Graph freeze
edited November 18 in Bug Reports
Hello, I just bought Ender 3X. I connected it to PC and in Repetier-host program, successfully. I can control entire 3D printer. Unfortunately when I was trying to see temperature graph it happened to be frozen. Every time I disconnected and connected again (in program) to the 3D printer, graph update but only once (still frozen but with some values). I can't figure it out how to get it work properly and see live data.
  • Several current ender products have a firmware bug reporting the temperature in a wrong format (they repeat everything so T:23.3 gets TT::23.323.3). Only our repetier-server beta 0.94.4 for linux (you need to change the url in download) would be able to fix the wrong format. Everything works fine with printer just we don't understand temperatures so they are not shown/updated. Next versions will contain a detection for it and convert it in the regular temperature string.
  • edited November 20
    Thank You very much, I will rather wait for next version on Windows. For now, I made a script with sequence of "M105" (checking temperature) and "G4 P100" (wait 100ms) commands repeated many times to update the temperature values. It worked for me. Anyway, it is good to know that it is not because my 3D printer is broken. Once again, Thank You very much and have a nice day :smiley:.
  • I wonder that this works. Could it be that you just have disabled temperature query with M105 in printer settings? Otherwise I do not understand why that reports a temperature for you.
