skipping some lines in version 1.0.4
I'm using FW 1.0.3 and S3D slicer. It works perfectly.
After upgrade to 1.0.4 printer skips first retraction (just fillament in, out produces blob) and do not turn fan on in first layer.
It is the same g-code as before.
I have to add retraction and fan to starting script, after that it works well.
But why? When I look to g-code, it is now two same lines, but it did only one.
Otherwise it is excelent firmware.
Thank you.
This gcode works in 1.0.3:
Fan start working fine, if it is from second layer.
If it should be from layer one, situation is same as with retraction.
Thank you so much for your time, as I mention, it can be solved in starting script in S3D.
