR:0 1028 1 Language
    Recv:19:18:32.901: EPR:2 75 115200 Baudrate
    Recv:19:18:32.902: EPR:3 129 0.010 Filament printed [m]
    Recv:19:18:32.903: EPR:2 125 253 Printer active [s]
    Recv:19:18:32.905: EPR:2 79 0 Max. inactive time [ms,0=off]
    Recv:19:18:32.906: EPR:2 83 360000 Stop stepper after inactivity [ms,0=off]
    Recv:19:18:32.907: EPR:3 3 200.4500 X-axis steps per mm
    Recv:19:18:32.908: EPR:3 7 200.0400 Y-axis steps per mm
    Recv:19:18:32.910: EPR:3 11 402.3100 Z-axis steps per mm
    Recv:19:18:32.911: EPR:3 15 600.000 X-axis max. feedrate [mm/s]
    Recv:19:18:32.912: EPR:3 19 600.000 Y-axis max. feedrate [mm/s]
    Recv:19:18:32.913: EPR:3 23 12.000 Z-axis max. feedrate [mm/s]
    Recv:19:18:32.965: EPR:3 27 80.000 X-axis homing feedrate [mm/s]
    Recv:19:18:32.966: EPR:3 31 80.000 Y-axis homing feedrate [mm/s]
    Recv:19:18:32.969: EPR:3 35 6.000 Z-axis homing feedrate [mm/s]
    Recv:19:18:32.971: EPR:3 39 8.000 Max. jerk [mm/s]
    Recv:19:18:32.972: EPR:3 47 0.200 Max. Z-jerk [mm/s]
    Recv:19:18:32.973: EPR:3 133 0.000 X min pos [mm]
    Recv:19:18:32.974: EPR:3 137 0.000 Y min pos [mm]
    Recv:19:18:32.975: EPR:3 141 0.000 Z min pos [mm]
    Recv:19:18:32.977: EPR:3 145 220.000 X max length [mm]
    Recv:19:18:32.978: EPR:3 149 190.000 Y max length [mm]
    Recv:19:18:32.979: EPR:3 153 230.000 Z max length [mm]
    Recv:19:18:32.980: EPR:3 1056 0.000 Park position X [mm]
    Recv:19:18:32.981: EPR:3 1060 0.000 Park position Y [mm]
    Recv:19:18:33.019: EPR:3 1064 10.000 Park position Z raise [mm]
    Recv:19:18:33.021: EPR:3 51 1000.000 X-axis acceleration [mm/s^2]
    Recv:19:18:33.022: EPR:3 55 1000.000 Y-axis acceleration [mm/s^2]
    Recv:19:18:33.022: EPR:3 59 100.000 Z-axis acceleration [mm/s^2]
    Recv:19:18:33.024: EPR:3 63 1700.000 X-axis travel acceleration [mm/s^2]
    Recv:19:18:33.025: EPR:3 67 1700.000 Y-axis travel acceleration [mm/s^2]
    Recv:19:18:33.026: EPR:3 71 100.000 Z-axis travel acceleration [mm/s^2]
    Recv:19:18:33.027: EPR:3 1024 0.000 Coating thickness [mm]
    Recv:19:18:33.028: EPR:3 808 40.000 Z-probe height [mm]
    Recv:19:18:33.030: EPR:3 929 10.000 Max. z-probe - bed dist. [mm]
    Recv:19:18:33.082: EPR:3 812 2.000 Z-probe speed [mm/s]
    Recv:19:18:33.082: EPR:3 840 150.000 Z-probe x-y-speed [mm/s]
    Recv:19:18:33.083: EPR:3 800 0.000 Z-probe offset x [mm]
    Recv:19:18:33.084: EPR:3 804 0.000 Z-probe offset y [mm]
    Recv:19:18:33.086: EPR:3 816 20.000 Z-probe X1 [mm]
    Recv:19:18:33.086: EPR:3 820 20.000 Z-probe Y1 [mm]
    Recv:19:18:33.087: EPR:3 824 160.000 Z-probe X2 [mm]
    Recv:19:18:33.088: EPR:3 828 20.000 Z-probe Y2 [mm]
    Recv:19:18:33.088: EPR:3 832 100.000 Z-probe X3 [mm]
    Recv:19:18:33.089: EPR:3 836 160.000 Z-probe Y3 [mm]
    Recv:19:18:33.090: EPR:3 1036 0.000 Z-probe bending correction A [mm]
    Recv:19:18:33.091: EPR:3 1040 0.000 Z-probe bending correction B [mm]
    Recv:19:18:33.091: EPR:3 1044 0.000 Z-probe bending correction C [mm]
    Recv:19:18:33.146: EPR:0 880 0 Autolevel active (1/0)
    Recv:19:18:33.147: EPR:1 1048 -1 Bed Preheat temp. [degC]
    Recv:19:18:33.147: EPR:0 106 0 Bed Heat Manager [0-3]
    Recv:19:18:33.148: EPR:0 107 255 Bed PID drive max
    Recv:19:18:33.149: EPR:0 124 80 Bed PID drive min
    Recv:19:18:33.150: EPR:3 108 196.000 Bed PID P-gain
    Recv:19:18:33.150: EPR:3 112 33.000 Bed PID I-gain
    Recv:19:18:33.151: EPR:3 116 290.000 Bed PID D-gain
    Recv:19:18:33.152: EPR:0 120 255 Bed PID max value [0-255]
    Recv:19:18:33.153: EPR:0 1020 1 Enable retraction conversion [0/1]
    Recv:19:18:33.153: EPR:3 992 3.000 Retraction length [mm]
    Recv:19:18:33.154: EPR:3 1000 40.000 Retraction speed [mm/s]
    Recv:19:18:33.155: EPR:3 1004 0.000 Retraction z-lift [mm]
    Recv:19:18:33.204: EPR:3 1008 0.000 Extra extrusion on undo retract [mm]
    Recv:19:18:33.205: EPR:3 1016 20.000 Retraction undo speed
    Recv:19:18:33.207: EPR:3 200 657.895 Extr.1 steps per mm
    Recv:19:18:33.208: EPR:3 204 50.000 Extr.1 max. feedrate [mm/s]
    Recv:19:18:33.209: EPR:3 208 20.000 Extr.1 start feedrate [mm/s]
    Recv:19:18:33.210: EPR:3 212 5000.000 Extr.1 acceleration [mm/s^2]
    Recv:19:18:33.211: EPR:1 294 190 Extr.1 Preheat temp. [degC]
    Recv:19:18:33.211: EPR:0 216 1 Extr.1 heat manager [0-3]
    Recv:19:18:33.212: EPR:0 217 255 Extr.1 PID drive max
    Recv:19:18:33.213: EPR:0 245 40 Extr.1 PID drive min
    Recv:19:18:33.213: EPR:3 218 4.5543 Extr.1 PID P-gain/dead-time
    Recv:19:18:33.269: EPR:3 222 0.1482 Extr.1 PID I-gain
    Recv:19:18:33.269: EPR:3 226 34.9860 Extr.1 PID D-gain
    Recv:19:18:33.270: EPR:0 230 255 Extr.1 PID max value [0-255]
    Recv:19:18:33.271: EPR:2 231 0 Extr.1 X-offset [steps]
    Recv:19:18:33.271: EPR:2 235 0 Extr.1 Y-offset [steps]
    Recv:19:18:33.272: EPR:2 290 0 Extr.1 Z-offset [steps]
    Recv:19:18:33.273: EPR:1 239 1 Extr.1 temp. stabilize time [s]
    Recv:19:18:33.275: EPR:1 250 150 Extr.1 temp. for retraction when heating [degC]
    Recv:19:18:33.276: EPR:1 252 0 Extr.1 distance to retract when heating [mm]
    Recv:19:18:33.276: EPR:0 254 255 Extr.1 extruder cooler speed [0-255]
  • Ok rätsel gelöst. 16092 waren Schritte. Du hast z auflösung 402,31 und z probe height 40mm => 16092 Schritte. Er will also nach den Proben 40mm tiefer weil du gesagt hast das die Düse beim triggern 40mm von der Düse entfernt ist. Denke mal 4mm wäre hier realistischer. Vielleicht auch noch weniger.
  • Bingo.
    Recv:15:29:23.034: z1
    Recv:15:29:31.513: z2
    Recv:15:29:32.504: z3
    Recv:15:29:34.616: z4:-1609.0000
    Recv:15:29:35.608: z5:-1609.0000
    Recv:15:29:37.368: z6
    Recv:15:29:38.373: X:0.00 Y:0.00 Z:0.000 E:0.0000
    Das Bett ist jetzt nur ein Stück hochgefahren, also musste ich nicht abbrechen.
    was mich jetzt nur wundert, warum fährt es überhaut hoch, sollte es nicht runter? (so kenne ich es von Marlin)
    kann ich auch -4mm angeben?
    Versuch macht Kluch...:
    ja so ist es...
    -4 bzw -5 (etwas mehr Luft) ist bei mit die Lösung.
    Jetzt ist die Frage ob das formell auch so richtig ist.
    Weil nach meiner Logik sollte der der Wert doch Positiv sein weil auch in den positiven Bereich gefahren werden soll.
  • Formell sind negative werte nur bei sensoren die die düse benutzen korrekt. Sonst würde die nase das Bett ja berühren bevor der z probe triggert, was nicht geht. Aber wenn die nase etwas druck ausüben muss biegt es irgendwo etwas was negative Werte in dem Fall benötigt, allerdings eher kleine Werte.
  • Erst Mal Danke für deine Hilfe. Ich werde mich nun daran machen die Treiber zu wechseln…
