Temperature in Repetier Host different from the internal temperature of the nozzle
Hello
I am checking the internal temperature of the nozzle by means of a multimeter with a thermal probe.
I found a misalignment of the temperature set in the Repetier Host and that detected inside the nozzle.
How can I adjust these values to have a situation more similar to the real one?
I tried to enable option:
#define TEMP_GAIN 1
Enabling this value has disabled the heated bed.
For an e3d v6 hotend, has someone created the NTC 100K B 3950 thermisotre table to have the
temperature values close to the real ones?
You can either configure firmware with user defined curve that you have full control or just as you tried
#define TEMP_GAIN 1
but then repopulate eeprom or at least fix wrong values in eeprom to get the desired result. Result is not 100% but you can at least modify it so that around print temperatures the result is more or less correct.
