RADDS + DUE + RAPS128 + RADDS LCD 4x 20 Control panel
rimrim
edited July 2020 in Questions & Answers
Hello, Need help here please. I am trying to configure my 3D printer, but the axes (X, Y, Z) do not move.
Below my configuration.h
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
   as you expect.
#define NUM_EXTRUDER 1
#define MOTHERBOARD 402
#define RFSERIAL Serial
#include "pins.h"
#undef FAN_BOARD_PIN
#define FAN_BOARD_PIN -1
#define FAN_THERMO_PIN -1
#define FAN_THERMO_THERMISTOR_TYPE 13
//#define COMPAT_PRE1
#define BLUETOOTH_SERIAL  101
#define BLUETOOTH_BAUD  250000
#define MIXING_EXTRUDER 0
#define DRIVE_SYSTEM 3
#define XAXIS_STEPS_PER_MM 20480 //128
#define YAXIS_STEPS_PER_MM 5120  //32
#define ZAXIS_STEPS_PER_MM 10240 //64
#define PDM_FOR_EXTRUDER 0
#define PDM_FOR_COOLER 0
#define RETRACT_ON_PAUSE 7
#define PAUSE_END_COMMANDS ""
#define EXT0_X_OFFSET 0
#define EXT0_Y_OFFSET -250
#define EXT0_Z_OFFSET 0
#define EXT0_STEPS_PER_MM 476.5 //16
#define EXT0_TEMPSENSOR_TYPE 13
#define EXT0_INVERSE 0
#define EXT0_ENABLE_ON 0
#define EXT0_MAX_FEEDRATE 100
#define EXT0_MAX_START_FEEDRATE 40
#define EXT0_MAX_ACCELERATION 10000
#define EXT0_HEAT_MANAGER 3
#define EXT0_WATCHPERIOD 1
#define EXT0_PID_INTEGRAL_DRIVE_MAX 210
#define EXT0_PID_PGAIN_OR_DEAD_TIME 8
#define EXT0_PID_I 2
#define EXT0_PID_D 40
#define EXT0_PID_MAX 255
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define EXT0_JAM_PIN -1
#define EXT0_JAM_PULLUP 0
//#define EXT1_X_OFFSET 0
//#define EXT1_Y_OFFSET 900
//#define EXT1_Z_OFFSET 0
//#define EXT1_STEPS_PER_MM 310
//#define EXT1_TEMPSENSOR_TYPE 1
//#define EXT1_TEMPSENSOR_PIN TEMP_2_PIN
//#define EXT1_HEATER_PIN HEATER_2_PIN
//#define EXT1_STEP_PIN ORIG_E1_STEP_PIN
//#define EXT1_DIR_PIN ORIG_E1_DIR_PIN
//#define EXT1_INVERSE 0
//#define EXT1_ENABLE_PIN ORIG_E1_ENABLE_PIN
//#define EXT1_ENABLE_ON 1
//#define EXT1_MAX_FEEDRATE 100
//#define EXT1_MAX_START_FEEDRATE 40
//#define EXT1_MAX_ACCELERATION 10000
//#define EXT1_HEAT_MANAGER 3
//#define EXT1_WATCHPERIOD 1
//#define EXT1_PID_INTEGRAL_DRIVE_MAX 210
//#define EXT1_PID_INTEGRAL_DRIVE_MIN 40
//#define EXT1_PID_PGAIN_OR_DEAD_TIME 8
//#define EXT1_PID_I 2
//#define EXT1_PID_D 40
//#define EXT1_PID_MAX 255
//#define EXT1_ADVANCE_K 0
//#define EXT1_ADVANCE_L 0
//#define EXT1_ADVANCE_BACKLASH_STEPS 0
//#define EXT1_WAIT_RETRACT_TEMP 150
//#define EXT1_WAIT_RETRACT_UNITS 0
//#define EXT1_SELECT_COMMANDS ""
//#define EXT1_DESELECT_COMMANDS ""
//#define EXT1_EXTRUDER_COOLER_PIN -1
//#define EXT1_EXTRUDER_COOLER_SPEED 255
//#define EXT1_DECOUPLE_TEST_PERIOD 12000
//#define EXT1_JAM_PIN -1
//#define EXT1_JAM_PULLUP 0
#define FEATURE_RETRACTION 1
#define AUTORETRACT_ENABLED 0
#define RETRACTION_LENGTH 7
#define RETRACTION_LONG_LENGTH 20
#define RETRACTION_SPEED 80
#define RETRACTION_Z_LIFT 1
#define RETRACTION_UNDO_SPEED 50
#define FILAMENTCHANGE_Y_POS -180
#define FILAMENTCHANGE_Z_ADD  10
#define FILAMENTCHANGE_REHOME 2
#define FILAMENTCHANGE_SHORTRETRACT 20
#define JAM_STEPS 220
#define JAM_SLOWDOWN_TO 70
#define JAM_ERROR_STEPS 500
#define JAM_MIN_STEPS 10
#define JAM_ACTION 1
#define PID_CONTROL_RANGE 20
#define SKIP_M109_IF_WITHIN 2
#define SCALE_PID_TO_MAX 0
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 160
#define GENERIC_THERM_VREF 5
#define HEATER_PWM_SPEED 1
#define HAVE_HEATED_BED 1
#define SKIP_M190_IF_WITHIN 3
#define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   196
#define HEATED_BED_DECOUPLE_TEST_PERIOD 500000
#define MIN_EXTRUDER_TEMP 150
#define MAXTEMP 275
// ##                             Laser configuration                                      ##
automatically disabled.
#define SUPPORT_LASER 0
#define LASER_PIN -1
#define LASER_ON_HIGH 1
// ##                              CNC configuration                                       ##
#define SUPPORT_CNC 0
#define CNC_WAIT_ON_DISABLE 0
#define CNC_ENABLE_PIN -1
#define CNC_ENABLE_WITH 1
#define CNC_DIRECTION_PIN -1
#define CNC_DIRECTION_CW 1
#define ENDSTOP_PULLUP_X_MAX false
#define ENDSTOP_X_MAX_INVERTING true
#define ENDSTOP_PULLUP_Y_MAX false
#define ENDSTOP_Y_MAX_INVERTING true
#define ENDSTOP_PULLUP_Z_MAX false
#define ENDSTOP_Z_MAX_INVERTING true
#define min_software_endstop_z true
#define ENDSTOP_X_BACK_MOVE 3
#define ENDSTOP_Y_BACK_MOVE 3
#define ENDSTOP_Z_BACK_MOVE 3
#define ENDSTOP_X_BACK_ON_HOME 20
#define ENDSTOP_Y_BACK_ON_HOME 20
#define ENDSTOP_Z_BACK_ON_HOME 20
#define X_ENABLE_ON 1
#define Y_ENABLE_ON 1
#define Z_ENABLE_ON 1
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 1
#define INVERT_Y_DIR 0
#define INVERT_Z_DIR 0
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR 1
#define X_MAX_LENGTH 250
#define Y_MAX_LENGTH 250
#define Z_MAX_LENGTH 250
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define DISTORTION_CORRECTION_POINTS 7
#define DISTORTION_CORRECTION_R 140
#define DISTORTION_UPDATE_FREQUENCY 12
#define DISTORTION_END_HEIGHT 2
#define DISTORTION_EXTRAPOLATE_CORNERS 1
#define DISTORTION_XMIN 10
#define DISTORTION_YMIN 10
#define DISTORTION_XMAX 240
#define DISTORTION_YMAX 240
#define DELTA_SEGMENTS_PER_SECOND_PRINT 600 // Move accurate setting for print moves
#define DELTA_SEGMENTS_PER_SECOND_MOVE 400 // Less accurate setting for other moves
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_DIAGONAL_ROD 445 // mm
#define DELTA_ALPHA_A 210
#define DELTA_ALPHA_B 330
#define DELTA_ALPHA_C 90.123
#define DELTA_RADIUS_CORRECTION_C -0.05
#define DELTA_MAX_RADIUS 200
#define ROD_RADIUS 209.5
#define PRINTER_RADIUS 209.5
#define DELTA_HOME_ON_POWER 0
#define STEP_COUNTER
//#define SOFTWARE_LEVELING
#define DELTASEGMENTS_PER_PRINTLINE 200
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 200
#define MAX_FEEDRATE_Y 200
#define MAX_FEEDRATE_Z 600
#define HOMING_FEEDRATE_X 40
#define HOMING_FEEDRATE_Y 40
#define HOMING_FEEDRATE_Z 120
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 999999
#define ZHOME_Y_POS 999999
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 1
#define DIRECTION_DELAY 50
#define STEP_DOUBLER_FREQUENCY 90000
#define ALLOW_QUADSTEPPING 1
#define DOUBLE_STEP_DELAY 1 // time in microseconds
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 2000
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 3000
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 3000
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 3000
#define MAX_JERK 20
#define MAX_ZJERK 0.3
#define PRINTLINE_CACHE_SIZE 32
#define MOVE_CACHE_LOW 10
#define USE_ADVANCE 0
#define BAUDRATE 115200
#define POWER_INVERTING 0
#define KILL_METHOD 1
#define ACK_WITH_LINENUMBER 1
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 1
#undef PS_ON_PIN
#define PS_ON_PIN -1
#define JSON_OUTPUT 1
/* ======== Servos =======
Control the servos with
#define FEATURE_SERVO 0
#define SERVO0_PIN 11
#define SERVO1_PIN -1
#define SERVO2_PIN -1
#define SERVO3_PIN -1
#define UI_SERVO_CONTROL 0
        #define FEATURE_WATCHDOG 1
#define Z_PROBE_Z_OFFSET 0
#define Z_PROBE_Z_OFFSET_MODE 1
#define UI_BED_COATING 1
#define FEATURE_Z_PROBE 1
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 1
#define Z_PROBE_X_OFFSET -39
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_SPEED 20
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_SWITCHING_DISTANCE 0.4
#define Z_PROBE_REPETITIONS 5
#define Z_PROBE_HEIGHT 2.03
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 -30
#define Z_PROBE_Y1 -30
#define Z_PROBE_X2 250
#define Z_PROBE_Y2 0
#define Z_PROBE_X3 0
#define Z_PROBE_Y3 250
#define BED_LEVELING_METHOD 1
#define BED_LEVELING_GRID_SIZE 4
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
#define SDSUPPORT 0
#undef SDCARDDETECT
#define SDCARDDETECT -1
#define SD_RUN_ON_STOP "G28"
#define ARC_SUPPORT 1
#define FEATURE_FAN_CONTROL 1
#define FEATURE_CONTROLLER 7
#define LANGUAGE_EN_ACTIVE 1
#define LANGUAGE_DE_ACTIVE 0
#define LANGUAGE_NL_ACTIVE 0
#define LANGUAGE_PT_ACTIVE 0
#define LANGUAGE_IT_ACTIVE 0
#define LANGUAGE_ES_ACTIVE 0
#define LANGUAGE_FI_ACTIVE 0
#define LANGUAGE_SE_ACTIVE 0
#define LANGUAGE_FR_ACTIVE 1
#define LANGUAGE_CZ_ACTIVE 0
#define LANGUAGE_PL_ACTIVE 0
#define LANGUAGE_TR_ACTIVE 0
#define UI_PRINTER_NAME "rh"
#define UI_PRINTER_COMPANY "HOME MADE"
#define UI_ANIMATION 0
#define FEATURE_UI_KEYS 0
#define UI_ENCODER_SPEED 1
#define UI_REVERSE_ENCODER 0
#define UI_KEY_BOUNCETIME 10
#define UI_KEY_MIN_REPEAT 50
#define FEATURE_BEEPER 1
#define CASE_LIGHTS_PIN -1
#define UI_START_SCREEN_DELAY 300
#define UI_SET_PRESET_EXTRUDER_TEMP_PLA   190
#define UI_SET_PRESET_EXTRUDER_TEMP_ABS   240
#define UI_SET_MIN_EXTRUDER_TEMP   170
#define NUM_MOTOR_DRIVERS 0
// Uncomment, to see detailed data for every move. Only for debugging purposes!
//#define DEBUG_QUEUE_MOVE
// Allows M111 to set bit 5 (16) which disables all commands except M111. This can be used
//to test your data througput or search for communication problems.
#define INCLUDE_DEBUG_COMMUNICATION 1
// This enables code to make M666 drop an ok, so you get problems with communication. It is to test host robustness.
#define DEBUG_COM_ERRORS
#define ALTERNATIVE_JERK
#define START_STEP_WITH_HIGH 0
  • RAPS128 need a different enable on state then most other drivers. Try inverting your enable on setting for them. A indication that it is wrong is that you can not move motor by hand when firmware starts since the "disabled" motor is powered.
  • Thank you for your fast reply.
    I tried to understund what you said but with no results... This is my first experience...
    If you can help me more please.
    As I need to know how to configure 2 stepper motors in Y axis and Z axis.
    Thank you.
    Kind Regards;
    RH
  • I mean these settings
    for extruder you have them 0 and for xyz 1 - if they use same drivers only one of them will work. So guess you need to set them 0 to enable.
  • Okey.Thank you.
    And what about how to configure two steppers for the same axis?
    Kind Regards;
    RH
  • Hello,
    I tried to redo the program with some comments.
    Just to put you in the picture, below all the components I have for my 3D printer:
    1) 5 NEMA23 Stepper motors ( One for the X-Axis // Two Motors for the Y-Axis and Two for the Z-Axis). Using ACME 8mm Lead Screw for the 5 Axis (X, Y, Y1, Z and Z1).
    2) RADDS + ARDUINO DUE.
    3) 4 RAPS128 (X,Y,Z,E0).
    4) 6 E-HALL (Three for Xmin,Ymin and Zmin // And three for Xmax, Y1max and Z1max).
    PS: My bed is fixed, doesn't move .
     Below my configuration. I don't know if there is any mistake in my configuration that stop me from running my Printer.Hope you will verify what I made and help me please. As I don't know how to fix my start point (0,0,0) (I don't want it in the center).
    I Thank you very much :)
    Kind Regards;
    RH
       This file is optimized for version 1.0.4dev
       as you expect.
    #include "pins.h"
    #define HOST_RESCUE 1
    #define BOARD_FAN_SPEED 255
    #define BOARD_FAN_MIN_SPEED 0
    #undef Y_MAX_PIN
    #define Y_MAX_PIN -1
    #undef Z_MAX_PIN
    #define Z_MAX_PIN -1
    #define BLUETOOTH_SERIAL  -1
    #define BLUETOOTH_BAUD  115200
    #define DRIVE_SYSTEM 0
    #define XAXIS_STEPS_PER_MM 20480           // 1/128 Ustep
    #define YAXIS_STEPS_PER_MM 5120            // 1/32 Ustep
    #define ZAXIS_STEPS_PER_MM 10240           // 1/64 Ustep
    #define EXT0_Y_OFFSET 0
    #define EXT0_STEPS_PER_MM 476.5            // Bondtech Extruder 1/16 Ustep
    #define EXT0_ENABLE_ON 0                   // RAPS128
    #define EXT0_MIRROR_STEPPER 0
    #define EXT0_INVERSE2 0
    #define EXT0_MAX_FEEDRATE 50
    #define EXT0_HEAT_MANAGER 2
    #define EXT0_PREHEAT_TEMP 190
    #define RETRACTION_LENGTH 3
    #define RETRACTION_LONG_LENGTH 13        //PT100 Ultimaker
    #define RETRACTION_SPEED 40
    #define RETRACTION_Z_LIFT 0
    #define FILAMENTCHANGE_Z_ADD  3
    #define JAM_METHOD 1
    #define TEMP_GAIN 0
    #define HEATER_PWM_SPEED 0
    #define COOLER_PWM_SPEED 0
    #define HEATED_BED_MAX_TEMP 130
    #define HEATED_BED_SENSOR_TYPE 13
    #define MAXTEMP 275
    #define LASER_WARMUP_TIME 0
    #define LASER_PWM_MAX 255
    #define LASER_WATT 2
    #define CNC_PWM_MAX 255
    #define CNC_RPM_MAX 8000
    #define CNC_SAFE_Z 150
    #define ENDSTOP_PULLUP_X_MIN true          // HALL-E Mounted in the X-AXIS
    #define ENDSTOP_PULLUP_Y_MIN true          // HALL-E Mounted in the Y-AXIS
    #define ENDSTOP_PULLUP_Z_MIN true          // HALL-E Mounted in the Z-AXIS
    #define ENDSTOP_PULLUP_Z2_MINMAX true      // HALL-E Mounted in the Z2-AXIS
    #define ENDSTOP_Z2_MINMAX_INVERTING true
    #define MINMAX_HARDWARE_ENDSTOP_Z2 true
    #define ENDSTOP_PULLUP_X_MAX true          // HALL-E Mounted in the X-AXIS
    #define ENDSTOP_PULLUP_Y_MAX true          // HALL-E Mounted in the Y2-AXIS
    #define ENDSTOP_X2_MAX_INVERTING true
    #define MAX_HARDWARE_ENDSTOP_Y2 true
    #define X2_MIN_PIN -1
    #define X2_MAX_PIN -1
    #define Y2_MIN_PIN -1
    #define Y2_MAX_PIN ORIG_Y_MAX_PIN
    #define Z2_MINMAX_PIN ORIG_Z_MAX_PIN
    #define DOOR_PIN -1
    #define DOOR_PULLUP 1
    #define DOOR_INVERTING 0
    #define ENDSTOP_X_BACK_MOVE 5
    #define ENDSTOP_Y_BACK_MOVE 5
    #define ENDSTOP_Z_BACK_MOVE 2
    #define ENDSTOP_X_BACK_ON_HOME 0
    #define ENDSTOP_Y_BACK_ON_HOME 0
    #define MOVE_X_WHEN_HOMED 0
    #define MOVE_Y_WHEN_HOMED 0
    #define MOVE_Z_WHEN_HOMED 0
    #define X_ENABLE_ON 0    // RAPS128
    #define Y_ENABLE_ON 0    // RAPS128
    #define Z_ENABLE_ON 0    // RAPS128
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define INVERT_X_DIR 0
    #define INVERT_X2_DIR 0
    #define INVERT_Y2_DIR 0
    #define INVERT_Z2_DIR 0
    #define INVERT_Z3_DIR 0
    #define INVERT_Z4_DIR 0
    #define Z_HOME_DIR -1
    #define X_MAX_LENGTH 250     // Dimension
    #define Y_MAX_LENGTH 250     // Dimension
    #define Z_MAX_LENGTH 250     // Dimension
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    #define PARK_POSITION_X 0
    #define PARK_POSITION_Y 0
    #define DISTORTION_LIMIT_TO 2
    // Delta settings
    #define MAX_FEEDRATE_Z 2
    #define HOMING_FEEDRATE_Z 2
    #define HOMING_ORDER HOME_ORDER_XYTZ
    #define ZHOME_PRE_RAISE 2
    #define ZHOME_HEAT_HEIGHT 10
    #define ZHOME_X_POS 125                 // I don't want my extruder to home in the center.So I don't know if the value I made is right or not!!
    #define ZHOME_Y_POS 125
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 80
    #define MAX_JERK 20
    #define DUAL_X_AXIS 0                    // 1 NEMA23 X-Stepper Motor
    #define DUAL_X_RESOLUTION 0
    #define FEATURE_TWO_YSTEPPER 1           // 2 NEMA23 (4A in total) Y-Stepper Motor for the same RAPS128
    #define Y2_STEP_PIN   ORIG_Y_STEP_PIN
    #define Y2_DIR_PIN    ORIG_Y_DIR_PIN
    #define Y2_ENABLE_PIN ORIG_Y_ENABLE_PIN
    #define FEATURE_TWO_ZSTEPPER 1            // 2 NEMA23 Z-Stepper Motor
    #define Z2_STEP_PIN   ORIG_Z_STEP_PIN
    #define Z2_DIR_PIN    ORIG_Z_DIR_PIN
    #define Z2_ENABLE_PIN ORIG_Z_ENABLE_PIN
    #define Z4_STEP_PIN   ORIG_E3_STEP_PIN
    #define Z4_DIR_PIN    ORIG_E3_DIR_PIN
    #define AUTOMATIC_POWERUP 0
    #undef PS_ON_PIN
    #define PS_ON_PIN ORIG_FAN_PIN
    #define JSON_OUTPUT 0
    #define MAX_FAN_PWM 255
            #define FEATURE_WATCHDOG 0
    #define EXTRUDER_IS_Z_PROBE 1
    #define Z_PROBE_ON_HIGH 0
    #define Z_PROBE_X_OFFSET 0
    #define Z_PROBE_SPEED 4
    #define Z_PROBE_REPETITIONS 2
    #define Z_PROBE_USE_MEDIAN 0
    #define Z_PROBE_DELAY 1
    #define Z_PROBE_X1 20
    #define Z_PROBE_Y1 20
    #define Z_PROBE_X2 230
    #define Z_PROBE_Y2 20
    #define Z_PROBE_X3 20
    #define Z_PROBE_Y3 230
    // RADDS LCD DISPLAY
    #define SDSUPPORT 1
    #undef SDCARDDETECT
    #undef SDCARDDETECTINVERTED
    #endif
    #define ADC_KEYPAD_PIN ORIG_PS_ON_PIN
    #define LANGUAGE_RU_ACTIVE 0
    #define UI_PRINTER_NAME "3D_RH"
    #define CASE_LIGHTS_PIN ORIG_SDCARDDETECT
    #define UI_SET_MAX_HEATED_BED_TEMP 130
    #endif
  • Best is to use our config tool on the webpage. There is a mirror y and mirror z axis and all relevant options pop up. Also easier to configure that way with better description of functions.
  • Do you mean this one?
     1
       4
       5
       6
       7
       8
       9
      10
      11
      12
      13
      14
      15
      16
      17
      18
      19
      20
      21
      22
      23
      24
      25
      26
      27
      28
      29
      30
      31
      32
      33
      34
      35
      36
      37
      38
      39
      40
      41
      42
      43
      44
      45
      46
      47
      48
      49
      50
      51
      52
      53
      54
      55
      56
      57
      58
      59
      60
      61
      62
      63
      64
      65
      66
      67
      68
      69
      70
      71
      72
      73
      74
      75
      76
      77
      78
      79
      80
      81
      82
      83
      84
      85
      86
      87
      88
      89
      90
      91
      92
      93
      94
      95
      96
      97
      98
      99
     100
     101
     102
     103
     104
     105
     106
     107
     108
     109
     110
     111
     112
     113
     114
     115
     116
     117
     118
     119
     120
     121
     122
     123
     124
     125
     126
     127
     128
     129
     130
     131
     132
     133
     134
     135
     136
     137
     138
     139
     140
     141
     142
     143
     144
     145
     146
     147
     148
     149
     150
     151
     152
     153
     154
     155
     156
     157
     158
     159
     160
     161
     162
     163
     164
     165
     166
     167
     168
     169
     170
     171
     172
     173
     174
     175
     176
     177
     178
     179
     180
     181
     182
     183
     184
     185
     186
     187
     188
     189
     190
     191
     192
     193
     194
     195
     196
     197
     198
     199
     200
     201
     202
     203
     204
     205
     206
     207
     208
     209
     210
     211
     212
     213
     214
     215
     216
     217
     218
     219
     220
     221
     222
     223
     224
     225
     226
     227
     228
     229
     230
     231
     232
     233
     234
     235
     236
     237
     238
     239
     240
     241
     242
     243
     244
     245
     246
     247
     248
     249
     250
     251
     252
     253
     254
     255
     256
     257
     258
     259
     260
     261
     262
     263
     264
     265
     266
     267
     268
     269
     270
     271
     272
     273
     274
     275
     276
     277
     278
     279
     280
     281
     282
     283
     284
     285
     286
     287
     288
     289
     290
     291
     292
     293
     294
     295
     296
     297
     298
     299
     300
     301
     302
     303
     304
     305
     306
     307
     308
     309
     310
     311
     312
     313
     314
     315
     316
     317
     318
     319
     320
     321
     322
     323
     324
     325
     326
     327
     328
     329
     330
     331
     332
     333
     334
     335
     336
     337
     338
     339
     340
     341
     342
     343
     344
     345
     346
     347
     348
     349
     350
     351
     352
     353
     354
     355
     356
     357
     358
     359
     360
     361
     362
     363
     364
     365
     366
     367
     368
     369
     370
     371
     372
     373
     374
     375
     376
     377
     378
     379
     380
     381
     382
     383
     384
     385
     386
     387
     388
     389
     390
     391
     392
     393
     394
     395
     396
     397
     398
     399
     400
     401
     402
     403
     404
     405
     406
     407
     408
     409
     410
     411
     412
     413
     414
     415
     416
     417
     418
     419
     420
     421
     422
     423
     424
     425
     426
     427
     428
     429
     430
     431
     432
     433
     434
     435
     436
     437
     438
     439
     440
     441
     442
     443
     444
     445
     446
     447
     448
     449
     450
     451
     452
     453
     454
     455
     456
     457
     458
     459
     460
     461
     462
     463
     464
     465
     466
     467
     468
     469
     470
     471
     472
     473
     474
     475
     476
     477
     478
     479
     480
     481
     482
     483
     484
     485
     486
     487
     488
     489
     490
     491
     492
     493
     494
     495
     496
     497
     498
     499
     500
     501
     502
     503
     504
     505
     506
     507
     508
     509
     510
     511
     512
     513
     514
     515
     516
     517
     518
     519
     520
     521
     522
     523
     524
     525
     526
     527
     528
     529
     530
     531
     532
     533
     534
     535
     536
     537
     538
     539
     540
     541
     542
     543
     544
     545
     546
     547
     548
     549
     550
     551
     552
     553
     554
     555
     556
     557
     558
     559
     560
     561
     562
     563
     564
     565
     566
     567
     568
     569
     570
     571
     572
     573
     574
     575
     576
     577
     578
     579
     580
     581
     582
     583
     584
     585
     586
     587
     588
     589
     590
     591
     592
     593
     594
     595
     596
     597
     598
     599
     600
     601
     602
     603
     604
     605
     606
     607
     608
     609
     610
     611
     612
     613
     614
     615
     616
     617
     618
     619
     620
     621
     622
     623
     624
     625
     626
     627
     628
     629
     630
     631
     632
     633
     634
     635
     636
     637
     638
     639
     640
     641
     642
     643
     644
     645
     646
     647
     648
     649
     650
     651
     652
     653
     654
     655
     656
     657
     658
     659
     660
     661
     662
     663
     664
     665
     666
     667
     668
     669
     670
     671
     672
     673
     674
     675
     676
     677
     678
     679
     680
     681
     682
     683
     684
     685
     686
     687
     688
     689
     690
     691
     692
     693
     694
     695
     696
     697
     698
     699
     700
     701
     702
     703
     704
     705
     706
     707
     708
     709
     710
     711
     712
     713
     714
     715
     716
     717
     718
     719
     720
     721
     722
     723
     724
     725
     726
     727
     728
     729
     730
     731
     732
     733
     734
     735
     736
     737
     738
     739
     740
     741
     742
     743
     744
     745
     746
     747
     748
     749
     750
     751
     752
     753
     754
     755
     756
     757
     758
     759
     760
     761
     762
     763
     764
     765
     766
     767
     768
     769
     770
     771
     772
     773
     774
     775
     776
     777
     778
     779
     780
     781
     782
     783
     784
     785
     786
     787
     788
     789
     790
     791
     792
     793
     794
     795
     796
     797
     798
     799
     800
     801
     802
     803
     804
     805
     806
     807
     808
     809
     810
     811
     812
     813
     814
     815
     816
     817
     818
     819
     820
     821
     822
     823
     824
     825
     826
     827
     828
     829
     830
     831
     832
     833
     834
     835
     836
     837
     838
     839
     840
     841
     842
     843
     844
     845
     846
     847
     848
     849
     850
     851
     852
     853
     854
     855
     856
     857
     858
     859
     860
     861
     862
     863
     864
     865
     866
     867
     868
     869
     870
     871
     872
     873
     874
     875
     876
     877
     878
     879
     880
     881
     882
     883
     884
     885
     886
     887
     888
     889
     890
     891
     892
     893
     894
     895
     896
     897
     898
     899
     900
     901
     902
     903
     904
     905
     906
     907
     908
     909
     910
     911
     912
     913
     914
     915
     916
     917
     918
     919
     920
     921
     922
     923
     924
     925
     926
     927
     928
     929
     930
     931
     932
     933
     934
     935
     936
     937
     938
     939
     940
     941
     942
     943
     944
     945
     946
     947
     948
     949
     950
     951
     952
     953
     954
     955
     956
     957
     958
     959
     960
     961
     962
     963
     964
     965
     966
     967
     968
     969
     970
     971
     972
     973
     974
     975
     976
     977
     978
     979
     980
     981
     982
     983
     984
     985
     986
     987
     988
     989
     990
     991
     992
     993
     994
     995
     996
     997
     998
     999
    1000
    1001
    1002
    1003
    1004
    1005
    1006
    1007
    1008
    1009
    1010
    1011
    1012
    1013
    1014
    1015
    1016
    1017
    1018
    1019
    1020
    1021
    1022
    1023
    1024
    1025
    1026
    1027
    1028
    1029
    1030
    1031
    1032
    1033
    1034
    1035
    1036
    1037
    1038
    1039
    1040
    1041
    1042
    1043
    1044
    1045
    1046
    1047
    1048
    1049
    1050
    1051
    1052
    1053
    1054
    1055
    1056
    1057
    1058
    1059
    1060
    1061
    1062
    1063
    1064
    1065
    1066
    1067
    1068
    1069
    1070
    1071
    1072
    1073
    1074
    1075
    1076
    1077
    1078
    1079
    1080
    1081
    1082
    1083
    1084
    1085
    1086
    1087
    1088
    1089
    1090
    1091
    1092
    1093
    1094
    1095
    1096
    1097
    1098
    1099
    1100
    1101
    1102
    1103
    1104
    1105
    1106
    1107
    1108
    1109
    1110
    1111
    1112
    1113
    1114
    1115
    1116
    1117
    1118
    1119
    1120
    1121
    1122
    1123
    1124
    1125
    1126
    1127
    1128
    1129
    1130
    1131
    1132
    1133
    1134
    1135
    1136
    1137
    1138
    1139
    1140
    1141
    1142
    1143
    1144
    1145
    1146
    1147
    1148
    1149
    1150
    1151
    1152
    1153
    1154
    1155
    1156
    1157
    1158
    1159
    1160
    1161
    1162
    1163
    1164
    1165
    1166
    1167
    1168
    1169
    1170
    1171
    1172
    1173
    1174
    1175
    1176
    1177
    1178
       generator: http://www.repetier.com/firmware/v092/
       as you expect.
    #define NUM_EXTRUDER 2
    #include "pins.h"
    #define XAXIS_STEPS_PER_MM 80
    #define YAXIS_STEPS_PER_MM 80
    #define ZAXIS_STEPS_PER_MM 80
    #define EXT0_Y_OFFSET -1040
    #define EXT0_STEPS_PER_MM 310
    #define EXT0_ENABLE_ON 1
    #define EXT1_Y_OFFSET 1040
    #define MAXTEMP 275
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define X_MAX_LENGTH 200
    #define Y_MAX_LENGTH 200
    #define Z_MAX_LENGTH 590
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    #define DISTORTION_XMAX 190
    #define DISTORTION_YMAX 190
    // Delta settings
    #define MAX_JERK 20
    #undef PS_ON_PIN
    #define Z_PROBE_X1 -120
    #define Z_PROBE_Y1 -120
    #define Z_PROBE_X2 120
    #define Z_PROBE_Y3 120
    #define SDSUPPORT 0
    #undef SDCARDDETECT
    #endif
    #define LANGUAGE_DE_ACTIVE 1
    #define LANGUAGE_NL_ACTIVE 1
    #define LANGUAGE_PT_ACTIVE 1
    #define LANGUAGE_IT_ACTIVE 1
    #define LANGUAGE_ES_ACTIVE 1
    #define LANGUAGE_FI_ACTIVE 1
    #define LANGUAGE_SE_ACTIVE 1
    #define LANGUAGE_CZ_ACTIVE 1
    #define LANGUAGE_PL_ACTIVE 1
    #define LANGUAGE_TR_ACTIVE 1
    #define UI_PRINTER_NAME "DeltaTower"
    #define UI_PRINTER_COMPANY "Hypecask"
    #endif
        "editMode": 2,
        "processor": 1,
        "baudrate": 115200,
        "bluetoothSerial": 101,
        "bluetoothBaudrate": 250000,
        "xStepsPerMM": 80,
        "yStepsPerMM": 80,
        "zStepsPerMM": 80,
        "xInvert": "1",
        "xInvertEnable": "1",
        "eepromMode": 1,
        "yInvert": "0",
        "yInvertEnable": "1",
        "zInvert": "0",
        "zInvertEnable": "1",
        "extruder": [
                "id": 0,
                "heatManager": 3,
                "pidDriveMin": 40,
                "pidDriveMax": 210,
                "pidMax": 255,
                "sensorType": 1,
                "sensorPin": "TEMP_0_PIN",
                "heaterPin": "HEATER_0_PIN",
                "maxFeedrate": 100,
                "startFeedrate": 40,
                "invert": "0",
                "invertEnable": "1",
                "acceleration": 10000,
                "watchPeriod": 1,
                "pidP": 8,
                "pidI": 2,
                "pidD": 40,
                "advanceK": 0,
                "advanceL": 0,
                "waitRetractTemp": 150,
                "waitRetractUnits": 0,
                "waitRetract": 0,
                "stepsPerMM": 310,
                "coolerPin": -1,
                "coolerSpeed": 255,
                "selectCommands": "",
                "deselectCommands": "",
                "xOffset": 0,
                "yOffset": -13,
                "zOffset": 0,
                "xOffsetSteps": 0,
                "yOffsetSteps": -1040,
                "zOffsetSteps": 0,
                "stepper": {
                    "name": "Extruder 0",
                    "step": "ORIG_E0_STEP_PIN",
                    "dir": "ORIG_E0_DIR_PIN",
                "advanceBacklashSteps": 0,
                "decoupleTestPeriod": 12,
                "jamPin": -1,
                "jamPullup": "0",
                "inverse": 0
                "id": 1,
                "heatManager": 3,
                "pidDriveMin": 40,
                "pidDriveMax": 210,
                "pidMax": 255,
                "sensorType": 1,
                "sensorPin": "TEMP_2_PIN",
                "heaterPin": "HEATER_2_PIN",
                "maxFeedrate": 100,
                "invert": "0",
                "watchPeriod": 1,
                "pidP": 8,
                "pidI": 2,
                "pidD": 40,
                "advanceK": 0,
                "advanceL": 0,
                "waitRetract": 0,
                "stepsPerMM": 310,
                "coolerPin": -1,
                "coolerSpeed": 255,
                "xOffset": 0,
                "yOffset": 13,
                "zOffset": 0,
                "xOffsetSteps": 0,
                "yOffsetSteps": 1040,
                "zOffsetSteps": 0,
                "stepper": {
                    "name": "Extruder 1",
                    "step": "ORIG_E1_STEP_PIN",
                    "dir": "ORIG_E1_DIR_PIN",
                "jamPin": -1,
                "jamPullup": "0",
                "inverse": 0
        "uiLanguage": 1,
        "uiController": 0,
        "xMinEndstop": 0,
        "yMinEndstop": 0,
        "zMinEndstop": 0,
        "xMaxEndstop": 3,
        "yMaxEndstop": 3,
        "zMaxEndstop": 3,
        "motherboard": 402,
        "driveSystem": 3,
        "xMaxSpeed": 200,
        "xHomingSpeed": 40,
        "xTravelAcceleration": 3000,
        "xPrintAcceleration": 1000,
        "yMaxSpeed": 200,
        "yHomingSpeed": 40,
        "yTravelAcceleration": 3000,
        "yPrintAcceleration": 1000,
        "zMaxSpeed": 600,
        "zHomingSpeed": 120,
        "zTravelAcceleration": 3000,
        "zPrintAcceleration": 2000,
        "xMotor": {
            "name": "X motor",
            "step": "ORIG_X_STEP_PIN",
            "dir": "ORIG_X_DIR_PIN",
            "enable": "ORIG_X_ENABLE_PIN"
        "yMotor": {
            "name": "Y motor",
            "step": "ORIG_Y_STEP_PIN",
            "dir": "ORIG_Y_DIR_PIN",
            "enable": "ORIG_Y_ENABLE_PIN"
        "zMotor": {
            "name": "Z motor",
            "step": "ORIG_Z_STEP_PIN",
            "dir": "ORIG_Z_DIR_PIN",
            "enable": "ORIG_Z_ENABLE_PIN"
        "enableBacklash": "0",
        "backlashX": 0,
        "backlashY": 0,
        "backlashZ": 0,
        "stepperInactiveTime": 360,
        "maxInactiveTime": 0,
        "xMinPos": 0,
        "yMinPos": 0,
        "zMinPos": 0,
        "xLength": 200,
        "yLength": 200,
        "zLength": 590,
        "alwaysCheckEndstops": "1",
        "disableX": "0",
        "disableY": "0",
        "disableZ": "0",
        "disableE": "0",
        "xHomeDir": -1,
        "yHomeDir": -1,
        "zHomeDir": 1,
        "xEndstopBack": 20,
        "yEndstopBack": 20,
        "zEndstopBack": 20,
        "deltaSegmentsPerSecondPrint": 600,
        "deltaSegmentsPerSecondTravel": 400,
        "deltaDiagonalRod": 445,
        "deltaHorizontalRadius": 209.5,
        "deltaAlphaA": 210,
        "deltaAlphaB": 330,
        "deltaAlphaC": 90.123,
        "deltaDiagonalCorrA": 0,
        "deltaDiagonalCorrB": 0,
        "deltaDiagonalCorrC": 0,
        "deltaMaxRadius": 200,
        "deltaRadiusCorrA": 0,
        "deltaRadiusCorrB": 0,
        "deltaRadiusCorrC": -0.05,
        "deltaXOffsetSteps": 0,
        "deltaYOffsetSteps": 0,
        "deltaZOffsetSteps": 0,
        "deltaSegmentsPerLine": 200,
        "stepperHighDelay": 1,
        "directionDelay": 50,
        "stepDoublerFrequency": 90000,
        "allowQuadstepping": "1",
        "doubleStepDelay": 1,
        "maxJerk": 20,
        "maxZJerk": 0.3,
        "moveCacheSize": 32,
        "moveCacheLow": 10,
        "lowTicksPerMove": 250000,
        "enablePowerOnStartup": "1",
        "echoOnExecute": "1",
        "sendWaits": "1",
        "ackWithLineNumber": "1",
        "killMethod": 1,
        "useAdvance": "0",
        "useQuadraticAdvance": "0",
        "powerInverting": 0,
        "mirrorX": 0,
        "mirrorXMotor": {
        "mirrorY": 0,
        "mirrorYMotor": {
        "mirrorZ": 0,
        "mirrorZMotor": {
        "mirrorZ3": "0",
        "mirrorZ3Motor": {
            "name": "Extruder 2",
            "step": "ORIG_E2_STEP_PIN",
            "dir": "ORIG_E2_DIR_PIN",
        "dittoPrinting": "0",
        "featureServos": "0",
        "servo0Pin": 11,
        "servo1Pin": -1,
        "servo2Pin": -1,
        "servo3Pin": -1,
        "featureWatchdog": "1",
        "hasHeatedBed": "1",
        "enableZProbing": "1",
        "extrudeMaxLength": 160,
        "featureController": 7,
        "uiPrinterName": "DeltaTower",
        "uiPrinterCompany": "Hypecask",
        "uiPagesDuration": 4000,
        "uiAnimation": "0",
        "uiDisablePageswitch": "1",
        "uiAutoReturnAfter": 30000,
        "featureKeys": "0",
        "uiEncoderSpeed": 1,
        "uiReverseEncoder": "0",
        "uiKeyBouncetime": 10,
        "uiKeyFirstRepeat": 500,
        "uiKeyReduceRepeat": 50,
        "uiKeyMinRepeat": 50,
        "featureBeeper": "1",
        "uiPresetBedTempPLA": 60,
        "uiPresetBedABS": 110,
        "uiPresetExtruderPLA": 190,
        "uiPresetExtruderABS": 240,
        "uiMinHeatedBed": 30,
        "uiMaxHeatedBed": 120,
        "uiMinEtxruderTemp": 170,
        "uiMaxExtruderTemp": 260,
        "uiExtruderFeedrate": 2,
        "maxBedTemperature": 120,
        "bedSensorType": 1,
        "bedSensorPin": "TEMP_1_PIN",
        "bedHeatManager": 0,
        "bedUpdateInterval": 5000,
        "bedPidDriveMin": 80,
        "bedPidDriveMax": 255,
        "bedPidP": 196,
        "bedPidI": 33,
        "bedPidD": 290,
        "bedPidMax": 255,
        "bedDecoupleTestPeriod": 500,
        "caseLightPin": -1,
        "caseLightDefaultOn": "1",
        "bedSkipIfWithin": 3,
        "gen1T0": 25,
        "gen1R0": 100000,
        "gen1Beta": 4036,
        "gen1MinTemp": -20,
        "gen1MaxTemp": 300,
        "gen1R1": 0,
        "gen1R2": 4700,
        "gen2T0": 25,
        "gen2R0": 100000,
        "gen2Beta": 4036,
        "gen2MinTemp": -20,
        "gen2MaxTemp": 300,
        "gen2R1": 0,
        "gen2R2": 4700,
        "gen3T0": 25,
        "gen3R0": 100000,
        "gen3Beta": 4036,
        "gen3MinTemp": -20,
        "gen3MaxTemp": 300,
        "gen3R1": 0,
        "gen3R2": 4700,
        "userTable0": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "userTable1": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "userTable2": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "tempHysteresis": 0,
        "pidControlRange": 20,
        "skipM109Within": 2,
        "extruderFanCoolTemp": 50,
        "minTemp": 150,
        "maxTemp": 275,
        "minDefectTemp": -10,
        "maxDefectTemp": 290,
        "arcSupport": "1",
        "forceChecksum": "0",
        "sdExtendedDir": "1",
        "featureFanControl": "1",
        "fanPin": "ORIG_FAN_PIN",
        "featureFan2Control": "0",
        "fan2Pin": "ORIG_FAN2_PIN",
        "fanThermoPin": -1,
        "fanThermoMinPWM": 128,
        "fanThermoMaxPWM": 255,
        "fanThermoMinTemp": 45,
        "fanThermoMaxTemp": 60,
        "fanThermoThermistorPin": -1,
        "fanThermoThermistorType": 1,
        "scalePidToMax": 0,
        "zProbeBedDistance": 10,
        "zProbePullup": "0",
        "zProbeOnHigh": "1",
        "zProbeXOffset": -39,
        "zProbeYOffset": 0,
        "zProbeWaitBeforeTest": "0",
        "zProbeSpeed": 20,
        "zProbeXYSpeed": 150,
        "zProbeHeight": 2.03,
        "zProbeStartScript": "",
        "zProbeFinishedScript": "",
        "featureAutolevel": "1",
        "zProbeX1": -120,
        "zProbeY1": -120,
        "zProbeX2": 120,
        "zProbeY2": 0,
        "zProbeX3": 0,
        "zProbeY3": 120,
        "zProbeSwitchingDistance": 0.4,
        "zProbeRepetitions": 5,
        "sdSupport": "0",
        "sdCardDetectPin": -1,
        "sdCardDetectInverted": "0",
        "uiStartScreenDelay": 300,
        "xEndstopBackMove": 3,
        "yEndstopBackMove": 3,
        "zEndstopBackMove": 3,
        "xEndstopRetestFactor": 3,
        "yEndstopRetestFactor": 3,
        "zEndstopRetestFactor": 3,
        "xMinPin": "ORIG_X_MIN_PIN",
        "yMinPin": "ORIG_Y_MIN_PIN",
        "zMinPin": "ORIG_Z_MIN_PIN",
        "xMaxPin": "ORIG_X_MAX_PIN",
        "yMaxPin": "ORIG_Y_MAX_PIN",
        "zMaxPin": "ORIG_Z_MAX_PIN",
        "deltaHomeOnPower": "0",
        "fanBoardPin": -1,
        "heaterPWMSpeed": 1,
        "featureBabystepping": "1",
        "babystepMultiplicator": 1,
        "pdmForHeater": "0",
        "pdmForCooler": "0",
        "psOn": -1,
        "mixingExtruder": "0",
        "featureAxisComp": "0",
        "axisCompTanXY": 0,
        "axisCompTanXZ": 0,
        "axisCompTanYZ": 0,
        "retractOnPause": 7,
        "pauseStartCommands": "",
        "pauseEndCommands": "",
        "distortionCorrection": "1",
        "distortionCorrectionPoints": 7,
        "distortionCorrectionR": 140,
        "distortionPermanent": "1",
        "distortionUpdateFrequency": 12,
        "distortionEndDegrade": 2,
        "distortionExtrapolateCorners": "1",
        "distortionXMin": 10,
        "distortionXMax": 190,
        "distortionYMin": 10,
        "distortionYMax": 190,
        "sdRunOnStop": "G28",
        "featureRetraction": "1",
        "autoretractEnabled": "0",
        "retractionLength": 7,
        "retractionLongLength": 20,
        "retractionSpeed": 80,
        "retractionZLift": 1,
        "retractionUndoSpeed": 50,
        "filamentChangeXPos": 0,
        "filamentChangeYPos": -180,
        "filamentChangeZAdd": 10,
        "filamentChangeRehome": 2,
        "filamentChangeShortRetract": 20,
        "fanKickstart": 200,
        "servo0StartPos": -1,
        "servo1StartPos": -1,
        "servo2StartPos": -1,
        "servo3StartPos": -1,
        "uiDynamicEncoderSpeed": "1",
        "uiServoControl": 0,
        "killIfSensorDefect": "0",
        "jamSteps": 220,
        "jamSlowdownSteps": 320,
        "jamSlowdownTo": 70,
        "jamErrorSteps": 500,
        "jamMinSteps": 10,
        "jamAction": 1,
        "primaryPort": 1,
        "numMotorDrivers": 0,
        "motorDrivers": [
                "t": "None",
                "s": "",
                "invertEnable": "0",
                "invertDirection": "0",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1
        "manualConfig": "\/\/ Uncomment, to see detailed data for every move. Only for debugging purposes! \n\/\/#define DEBUG_QUEUE_MOVE\n\/\/ Allows M111 to set bit 5 (16) which disables all commands except M111. This can be used\n\/\/to test your data througput or search for communication problems. \n#define INCLUDE_DEBUG_COMMUNICATION 1\n\/\/ This enables code to make M666 drop an ok, so you get problems with communication. It is to test host robustness. \n#define DEBUG_COM_ERRORS\n#define ALTERNATIVE_JERK\n#define START_STEP_WITH_HIGH 0",
        "zHomeMinTemperature": 0,
        "zHomeXPos": 999999,
        "zHomeYPos": 999999,
        "zHomeHeatHeight": 20,
        "zHomeHeatAll": "1",
        "zProbeZOffsetMode": 1,
        "zProbeZOffset": 0,
        "uiBedCoating": "1",
        "langEN": "1",
        "langDE": "1",
        "langNL": "1",
        "langPT": "1",
        "langIT": "1",
        "langES": "1",
        "langFI": "1",
        "langSE": "1",
        "langFR": "1",
        "langCZ": "1",
        "langPL": "1",
        "langTR": "1",
        "accelerationFactorTop": 100,
        "bendingCorrectionA": 0,
        "bendingCorrectionB": 0,
        "bendingCorrectionC": 0,
        "supportLaser": "0",
        "laserPin": -1,
        "laserOnHigh": "1",
        "defaultPrinterMode": 0,
        "supportCNC": "0",
        "cncWaitOnEnable": 300,
        "cncWaitOnDisable": 0,
        "cncEnablePin": -1,
        "cncEnableWith": "1",
        "cncDirectionPin": -1,
        "cncDirectionCW": "1",
        "startupGCode": "",
        "jsonOutput": "1",
        "bedLevelingMethod": 1,
        "bedCorrectionMethod": 0,
        "bedLevelingGridSize": 4,
        "bedLevelingRepetitions": 5,
        "bedMotor1X": 0,
        "bedMotor1Y": 0,
        "bedMotor2X": 200,
        "bedMotor2Y": 0,
        "bedMotor3X": 100,
        "bedMotor3Y": 200,
        "zProbeRequiresHeating": "0",
        "zProbeMinTemperature": 150,
        "maxHalfstepInterval": 1999,
        "hasMAX6675": false,
        "hasMAX31855": false,
        "hasGeneric1": false,
        "hasGeneric2": false,
        "hasGeneric3": false,
        "hasUser0": false,
        "hasUser1": false,
        "hasUser2": false,
  • Yes, that is what I mean but you have not activated the mirror function as config has
        "mirrorY": 0,
        "mirrorYMotor": {
        "mirrorZ": 0,
        "mirrorZMotor": {
    and that is why the options are not in the config part.
  • Okay. Thank you very much for your help, I appreciate it.
    I'll Try it if it works.
    Have a nice day.
    Kind Regards;
    RH
  • Hello again,
    I've tested the program, and this is what happens:
    X: Makes a strange sound, and it moves only one step and stop.
    Y: The motors just vibrate without turning.
    Z: After switching the cables, it works. But when I started testing Y axis, and switched to Z axis, and here nothings works.
    The problem is that when I tried to retest Z axis, The Y axis that start vibrating without turning!
    And I really don't understand why :/
    I switched the cables many times, but with no results.
    PS: X axis always make a sound when I try to move the two other axis.
    Any help please :(
    Thank you.
    Kind Regards;
    RH
    This is all what I did:
    #include "pins.h"
    #undef Y_MAX_PIN
    #define EXT0_Y_OFFSET -120
    #define TEMP_GAIN 0
    #define MAXTEMP 275
    #define ENDSTOP_PULLUP_Y_MIN false
    #define ENDSTOP_PULLUP_Y2_MAX false
    #define ENDSTOP_Y2_MAX_INVERTING true
    #define Z2_MINMAX_PIN -1
    #define DOOR_PIN -1
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define PREVENT_Z_DISABLE_ON_STEPPER_TIMEOUT
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    // Delta settings
    #define MAX_JERK 20
    #undef PS_ON_PIN
    #define EXTRUDER_IS_Z_PROBE 0
    #define Z_PROBE_DELAY 0
    #define SDSUPPORT 1
    #undef SDCARDDETECT
    #endif
    #define UI_PRINTER_NAME "RH-3DP"
    #define UI_SPEEDDEPENDENT_POSITIONING 1
    #define NUM_MOTOR_DRIVERS 0 #endif
  • Work logical, check what you connected and how. Best is to make motors loose from belts in your case so you see which move and in which direction. If I see
    I ask myself what you are doing. The original y and z motors already use these so why reuse them again for the second motor? That is screaming for problems - the second will not move. Here you need to select the motor socket where you connected them. E1 and E2 are likely the correct choice. Also always check steps per mm to match your microsteps, check jerk is not too high as well as acceleration.
  • Hei,
    I've took ur program and all I changed is the steps/mm I put (X:10240; Y:5120; Z: 10240, E:476,5), the type of the sensor and mirrors of Y and Z axies.
    Z: is okey.
    Y: It makes a sound like it's turning but no move not rotation.
    X: tries to make one step but no move no rotation...
    I can't find out why! Because I saw here someone that has used ur program and it was all okey for him.
    I don't know what are the mistakes I made!!I've switched cables many times, but no results.
    PS:
    I'm using Repetier-Firmware configuration tool for version 1.0.5dev.
    Sorry for all this questions and thank you very much.
    Kind Regards.
    RH;
       as you expect.
    #include "pins.h"
    #define XAXIS_STEPS_PER_MM 10240
    #define EXT0_Y_OFFSET -133120
    #define TEMP_GAIN 0
    #define MAXTEMP 275
    #define Y2_MAX_PIN -1
    #define DOOR_PIN -1
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    // Delta settings
    #define ZHOME_PRE_RAISE 0
    #define MAX_JERK 20
    #undef PS_ON_PIN
    #define SDSUPPORT 1
    #undef SDCARDDETECT
    #endif
    #define ADC_KEYPAD_PIN -1
    #define UI_PRINTER_NAME "RH_3D"
    #define UI_PRINTER_COMPANY "HOMEMADE"
    #endif
        "editMode": 2,
        "processor": 1,
        "baudrate": 115200,
        "xStepsPerMM": 10240,
        "yStepsPerMM": 5120,
        "zStepsPerMM": 10240,
        "xInvert": "1",
        "x2Invert": 0,
        "eepromMode": 1,
        "yInvert": "0",
        "y2Invert": 0,
        "zInvert": "0",
        "z2Invert": 0,
        "z3Invert": 0,
        "z4Invert": 0,
        "extruder": [
                "id": 0,
                "heatManager": 3,
                "pidDriveMin": 40,
                "pidDriveMax": 210,
                "pidMax": 255,
                "sensorType": 13,
                "maxFeedrate": 100,
                "invert": "0",
                "watchPeriod": 1,
                "pidP": 8,
                "pidI": 2,
                "pidD": 40,
                "advanceK": 0,
                "advanceL": 0,
                "waitRetract": 0,
                "stepsPerMM": 476.5,
                "coolerPin": -1,
                "coolerSpeed": 255,
                "xOffset": 0,
                "yOffset": -13,
                "zOffset": 0,
                "xOffsetSteps": 0,
                "yOffsetSteps": -133120,
                "zOffsetSteps": 0,
                "stepper": {
                "jamPin": -1,
                "jamPullup": "0",
                "mirror": "0",
                "invert2": "0",
                "stepper2": {
                "preheat": 190,
                "inverse": 0
        "uiLanguage": 1,
        "uiController": 0,
        "xMinEndstop": 3,
        "yMinEndstop": 3,
        "zMinEndstop": 3,
        "xMaxEndstop": 3,
        "yMaxEndstop": 3,
        "zMaxEndstop": 3,
        "x2MinEndstop": 0,
        "y2MinEndstop": 0,
        "x2MaxEndstop": 0,
        "y2MaxEndstop": 0,
        "motherboard": 402,
        "driveSystem": 3,
        "xMaxSpeed": 200,
        "xHomingSpeed": 40,
        "yMaxSpeed": 200,
        "yHomingSpeed": 40,
        "zMaxSpeed": 600,
        "xMotor": {
            "name": "X motor",
        "yMotor": {
            "name": "Y motor",
        "zMotor": {
            "name": "Z motor",
        "backlashX": 0,
        "backlashY": 0,
        "backlashZ": 0,
        "xMinPos": 0,
        "yMinPos": 0,
        "zMinPos": 0,
        "xLength": 200,
        "yLength": 200,
        "zLength": 590,
        "disableX": "0",
        "disableY": "0",
        "disableZ": "0",
        "disableE": "0",
        "xHomeDir": -1,
        "yHomeDir": -1,
        "zHomeDir": 1,
        "xEndstopBack": 20,
        "yEndstopBack": 20,
        "zEndstopBack": 20,
        "deltaAlphaA": 210,
        "deltaAlphaB": 330,
        "maxJerk": 20,
        "maxZJerk": 0.3,
        "moveCacheLow": 10,
        "sendWaits": "1",
        "killMethod": 1,
        "useAdvance": "0",
        "mirrorX": 0,
        "mirrorXMotor": {
        "mirrorY": "1",
        "mirrorYMotor": {
        "mirrorZ": "1",
        "mirrorZMotor": {
        "mirrorZ3": "0",
        "mirrorZ3Motor": {
        "mirrorZ4": "0",
        "mirrorZ4Motor": {
            "name": "Extruder 3",
            "step": "ORIG_E3_STEP_PIN",
            "dir": "ORIG_E3_DIR_PIN",
        "servo0Pin": 11,
        "servo1Pin": -1,
        "servo2Pin": -1,
        "servo3Pin": -1,
        "uiPrinterName": "RH_3D",
        "uiPrinterCompany": "HOMEMADE",
        "uiHeadline": "",
        "featureKeys": "0",
        "maxBedTemperature": 130,
        "bedSensorType": 13,
        "bedPreheat": 55,
        "bedPidP": 196,
        "bedPidI": 33,
        "bedPidD": 290,
        "bedPidMax": 255,
        "caseLightPin": -1,
        "gen1T0": 25,
        "gen1R0": 100000,
        "gen1Beta": 4036,
        "gen1MinTemp": -20,
        "gen1MaxTemp": 300,
        "gen1R1": 0,
        "gen1R2": 4700,
        "gen2T0": 25,
        "gen2R0": 100000,
        "gen2Beta": 4036,
        "gen2MinTemp": -20,
        "gen2MaxTemp": 300,
        "gen2R1": 0,
        "gen2R2": 4700,
        "gen3T0": 25,
        "gen3R0": 100000,
        "gen3Beta": 4036,
        "gen3MinTemp": -20,
        "gen3MaxTemp": 300,
        "gen3R1": 0,
        "gen3R2": 4700,
        "userTable0": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "userTable1": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "userTable2": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "minTemp": 150,
        "maxTemp": 275,
        "arcSupport": "1",
        "fanThermoPin": -1,
        "fanThermoThermistorType": 13,
        "scalePidToMax": 0,
        "zProbeDisableHeaters": "0",
        "zProbeYOffset": 0,
        "zProbeSpeed": 20,
        "zProbeX1": -120,
        "zProbeY1": -120,
        "zProbeX2": 120,
        "zProbeY2": 0,
        "zProbeX3": 0,
        "zProbeY3": 120,
        "zProbeMedian": "0",
        "zProbeEveryPoint": "",
        "sdSupport": "1",
        "x2MinPin": -1,
        "y2MinPin": -1,
        "x2MaxPin": -1,
        "y2MaxPin": -1,
        "fanBoardPin": -1,
        "psOn": -1,
        "axisCompTanXY": 0,
        "axisCompTanXZ": 0,
        "axisCompTanYZ": 0,
        "jamSteps": 220,
        "jamMinSteps": 10,
        "jamAction": 1,
        "jamMethod": 1,
        "primaryPort": 1,
        "motorDrivers": [
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "invertEndstop": "0",
                "minEndstop": "1",
                "endstopPullup": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
        "zProbeZOffset": 0,
        "zProbeDelay": 0,
        "langEN": "1",
        "langDE": "1",
        "langNL": "1",
        "langPT": "1",
        "langIT": "1",
        "langES": "1",
        "langFI": "1",
        "langSE": "1",
        "langFR": "1",
        "langCZ": "1",
        "langPL": "1",
        "langTR": "1",
        "langRU": "0",
        "laserPin": -1,
        "laserOnHigh": "1",
        "laserWarmupTime": 0,
        "laserPwmMax": 255,
        "laserWatt": 2,
        "supportCNC": "0",
        "cncEnablePin": -1,
        "cncPwmMax": 255,
        "cncRpmMax": 8000,
        "cncSafeZ": 150,
        "startupGCode": "",
        "jsonOutput": "1",
        "bedMotor1X": 0,
        "bedMotor1Y": 0,
        "bedMotor2X": 200,
        "bedMotor2Y": 0,
        "bedMotor3X": 100,
        "bedMotor3Y": 200,
        "adcKeypadPin": -1,
        "sharedExtruderHeater": "0",
        "extruderSwitchXYSpeed": 100,
        "dualXAxis": "0",
        "boardFanSpeed": 255,
        "keepAliveInterval": 2000,
        "moveXWhenHomed": "0",
        "moveYWhenHomed": "0",
        "moveZWhenHomed": "0",
        "preheatTime": 30000,
        "multiZEndstopHoming": "0",
        "z2MinMaxPin": -1,
        "z2MinMaxEndstop": 0,
        "extruderIsZProbe": "0",
        "boardFanMinSpeed": 0,
        "doorPin": -1,
        "doorEndstop": 0,
        "zhomePreRaise": 0,
        "zhomePreRaiseDistance": 10,
        "dualXResolution": "0",
        "x2axisStepsPerMM": 100,
        "coolerPWMSpeed": 0,
        "maxFanPWM": 255,
        "raiseZOnToolchange": 0,
        "distortionLimitTo": 2,
        "automaticPowerup": 0,
        "hasTMC2130": "0",
        "TMC2130Sensorless": "0",
        "TMC2130Steathchop": "1",
        "TMC2130Interpolate256": "1",
        "TMC2130PWMAmpl": 255,
        "TMC2130PWMGrad": 1,
        "TMC2130PWMAutoscale": "1",
        "TMC2130PWMFreq": 2,
        "TMC2130CSX": -1,
        "TMC2130CSY": -1,
        "TMC2130CSZ": -1,
        "TMC2130CSE0": -1,
        "TMC2130CSE1": -1,
        "TMC2130CSE2": -1,
        "TMC2130CSE3": -1,
        "TMC2130CSE4": -1,
        "TMC2130CurrentX": 1000,
        "TMC2130CurrentY": 1000,
        "TMC2130CurrentZ": 1000,
        "TMC2130CurrentE0": 1000,
        "TMC2130CurrentE1": 1000,
        "TMC2130CurrentE2": 1000,
        "TMC2130CurrentE3": 1000,
        "TMC2130CurrentE4": 1000,
        "microstepX": 16,
        "microstepY": 16,
        "microstepZ": 16,
        "microstepE0": 16,
        "microstepE1": 16,
        "microstepE2": 16,
        "microstepE3": 16,
        "microstepE4": 16,
        "parkPosX": 0,
        "parkPosY": 0,
        "parkPosZ": 10,
        "emergencyParser": -1,
        "hostRescue": "1",
        "MAX31855SwCS": -1,
        "MAX31855SwCLK": -1,
        "tempGain": "0",
        "uiAnimation": "0",
        "hasUser0": false,
        "hasUser1": false,
        "hasUser2": false,
        "numExtruder": 1,
        "version": 100.4,
        "primaryPortName": "Serial",
        "hasMAX31855SW": false
  • Why don't you do what I say?
    So what is now connected to E1? second Z or second Y motor? Since Z works as you said I guess Z so it can't be used for Y motor.
    X:10240; Y:5120;
    Are these values serious? With such high values you can only move slowly. Maybe 30mm/s if you have no extra delays. Any resolution higher then 1000 steps/mm is exaggerated and even around 1000 is only good for better motor sound. If these values are too high your motor will just block and you hear a high pitch sound.
  • Yes they are serious. Because I'm using a lead screw drive system.
    X --> I shoosed 64 step/mm (200 X 64)/1.25=10240 Step/mm
    Y--> 32 step/mm (200 X 32) / 1.25= 5120 Step/mm
    And Z : same like X 64 step/mm (200 X 64)/1.25=10240 Step/mm
  • Ok lead screws explain that. But with these values make sure speed is below 30mm/s - maybe even 25mm/s. And also acceleration/jerk are much more sensitive - take values from z for x and y then. If motors can handle the speed you can reduce microsteps for more speed, but I know z often is already limited by the reduced torque from high rotation speed.
  • rimrim
    edited July 2020
    Hello, below everything I did in the config.
    But as I said before, no movement of the two steppers of Y and that of X!
     1) The Y axes make noise as if they move the axes, but no rotation / no movement only a sound !!
     2) The X axis is identical to the Y axis!
     3) And for the Z axes, move, but I thought that normally when we turn off the E-HALL Endstop and turn on the 3D printer, the axes should not move! But in my case, the Z axes move. And when I turned on the Z-E-HALL Max, and I try to configure it, Z does not go up, only goes down.
     I don't know if you can help me, but I hope so. And I apologize, But as I already mentioned, this is something new for me and I try to learn. So I hope to get help here. I sincerely thank you.
    PS:
    When I use the voltmeter to measure the output voltage of the motors, for the z, it displays the 3V. on the other hand the Y and the X is 0 :(
    Kind Regards;
    Config:
    #include "pins.h"
    #define JAM_SLOWDOWN_STEPS 250
    #define JAM_ERROR_STEPS 400
    #define TEMP_GAIN 0
    #define MAXTEMP 275
    #define DOOR_PIN -1
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define X_HOME_DIR 1
    #define Y_HOME_DIR 1
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    // Delta settings
    #define MAX_FEEDRATE_X 25
    #define MAX_FEEDRATE_Y 25
    #define MAX_FEEDRATE_Z 25
    #define HOMING_FEEDRATE_X 25
    #define HOMING_FEEDRATE_Y 25
    #define HOMING_FEEDRATE_Z 25
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 500
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 500
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 500
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 500
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 500
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 500
    #define MAX_JERK 12
    #define Z2_STEP_PIN   ORIG_E2_STEP_PIN
    #define Z2_DIR_PIN    ORIG_E2_DIR_PIN
    #define Z2_ENABLE_PIN ORIG_E2_ENABLE_PIN
    #undef PS_ON_PIN
    #define Z_PROBE_X_OFFSET -10
    #define Z_PROBE_Y_OFFSET -10
    #define Z_PROBE_SPEED 12
    #define Z_PROBE_XY_SPEED 100
    #define FEATURE_AUTOLEVEL 0
    #define Z_PROBE_X1 -10
    #define Z_PROBE_Y1 -10
    #define Z_PROBE_X2 240
    #define Z_PROBE_Y2 10
    #define Z_PROBE_X3 10
    #define Z_PROBE_Y3 240
    #define SDSUPPORT 0
    #undef SDCARDDETECT
    #endif
    #define FEATURE_BEEPER 0
    #endif
  • There is not much I can do. You need to use logic and tests. Do the rods block when starting to move? I guess since you said they make sounds. Sounds mean pins are correct and you are just moving too fast and loosing steps. Or one of the wires has no contact and motors can not rotate. As alsready said try with motors without connected rods to see if all move in correct direction and same speed. Differences can cause mechanic to block so it can not move. Can also be the the current on the motor driver is not configured correctly.
    And lastly
    #define MAX_JERK 12
    Z starts with 0.3mm/s while xy start with 12 - actually 50% of it. But that can already be too
    much with rod system so reduce the value as well to 0.3. Make sure eeprom has
    the values as well. Upload will not change them in eeprom.
    Same settings on all motors should work if mechanics are similar.
  • rimrim
    edited July 2020
    Okey.Thank you.
    And why Z can't move up when I activate the E-HALL Endstop max?
  • Check with M119 the signal. If it is high you can not move in that direction. It might be high if pullup or invert for the endstop does not match the switch.
  • Me again...
    X, Y and Z finally worked :)
    But now I have another problem. When I turn on the printer, the Z axis starts to go up without even touching anything !! Do you have any idea what may be causing this?.
    Thank you :)
  • Maybe it comes from
    it is the only homing command I see in configuration. If yu don't have z max homing that would be a bad idea anyway.
    At startup firmware tries to run a autorun script so even if it is not there it might get stopped and trigger this.
  • Hei, I have a question please.
    This is the size of my bed:
    But it doesn't seem like that when I move my axis...!It's like it consider it 90 x 90 x 90!
    Could it be something registered in the eeprom? That I should modify in the host?
    kind Regards;
  • Yes, you should see same in eeprom. Are ,oves correct in distance? Otherwise steps per mm are just wrong.
