RADDS + DUE + RAPS128 + RADDS LCD 4x 20 Control panel
Need help here please.
I am trying to configure my 3D printer, but the axes (X, Y, Z) do not move.
Below my configuration.h
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
generator: http://www.repetier.com/firmware/v092/
as you expect.
#define NUM_EXTRUDER 1
#define MOTHERBOARD 402
#define RFSERIAL Serial
#include "pins.h"
#undef FAN_BOARD_PIN
#define FAN_BOARD_PIN -1
#define FAN_THERMO_PIN -1
#define FAN_THERMO_THERMISTOR_TYPE 13
//#define COMPAT_PRE1
#define BLUETOOTH_SERIAL 101
#define BLUETOOTH_BAUD 250000
#define MIXING_EXTRUDER 0
#define DRIVE_SYSTEM 3
#define XAXIS_STEPS_PER_MM 20480 //128
#define YAXIS_STEPS_PER_MM 5120 //32
#define ZAXIS_STEPS_PER_MM 10240 //64
#define PDM_FOR_EXTRUDER 0
#define PDM_FOR_COOLER 0
#define RETRACT_ON_PAUSE 7
#define PAUSE_END_COMMANDS ""
#define EXT0_X_OFFSET 0
#define EXT0_Y_OFFSET -250
#define EXT0_Z_OFFSET 0
#define EXT0_STEPS_PER_MM 476.5 //16
#define EXT0_TEMPSENSOR_TYPE 13
#define EXT0_INVERSE 0
#define EXT0_ENABLE_ON 0
#define EXT0_MAX_FEEDRATE 100
#define EXT0_MAX_START_FEEDRATE 40
#define EXT0_MAX_ACCELERATION 10000
#define EXT0_HEAT_MANAGER 3
#define EXT0_WATCHPERIOD 1
#define EXT0_PID_INTEGRAL_DRIVE_MAX 210
#define EXT0_PID_PGAIN_OR_DEAD_TIME 8
#define EXT0_PID_I 2
#define EXT0_PID_D 40
#define EXT0_PID_MAX 255
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define EXT0_JAM_PIN -1
#define EXT0_JAM_PULLUP 0
//#define EXT1_X_OFFSET 0
//#define EXT1_Y_OFFSET 900
//#define EXT1_Z_OFFSET 0
//#define EXT1_STEPS_PER_MM 310
//#define EXT1_TEMPSENSOR_TYPE 1
//#define EXT1_TEMPSENSOR_PIN TEMP_2_PIN
//#define EXT1_HEATER_PIN HEATER_2_PIN
//#define EXT1_STEP_PIN ORIG_E1_STEP_PIN
//#define EXT1_DIR_PIN ORIG_E1_DIR_PIN
//#define EXT1_INVERSE 0
//#define EXT1_ENABLE_PIN ORIG_E1_ENABLE_PIN
//#define EXT1_ENABLE_ON 1
//#define EXT1_MAX_FEEDRATE 100
//#define EXT1_MAX_START_FEEDRATE 40
//#define EXT1_MAX_ACCELERATION 10000
//#define EXT1_HEAT_MANAGER 3
//#define EXT1_WATCHPERIOD 1
//#define EXT1_PID_INTEGRAL_DRIVE_MAX 210
//#define EXT1_PID_INTEGRAL_DRIVE_MIN 40
//#define EXT1_PID_PGAIN_OR_DEAD_TIME 8
//#define EXT1_PID_I 2
//#define EXT1_PID_D 40
//#define EXT1_PID_MAX 255
//#define EXT1_ADVANCE_K 0
//#define EXT1_ADVANCE_L 0
//#define EXT1_ADVANCE_BACKLASH_STEPS 0
//#define EXT1_WAIT_RETRACT_TEMP 150
//#define EXT1_WAIT_RETRACT_UNITS 0
//#define EXT1_SELECT_COMMANDS ""
//#define EXT1_DESELECT_COMMANDS ""
//#define EXT1_EXTRUDER_COOLER_PIN -1
//#define EXT1_EXTRUDER_COOLER_SPEED 255
//#define EXT1_DECOUPLE_TEST_PERIOD 12000
//#define EXT1_JAM_PIN -1
//#define EXT1_JAM_PULLUP 0
#define FEATURE_RETRACTION 1
#define AUTORETRACT_ENABLED 0
#define RETRACTION_LENGTH 7
#define RETRACTION_LONG_LENGTH 20
#define RETRACTION_SPEED 80
#define RETRACTION_Z_LIFT 1
#define RETRACTION_UNDO_SPEED 50
#define FILAMENTCHANGE_Y_POS -180
#define FILAMENTCHANGE_Z_ADD 10
#define FILAMENTCHANGE_REHOME 2
#define FILAMENTCHANGE_SHORTRETRACT 20
#define JAM_STEPS 220
#define JAM_SLOWDOWN_TO 70
#define JAM_ERROR_STEPS 500
#define JAM_MIN_STEPS 10
#define JAM_ACTION 1
#define PID_CONTROL_RANGE 20
#define SKIP_M109_IF_WITHIN 2
#define SCALE_PID_TO_MAX 0
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 160
#define GENERIC_THERM_VREF 5
#define HEATER_PWM_SPEED 1
#define HAVE_HEATED_BED 1
#define SKIP_M190_IF_WITHIN 3
#define HEATED_BED_DECOUPLE_TEST_PERIOD 500000
#define MIN_EXTRUDER_TEMP 150
#define MAXTEMP 275
// ## Laser configuration ##
automatically disabled.
#define SUPPORT_LASER 0
#define LASER_PIN -1
#define LASER_ON_HIGH 1
// ## CNC configuration ##
#define SUPPORT_CNC 0
#define CNC_WAIT_ON_DISABLE 0
#define CNC_ENABLE_PIN -1
#define CNC_ENABLE_WITH 1
#define CNC_DIRECTION_PIN -1
#define CNC_DIRECTION_CW 1
#define ENDSTOP_PULLUP_X_MAX false
#define ENDSTOP_PULLUP_Y_MAX false
#define ENDSTOP_Y_MAX_INVERTING true
#define ENDSTOP_PULLUP_Z_MAX false
#define ENDSTOP_Z_MAX_INVERTING true
#define ENDSTOP_X_BACK_MOVE 3
#define ENDSTOP_Y_BACK_MOVE 3
#define ENDSTOP_Z_BACK_MOVE 3
#define ENDSTOP_X_BACK_ON_HOME 20
#define ENDSTOP_Y_BACK_ON_HOME 20
#define ENDSTOP_Z_BACK_ON_HOME 20
#define X_ENABLE_ON 1
#define Y_ENABLE_ON 1
#define Z_ENABLE_ON 1
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 1
#define INVERT_Y_DIR 0
#define INVERT_Z_DIR 0
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR 1
#define X_MAX_LENGTH 250
#define Y_MAX_LENGTH 250
#define Z_MAX_LENGTH 250
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define DISTORTION_CORRECTION_POINTS 7
#define DISTORTION_CORRECTION_R 140
#define DISTORTION_UPDATE_FREQUENCY 12
#define DISTORTION_END_HEIGHT 2
#define DISTORTION_EXTRAPOLATE_CORNERS 1
#define DISTORTION_XMIN 10
#define DISTORTION_YMIN 10
#define DISTORTION_XMAX 240
#define DISTORTION_YMAX 240
// ## Movement settings ##
#define DELTA_SEGMENTS_PER_SECOND_PRINT 600 // Move accurate setting for print moves
#define DELTA_SEGMENTS_PER_SECOND_MOVE 400 // Less accurate setting for other moves
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_DIAGONAL_ROD 445 // mm
#define DELTA_ALPHA_A 210
#define DELTA_ALPHA_B 330
#define DELTA_ALPHA_C 90.123
#define DELTA_RADIUS_CORRECTION_C -0.05
#define DELTA_MAX_RADIUS 200
#define ROD_RADIUS 209.5
#define PRINTER_RADIUS 209.5
#define DELTA_HOME_ON_POWER 0
#define STEP_COUNTER
#define DELTA_FLOOR_SAFETY_MARGIN_MM 15
//#define SOFTWARE_LEVELING
#define DELTASEGMENTS_PER_PRINTLINE 200
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 200
#define MAX_FEEDRATE_Y 200
#define MAX_FEEDRATE_Z 600
#define HOMING_FEEDRATE_X 40
#define HOMING_FEEDRATE_Y 40
#define HOMING_FEEDRATE_Z 120
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 999999
#define ZHOME_Y_POS 999999
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 1
#define DIRECTION_DELAY 50
#define STEP_DOUBLER_FREQUENCY 90000
#define ALLOW_QUADSTEPPING 1
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 2000
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 3000
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 3000
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 3000
#define MAX_JERK 20
#define MAX_ZJERK 0.3
#define PRINTLINE_CACHE_SIZE 32
#define MOVE_CACHE_LOW 10
#define USE_ADVANCE 0
#define BAUDRATE 115200
#define POWER_INVERTING 0
#define KILL_METHOD 1
#define ACK_WITH_LINENUMBER 1
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 1
#undef PS_ON_PIN
#define PS_ON_PIN -1
#define JSON_OUTPUT 1
/* ======== Servos =======
Control the servos with
#define FEATURE_SERVO 0
#define SERVO0_PIN 11
#define SERVO1_PIN -1
#define SERVO2_PIN -1
#define SERVO3_PIN -1
#define SERVO0_NEUTRAL_POS -1
#define SERVO1_NEUTRAL_POS -1
#define SERVO2_NEUTRAL_POS -1
#define SERVO3_NEUTRAL_POS -1
#define UI_SERVO_CONTROL 0
#define FEATURE_WATCHDOG 1
#define Z_PROBE_Z_OFFSET 0
#define Z_PROBE_Z_OFFSET_MODE 1
#define UI_BED_COATING 1
#define FEATURE_Z_PROBE 1
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 1
#define Z_PROBE_X_OFFSET -39
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_SPEED 20
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_SWITCHING_DISTANCE 0.4
#define Z_PROBE_REPETITIONS 5
#define Z_PROBE_HEIGHT 2.03
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 -30
#define Z_PROBE_Y1 -30
#define Z_PROBE_X2 250
#define Z_PROBE_Y2 0
#define Z_PROBE_X3 0
#define Z_PROBE_Y3 250
#define BED_LEVELING_METHOD 1
#define BED_LEVELING_GRID_SIZE 4
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
#define SDSUPPORT 0
#undef SDCARDDETECT
#define SDCARDDETECT -1
#define SD_RUN_ON_STOP "G28"
#define ARC_SUPPORT 1
#define FEATURE_FAN_CONTROL 1
#define FEATURE_CONTROLLER 7
#define LANGUAGE_EN_ACTIVE 1
#define LANGUAGE_DE_ACTIVE 0
#define LANGUAGE_NL_ACTIVE 0
#define LANGUAGE_PT_ACTIVE 0
#define LANGUAGE_IT_ACTIVE 0
#define LANGUAGE_ES_ACTIVE 0
#define LANGUAGE_FI_ACTIVE 0
#define LANGUAGE_SE_ACTIVE 0
#define LANGUAGE_FR_ACTIVE 1
#define LANGUAGE_CZ_ACTIVE 0
#define LANGUAGE_PL_ACTIVE 0
#define LANGUAGE_TR_ACTIVE 0
#define UI_PRINTER_NAME "rh"
#define UI_PRINTER_COMPANY "HOME MADE"
#define UI_ANIMATION 0
#define FEATURE_UI_KEYS 0
#define UI_ENCODER_SPEED 1
#define UI_REVERSE_ENCODER 0
#define UI_KEY_BOUNCETIME 10
#define UI_KEY_MIN_REPEAT 50
#define FEATURE_BEEPER 1
#define CASE_LIGHTS_PIN -1
#define UI_START_SCREEN_DELAY 300
#define UI_SET_PRESET_EXTRUDER_TEMP_PLA 190
#define UI_SET_PRESET_EXTRUDER_TEMP_ABS 240
#define NUM_MOTOR_DRIVERS 0
// Uncomment, to see detailed data for every move. Only for debugging purposes!
//#define DEBUG_QUEUE_MOVE
// Allows M111 to set bit 5 (16) which disables all commands except M111. This can be used
//to test your data througput or search for communication problems.
#define INCLUDE_DEBUG_COMMUNICATION 1
// This enables code to make M666 drop an ok, so you get problems with communication. It is to test host robustness.
#define DEBUG_COM_ERRORS
#define ALTERNATIVE_JERK
#define START_STEP_WITH_HIGH 0
I tried to understund what you said but with no results... This is my first experience...
If you can help me more please.
As I need to know how to configure 2 stepper motors in Y axis and Z axis.
Thank you.
Kind Regards;
RH
for extruder you have them 0 and for xyz 1 - if they use same drivers only one of them will work. So guess you need to set them 0 to enable.
And what about how to configure two steppers for the same axis?
Kind Regards;
RH
I tried to redo the program with some comments.
Just to put you in the picture, below all the components I have for my 3D printer:
1) 5 NEMA23 Stepper motors ( One for the X-Axis // Two Motors for the Y-Axis and Two for the Z-Axis). Using ACME 8mm Lead Screw for the 5 Axis (X, Y, Y1, Z and Z1).
2) RADDS + ARDUINO DUE.
3) 4 RAPS128 (X,Y,Z,E0).
4) 6 E-HALL (Three for Xmin,Ymin and Zmin // And three for Xmax, Y1max and Z1max).
PS: My bed is fixed, doesn't move .
Below my configuration. I don't know if there is any mistake in my configuration that stop me from running my Printer.Hope you will verify what I made and help me please. As I don't know how to fix my start point (0,0,0) (I don't want it in the center).
I Thank you very much
Kind Regards;
RH
and that is why the options are not in the config part.
I'll Try it if it works.
Have a nice day.
Kind Regards;
RH
I've tested the program, and this is what happens:
X: Makes a strange sound, and it moves only one step and stop.
Y: The motors just vibrate without turning.
Z: After switching the cables, it works. But when I started testing Y axis, and switched to Z axis, and here nothings works.
The problem is that when I tried to retest Z axis, The Y axis that start vibrating without turning!
And I really don't understand why
I switched the cables many times, but with no results.
PS: X axis always make a sound when I try to move the two other axis.
Any help please
Thank you.
Kind Regards;
RH
This is all what I did: #define NUM_MOTOR_DRIVERS 0 #endif
I ask myself what you are doing. The original y and z motors already use these so why reuse them again for the second motor? That is screaming for problems - the second will not move. Here you need to select the motor socket where you connected them. E1 and E2 are likely the correct choice. Also always check steps per mm to match your microsteps, check jerk is not too high as well as acceleration.
So what is now connected to E1? second Z or second Y motor? Since Z works as you said I guess Z so it can't be used for Y motor.
X:10240; Y:5120;
Are these values serious? With such high values you can only move slowly. Maybe 30mm/s if you have no extra delays. Any resolution higher then 1000 steps/mm is exaggerated and even around 1000 is only good for better motor sound. If these values are too high your motor will just block and you hear a high pitch sound.
X --> I shoosed 64 step/mm (200 X 64)/1.25=10240 Step/mm
Y--> 32 step/mm (200 X 32) / 1.25= 5120 Step/mm
And Z : same like X 64 step/mm (200 X 64)/1.25=10240 Step/mm
But as I said before, no movement of the two steppers of Y and that of X!
1) The Y axes make noise as if they move the axes, but no rotation / no movement only a sound !!
2) The X axis is identical to the Y axis!
3) And for the Z axes, move, but I thought that normally when we turn off the E-HALL Endstop and turn on the 3D printer, the axes should not move! But in my case, the Z axes move. And when I turned on the Z-E-HALL Max, and I try to configure it, Z does not go up, only goes down.
I don't know if you can help me, but I hope so. And I apologize, But as I already mentioned, this is something new for me and I try to learn. So I hope to get help here. I sincerely thank you.
PS:
When I use the voltmeter to measure the output voltage of the motors, for the z, it displays the 3V. on the other hand the Y and the X is 0
Kind Regards;
Config:
And lastly
And why Z can't move up when I activate the E-HALL Endstop max?
it is the only homing command I see in configuration. If yu don't have z max homing that would be a bad idea anyway.
At startup firmware tries to run a autorun script so even if it is not there it might get stopped and trigger this.
This is the size of my bed:
