Z probe too high one side
I use a Pibot board with Repetier firmware.
I have in my start Gcdoe a G32 S0 command for probe.
It works on 3 points but when I print on the right side the nozzle is too high.
Z motors works for compensation but on the right side the nozzle goes too high.
I'm using a reflecting probe produced by Pibot.
Can you help me.
I tried to realize a mesh of point but it doesn't work. It only works with 3 points probe G32.
Can you help me?
  • First use 1.0.4dev - there was a bug that could cause z going up during measurements a bit. If that does not help you can "misuse" bending correction and set a correction for the right side if the sensor gives other values there due to different reflections. So all points get correction 0 and the one on the right is set with the error distance.
  • I'm working with an old version of the firmware of 2016. Tried to configure again with repeater for Pibot configurator but nothing moves. Is there a possibility to configure a new firmware with mesh bed autolevel. I intend the bilinear one. Thanks a lot.
    I'm using this kit https://www.pibot.com/set-of-pibot-electronics-kits-for-3d-printer-2-0-d.html but the producer doesn't answer to questions. Bad situation:-(
  • Since old version works, the answer is yes. You just need to use same settings as in old firmware. If it was created with config tool it would update automatically, otherwise use the values from configuration.h to fill in the values. The settings show the name of the config parameter below the name.
  • I used the configurator to set the new firmware. I solved some problems with Arduino Ide and now i flashed the firmware. When I start Repetier it operates only on extruder temp and fan. Motors don't work. End stop are H and probe is L. Tried to home but nothing. Tried to move one each one but nothing. Only extruder temp and extruder fan works.
    At this link the configuration h and all of the firmware.
    Can you help me to solve?
    Thanks a lot.
    https://drive.google.com/drive/folders/1zYWo3zz3kjyMgr0gdSABN-2nKQ-ZDY3_?usp=sharing
  • Any help?
  • End stops must be L when untriggered. SO assuming pins were correct you need the inverted method in config tool. That may also prevent moves/homing.
    Extruder will only run if hot or if you allow cold extrusion using
    M302 S1
    It might also be that you need to invert enable signal for motor driver to get them work. Some need high some low. Just test if you can move them when you start firmware. At start motors are off so they should not block. If they block enable must be inverted.
  • edited May 28
    First of all thanks a lot!
    I inverted the motor on configurator and now is ok.
    Now I can move motor and I think I'll be able to test the printer.
    Let's start again with autolevel.
    I want to use a mesh of 9 points on the bed and I configured it in the configurator online.
    When It starts with the first point the probe goes down but doesn't stop when triggers.
    I have a blue led on the reflective z-probe that goes on but z axis continue to go down.
    I tried to tes with M119 the status and i saw that it remains the same.
    Always High with blue light on or off.
    With other version of firmware it works.
    Any idea?
    Other question: Wich is the commend for autoleveling and 9 point probe? G29 or G32?
    Thank you
  • Solved the problem of the status of the probe.
    It was a wrong assignation of the pin.
    The problem is: how to have a 9 points grid on the bed before to print?
    For example:
    3 points on X with Y20
    3 on X with  Y 40
    3on X with Y 60
    I configured the bilinear one but it takes points always on the same Y value.
  • Solved this too :-)
    Probably is better if I wait before asking :-)
    I did it from configurator and works.
    Tonight I'll have some test on the correction bed level function.
  • edited May 29
    As in the title...
    after G32 S0 the nozzle goes down and scratch a little the plane and then goes to start printing on the left side.
    At this point, the extruder is 2mm higher than the plane but when it goes on the right side is very attached to the plane.
    So after configuring the new firmware I have the same problem but with an inverted side :-)
    P.S.
    The Z axis moves while X and Y moves. So I think printer reads some dates but no the correct one...
    Any idea?
    Thanks a lot guys. I hope I'll be able to use Repetier :-)
    This is the start GCODE:
    M104 S200 ; set temperature
    G1 Z10 F50 ; lift nozzle
    G28; home all axes
    G32 S0;
    ; Filament gcode
    M82 ; use absolute distances for extrusion
    G92 E0 ; reset extrusion distance
    G1 E-1.00000 F1800.00000 ; retract extruder 0
    G1 Z-1.680 F2100.000 ; move to next layer (0)
    This is the Eprom configuration
    12:50:43.841 : FIRMWARE_NAME:Repetier_0.92.9 FIRMWARE_URL:https://github.com/repetier/Repetier-Firmware/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:1 REPETIER_PROTOCOL:3
    12:50:43.841 : Printed filament:0.30m Printing time:0 days 0 hours 16 min
    12:50:43.841 : PrinterMode:FFF
    12:50:43.844 : X:0.00 Y:0.00 Z:15.000 E:0.0000
    12:50:43.844 : DebugLevel:6
    12:50:49.153 : SelectExtruder:0
    12:50:49.153 : Unknown command:N7 M20
    12:50:49.154 : DebugLevel:6
    12:50:49.154 : SelectExtruder:0
    12:54:09.248 : EPR:0 1028 0 Language
    12:54:09.255 : EPR:2 75 115200 Baudrate
    12:54:09.263 : EPR:3 129 0.297 Filament printed [m]
    12:54:09.271 : EPR:2 125 1003 Printer active [s]
    12:54:09.278 : EPR:2 79 0 Max. inactive time [ms,0=off]
    12:54:09.294 : EPR:2 83 0 Stop stepper after inactivity [ms,0=off]
    12:54:09.303 : EPR:3 3 80.0000 X-axis steps per mm
    12:54:09.311 : EPR:3 7 64.0000 Y-axis steps per mm
    12:54:09.319 : EPR:3 11 1600.0000 Z-axis steps per mm
    12:54:09.329 : EPR:3 15 200.000 X-axis max. feedrate [mm/s]
    12:54:09.337 : EPR:3 19 200.000 Y-axis max. feedrate [mm/s]
    12:54:09.345 : EPR:3 23 8.000 Z-axis max. feedrate [mm/s]
    12:54:09.354 : EPR:3 27 150.000 X-axis homing feedrate [mm/s]
    12:54:09.362 : EPR:3 31 150.000 Y-axis homing feedrate [mm/s]
    12:54:09.370 : EPR:3 35 2.000 Z-axis homing feedrate [mm/s]
    12:54:09.379 : EPR:3 39 20.000 Max. jerk [mm/s]
    12:54:09.393 : EPR:3 47 0.300 Max. Z-jerk [mm/s]
    12:54:09.402 : EPR:3 133 0.000 X min pos [mm]
    12:54:09.410 : EPR:3 137 0.000 Y min pos [mm]
    12:54:09.421 : EPR:3 141 0.000 Z min pos [mm]
    12:54:09.430 : EPR:3 145 900.000 X max length [mm]
    12:54:09.439 : EPR:3 149 1600.000 Y max length [mm]
    12:54:09.450 : EPR:3 153 800.000 Z max length [mm]
    12:54:09.458 : EPR:3 51 250.000 X-axis acceleration [mm/s^2]
    12:54:09.468 : EPR:3 55 250.000 Y-axis acceleration [mm/s^2]
    12:54:09.478 : EPR:3 59 68.000 Z-axis acceleration [mm/s^2]
    12:54:09.488 : EPR:3 63 300.000 X-axis travel acceleration [mm/s^2]
    12:54:09.499 : EPR:3 67 300.000 Y-axis travel acceleration [mm/s^2]
    12:54:09.509 : EPR:3 71 68.000 Z-axis travel acceleration [mm/s^2]
    12:54:09.519 : EPR:3 1032 80.000 Acceleration factor at top [%,100=like bottom]
    12:54:09.529 : EPR:3 1024 0.000 Coating thickness [mm]
    12:54:09.540 : EPR:3 808 -2.000 Z-probe height [mm]
    12:54:09.550 : EPR:3 929 10.000 Max. z-probe - bed dist. [mm]
    12:54:09.558 : EPR:3 812 4.000 Z-probe speed [mm/s]
    12:54:09.568 : EPR:3 840 80.000 Z-probe x-y-speed [mm/s]
    12:54:09.577 : EPR:3 800 -45.000 Z-probe offset x [mm]
    12:54:09.586 : EPR:3 804 -25.000 Z-probe offset y [mm]
    12:54:09.596 : EPR:3 816 20.000 Z-probe X1 [mm]
    12:54:09.605 : EPR:3 820 20.000 Z-probe Y1 [mm]
    12:54:09.615 : EPR:3 824 300.000 Z-probe X2 [mm]
    12:54:09.625 : EPR:3 828 20.000 Z-probe Y2 [mm]
    12:54:09.635 : EPR:3 832 20.000 Z-probe X3 [mm]
    12:54:09.643 : EPR:3 836 300.000 Z-probe Y3 [mm]
    12:54:09.656 : EPR:3 1036 0.000 Z-probe bending correction A [mm]
    12:54:09.667 : EPR:3 1040 0.000 Z-probe bending correction B [mm]
    12:54:09.676 : EPR:3 1044 0.000 Z-probe bending correction C [mm]
    12:54:09.686 : EPR:0 880 1 Autolevel active (1/0)
    12:54:09.693 : EPR:3 976 0.000 tanXY Axis Compensation
    12:54:09.701 : EPR:3 980 0.000 tanYZ Axis Compensation
    12:54:09.707 : EPR:3 984 0.000 tanXZ Axis Compensation
    12:54:09.715 : EPR:0 1020 0 Enable retraction conversion [0/1]
    12:54:09.722 : EPR:3 992 3.000 Retraction length [mm]
    12:54:09.729 : EPR:3 1000 40.000 Retraction speed [mm/s]
    12:54:09.736 : EPR:3 1004 0.000 Retraction z-lift [mm]
    12:54:09.743 : EPR:3 1008 0.000 Extra extrusion on undo retract [mm]
    12:54:09.750 : EPR:3 1016 20.000 Retraction undo speed
    12:54:09.757 : EPR:3 200 120.000 Extr.1 steps per mm
    12:54:09.765 : EPR:3 204 30.000 Extr.1 max. feedrate [mm/s]
    12:54:09.772 : EPR:3 208 10.000 Extr.1 start feedrate [mm/s]
    12:54:09.780 : EPR:3 212 4000.000 Extr.1 acceleration [mm/s^2]
    12:54:09.788 : EPR:0 216 1 Extr.1 heat manager [0-3]
    12:54:09.795 : EPR:0 217 230 Extr.1 PID drive max
    12:54:09.804 : EPR:0 245 40 Extr.1 PID drive min
    12:54:09.811 : EPR:3 218 16.0000 Extr.1 PID P-gain/dead-time
    12:54:09.819 : EPR:3 222 0.9200 Extr.1 PID I-gain
    12:54:09.826 : EPR:3 226 60.0000 Extr.1 PID D-gain
    12:54:09.834 : EPR:0 230 255 Extr.1 PID max value [0-255]
    12:54:09.841 : EPR:2 231 0 Extr.1 X-offset [steps]
    12:54:09.849 : EPR:2 235 0 Extr.1 Y-offset [steps]
    12:54:09.858 : EPR:2 290 0 Extr.1 Z-offset [steps]
    12:54:09.867 : EPR:1 239 1 Extr.1 temp. stabilize time [s]
    12:54:09.875 : EPR:1 250 186 Extr.1 temp. for retraction when heating [C]
    12:54:09.884 : EPR:1 252 2 Extr.1 distance to retract when heating [mm]
    12:54:09.891 : EPR:0 254 255 Extr.1 extruder cooler speed [0-255]
  • See you are still on 0.92.9. Not sure about which problems existed there. Know it worked at least.
    What is the log from
    G28; home all axes
    G32 S0;
    Depending on setup this can cause illegal position and abort of G32. If you home x and y min I guess it should work with correct points.
    What I wonder is when your printer is 900x1600 mm big, why do you not test rotation for full bed? You only measure a square 20-300x20-300 so rounding errors of that measurement count up. Also such big beds tend to deform when getting hot and move.
  • Thanks a lot Repetier.
    I configured the last version by online configurator but while I upload to the board, a the end of the process I have this message:
    avrdude: verification error, first mismatch at byte 0x0000
             0xb8 != 0x0c
    avrdude: verification error; content mismatch
    Tried to reinstall the old configuration and everything works again.
    Any solution?
  • It just says that uploading did not work. Already the first send byte was wrong. So normally you just retry in that case uploading and hope it was just a communication error. That is why you run verify after uploading.
  • Everything works with old firmware bit I still have this error when I try to install last version.
  • Can't say more. Error message is from uploader so has nothing to do with content. It just says the compilation has one value as first byte and the uploaded code another value.
    Does old firmware upload if you change any parameter making it differ? Question is if flash is write protected so uploading does not work and old just works because it is identical to already existing or if it writes and jus has a write failure.
    Do mor euploads cause exactly the same error?
  • Probably there is some bug in configurator online.
    I eliminated some code that I added in pause command on start on the online configurator and now the upload is ok.
    QUESTION 1
    I sent G32 S0 and now I generated a mesh for the plane.
    At this point, I execute the slicing but when printer starts goes to Z0 and not to Z-2.
    So Zmotors compensate probably in the right way but extruder stays to Z0 position so +2 and prints in the air.
    I saw also the GCODE of the slicing and it indicates the first layer to Z-2.
    So the command is ok but is ignored.
    QUESTION 2 - Z OFFSET
    Where to set the parameter? In the slicer or in Eprom.
    I hoped Repetier host and set the value in EPROM but nothing append. If I do the same in Slic3R from RHost,  it works. Can you explain how to operate?
    QUESTION 3 SD CARD
    I saw there is no possibility to read SD card from the physical reader on the board.
    ; generated by Slic3r 1.3.1-dev on 2020-06-04 at 12:10:30
    ; external perimeters extrusion width = 130.00mm (2077.80mm^3/s)
    ; perimeters extrusion width = 0.50mm (9.28mm^3/s)
    ; infill extrusion width = 0.45mm (7.00mm^3/s)
    ; solid infill extrusion width = 0.42mm (6.33mm^3/s)
    ; top infill extrusion width = 0.52mm (7.35mm^3/s)
    M104 S210
    G28 ; home all axes
    ; Filament gcode
    This the configuration files stored at this link
        MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
        along with Repetier-Firmware.  If not, see <http://www.gnu.org/licenses/>.
    #ifndef CONFIGURATION_H
    #define CONFIGURATION_H
       This file is optimized for version 1.0.3
       as you expect.
    #define NUM_EXTRUDER 1
    #define MOTHERBOARD 316
    #include "pins.h"
    #undef FAN_BOARD_PIN
    #define FAN_BOARD_PIN -1
    #define BOARD_FAN_SPEED 255
    #define BOARD_FAN_MIN_SPEED 0
    #define FAN_THERMO_PIN -1
    //#define COMPAT_PRE1
    #define BLUETOOTH_SERIAL  -1
    #define MIXING_EXTRUDER 0
    #define DRIVE_SYSTEM 0
    #define XAXIS_STEPS_PER_MM 80
    #define YAXIS_STEPS_PER_MM 64
    #define ZAXIS_STEPS_PER_MM 1600
    #define PDM_FOR_EXTRUDER 0
    #define PDM_FOR_COOLER 0
    #define RETRACT_ON_PAUSE 2
    #define PAUSE_END_COMMANDS ""
    #define EXT0_X_OFFSET 0
    #define EXT0_Y_OFFSET 0
    #define EXT0_Z_OFFSET 0
    #define EXT0_STEPS_PER_MM 120
    #define EXT0_INVERSE 0
    #define EXT0_ENABLE_ON 1
    #define EXT0_MIRROR_STEPPER 0
    #define EXT0_INVERSE2 0
    #define EXT0_MAX_FEEDRATE 50
    #define EXT0_MAX_ACCELERATION 1000
    #define EXT0_HEAT_MANAGER 1
    #define EXT0_PREHEAT_TEMP 190
    #define EXT0_WATCHPERIOD 1
    #define EXT0_PID_I 2
    #define EXT0_PID_D 40
    #define EXT0_PID_MAX 255
    #define EXT0_ADVANCE_K 0
    #define EXT0_ADVANCE_L 0
    #define EXT0_EXTRUDER_COOLER_PIN ORIG_FAN_PIN
    #define EXT0_JAM_PIN -1
    #define EXT0_JAM_PULLUP 0
    #define FEATURE_RETRACTION 1
    #define AUTORETRACT_ENABLED 0
    #define RETRACTION_LENGTH 3
    #define RETRACTION_SPEED 40
    #define RETRACTION_Z_LIFT 0
    #define JAM_METHOD 1
    #define JAM_STEPS 220
    #define JAM_SLOWDOWN_TO 70
    #define JAM_ERROR_STEPS 500
    #define JAM_MIN_STEPS 10
    #define JAM_ACTION 1
    #define PID_CONTROL_RANGE 20
    #define SKIP_M109_IF_WITHIN 2
    #define SCALE_PID_TO_MAX 0
    #define TEMP_HYSTERESIS 0
    #define EXTRUDE_MAXLENGTH 160
    #define GENERIC_THERM_VREF 5
    #define HEATER_PWM_SPEED 0
    #define COOLER_PWM_SPEED 0
    #define HAVE_HEATED_BED 0
    #define SKIP_M190_IF_WITHIN 3
    #define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   196
    #define HEATED_BED_PID_IGAIN   33
    #define MIN_EXTRUDER_TEMP 190
    #define MAXTEMP 275
    // ##                             Laser configuration                                      ##
    automatically disabled.
    #define SUPPORT_LASER 0
    #define LASER_PIN -1
    #define LASER_ON_HIGH 1
    #define LASER_WARMUP_TIME 0
    #define LASER_PWM_MAX 255
    #define LASER_WATT 2
    // ##                              CNC configuration                                       ##
    #define SUPPORT_CNC 0
    #define CNC_WAIT_ON_DISABLE 0
    #define CNC_ENABLE_PIN -1
    #define CNC_ENABLE_WITH 1
    #define CNC_DIRECTION_PIN -1
    #define CNC_DIRECTION_CW 1
    #define CNC_PWM_MAX 255
    #define CNC_RPM_MAX 8000
    #define CNC_SAFE_Z 150
    #define ENDSTOP_PULLUP_X_MIN false
    #define ENDSTOP_PULLUP_Y_MIN false
    #define X2_MIN_PIN -1
    #define X2_MAX_PIN -1
    #define Y2_MIN_PIN -1
    #define Y2_MAX_PIN -1
    #define Z2_MINMAX_PIN -1
    #define DOOR_PIN -1
    #define DOOR_PULLUP 1
    #define DOOR_INVERTING 0
    #define ENDSTOP_X_BACK_MOVE 5
    #define ENDSTOP_Y_BACK_MOVE 5
    #define ENDSTOP_Z_BACK_MOVE 2
    #define ENDSTOP_Z_BACK_ON_HOME 1
    #define MOVE_X_WHEN_HOMED 0
    #define MOVE_Y_WHEN_HOMED 0
    #define MOVE_Z_WHEN_HOMED 0
    #define X_ENABLE_ON 1
    #define Y_ENABLE_ON 1
    #define Z_ENABLE_ON 1
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define INVERT_X_DIR 0
    #define INVERT_X2_DIR 0
    #define INVERT_Y_DIR 1
    #define INVERT_Y2_DIR 0
    #define INVERT_Z_DIR 0
    #define INVERT_Z2_DIR 0
    #define INVERT_Z3_DIR 0
    #define INVERT_Z4_DIR 0
    #define X_HOME_DIR -1
    #define Y_HOME_DIR -1
    #define Z_HOME_DIR -1
    #define X_MAX_LENGTH 1000
    #define Y_MAX_LENGTH 1500
    #define Z_MAX_LENGTH 900
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    #define PARK_POSITION_X 0
    #define PARK_POSITION_Y 0
    #define DISTORTION_CORRECTION_POINTS 3
    #define DISTORTION_LIMIT_TO 2
    #define DISTORTION_XMIN 10
    #define DISTORTION_YMIN 10
    #define DISTORTION_XMAX 990
    #define DISTORTION_YMAX 1490
    // ##                           Movement settings                                          ##
    #define EXACT_DELTA_MOVES 1
    // Delta settings
    #define DELTA_HOME_ON_POWER 0
    #define MAX_INACTIVE_TIME 0L
    #define MAX_FEEDRATE_X 300
    #define MAX_FEEDRATE_Y 300
    #define MAX_FEEDRATE_Z 2
    #define HOMING_FEEDRATE_X 40
    #define HOMING_FEEDRATE_Y 40
    #define HOMING_FEEDRATE_Z 2
    #define HOMING_ORDER HOME_ORDER_XYZ
    #define ZHOME_PRE_RAISE 0
    #define ZHOME_HEAT_ALL 1
    #define ZHOME_HEAT_HEIGHT 20
    #define ZHOME_X_POS 999999
    #define ZHOME_Y_POS 999999
    #define X_BACKLASH 0
    #define Y_BACKLASH 0
    #define Z_BACKLASH 0
    #define RAMP_ACCELERATION 1
    #define STEPPER_HIGH_DELAY 0
    #define DIRECTION_DELAY 0
    #define ALLOW_QUADSTEPPING 1
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 300
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 300
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 50
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 300
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 300
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 150
    #define INTERPOLATE_ACCELERATION_WITH_Z 3
    #define ACCELERATION_FACTOR_TOP 80
    #define MAX_JERK 20
    #define MAX_ZJERK 0.3
    #define MOVE_CACHE_LOW 10
    #define DUAL_X_AXIS 0
    #define DUAL_X_RESOLUTION 0
    #define X2_STEP_PIN   ORIG_E1_STEP_PIN
    #define X2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Y2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Y2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Z2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z3_STEP_PIN   ORIG_E2_STEP_PIN
    #define Z3_DIR_PIN    ORIG_E2_DIR_PIN
    #define Z4_STEP_PIN   ORIG_E3_STEP_PIN
    #define Z4_DIR_PIN    ORIG_E3_DIR_PIN
    #define USE_ADVANCE 0
    #define BAUDRATE 115200
    #define POWER_INVERTING 0
    #define AUTOMATIC_POWERUP 0
    #define KILL_METHOD 0
    #define ACK_WITH_LINENUMBER 1
    #define ECHO_ON_EXECUTE 1
    #define EEPROM_MODE 1
    #undef PS_ON_PIN
    #define STARTUP_GCODE "G1 Z15 F50 ; G28 ; G1 Z15 F50 ;"
    #define JSON_OUTPUT 0
    /* ======== Servos =======
    Control the servos with
    M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
    #define FEATURE_SERVO 0
    #define SERVO0_PIN 11
    #define SERVO1_PIN -1
    #define SERVO2_PIN -1
    #define SERVO3_PIN -1
    #define UI_SERVO_CONTROL 0
    #define MAX_FAN_PWM 255
            #define FEATURE_WATCHDOG 1
    #define Z_PROBE_Z_OFFSET 0
    #define Z_PROBE_Z_OFFSET_MODE 1
    #define UI_BED_COATING 0
    #define FEATURE_Z_PROBE 1
    #define EXTRUDER_IS_Z_PROBE 0
    #define Z_PROBE_PIN 68
    #define Z_PROBE_PULLUP 0
    #define Z_PROBE_ON_HIGH 0
    #define Z_PROBE_X_OFFSET -25
    #define Z_PROBE_Y_OFFSET -40
    #define Z_PROBE_SPEED 5
    #define Z_PROBE_XY_SPEED 100
    #define Z_PROBE_SWITCHING_DISTANCE 5
    #define Z_PROBE_REPETITIONS 3
    #define Z_PROBE_USE_MEDIAN 0
    #define Z_PROBE_HEIGHT -1.92
    #define Z_PROBE_DELAY 0
    #define FEATURE_AUTOLEVEL 1
    #define Z_PROBE_X1 20
    #define Z_PROBE_Y1 20
    #define Z_PROBE_X2 600
    #define Z_PROBE_Y2 20
    #define Z_PROBE_X3 20
    #define Z_PROBE_Y3 600
    #define BED_LEVELING_METHOD 1
    #define BED_LEVELING_GRID_SIZE 3
    #define BED_LEVELING_REPETITIONS 2
    #define BED_MOTOR_1_X 0
    #define BED_MOTOR_1_Y 0
    #define BED_MOTOR_2_X 200
    #define BED_MOTOR_2_Y 0
    #define BED_MOTOR_3_X 100
    #define BED_MOTOR_3_Y 200
    #define FEATURE_AXISCOMP 1
    #define AXISCOMP_TANXY 0
    #define AXISCOMP_TANYZ 0
    #define AXISCOMP_TANXZ 0
    #define SDSUPPORT 0
    #undef SDCARDDETECT
    #define SDCARDDETECT -1
    #undef SDCARDDETECTINVERTED
    #define SD_RUN_ON_STOP ""
    #define ARC_SUPPORT 1
    #define FEATURE_FAN_CONTROL 1
    #define FEATURE_CONTROLLER 8
    #define ADC_KEYPAD_PIN -1
    #define LANGUAGE_EN_ACTIVE 1
    #define LANGUAGE_DE_ACTIVE 0
    #define LANGUAGE_NL_ACTIVE 0
    #define LANGUAGE_PT_ACTIVE 0
    #define LANGUAGE_IT_ACTIVE 0
    #define LANGUAGE_ES_ACTIVE 0
    #define LANGUAGE_FI_ACTIVE 0
    #define LANGUAGE_SE_ACTIVE 0
    #define LANGUAGE_FR_ACTIVE 0
    #define LANGUAGE_CZ_ACTIVE 0
    #define LANGUAGE_PL_ACTIVE 0
    #define LANGUAGE_TR_ACTIVE 0
    #define UI_PRINTER_NAME "Ciccio"
    #define UI_PRINTER_COMPANY "Pasticcio"
    #define FEATURE_UI_KEYS 0
    #define UI_ENCODER_SPEED 1
    #define UI_REVERSE_ENCODER 0
    #define UI_KEY_BOUNCETIME 10
    #define UI_KEY_MIN_REPEAT 50
    #define FEATURE_BEEPER 0
    #define CASE_LIGHTS_PIN -1
    #define UI_SET_MIN_EXTRUDER_TEMP   170
    #define UI_SET_MAX_EXTRUDER_TEMP   260
    #define NUM_MOTOR_DRIVERS 0
        "editMode": 2,
        "processor": 0,
        "baudrate": 115200,
        "bluetoothSerial": -1,
        "bluetoothBaudrate": 115200,
        "xStepsPerMM": 80,
        "yStepsPerMM": 64,
        "zStepsPerMM": 1600,
        "xInvert": "0",
        "x2Invert": 0,
        "xInvertEnable": "1",
        "eepromMode": 1,
        "yInvert": "1",
        "y2Invert": 0,
        "yInvertEnable": "1",
        "zInvert": "0",
        "z2Invert": 0,
        "z3Invert": 0,
        "z4Invert": 0,
        "zInvertEnable": "1",
        "extruder": [
                "id": 0,
                "heatManager": 1,
                "pidDriveMin": 40,
                "pidDriveMax": 230,
                "pidMax": 255,
                "sensorType": 1,
                "sensorPin": "TEMP_0_PIN",
                "heaterPin": "HEATER_0_PIN",
                "maxFeedrate": 50,
                "startFeedrate": 20,
                "invert": "0",
                "invertEnable": "1",
                "acceleration": 1000,
                "watchPeriod": 1,
                "pidP": 7,
                "pidI": 2,
                "pidD": 40,
                "advanceK": 0,
                "advanceL": 0,
                "waitRetractTemp": 150,
                "waitRetractUnits": 0,
                "waitRetract": 0,
                "stepsPerMM": 120,
                "coolerPin": "ORIG_FAN_PIN",
                "coolerSpeed": 255,
                "selectCommands": "",
                "deselectCommands": "",
                "xOffset": 0,
                "yOffset": 0,
                "zOffset": 0,
                "xOffsetSteps": 0,
                "yOffsetSteps": 0,
                "zOffsetSteps": 0,
                "stepper": {
                    "name": "Extruder 0",
                    "step": "ORIG_E0_STEP_PIN",
                    "dir": "ORIG_E0_DIR_PIN",
                "advanceBacklashSteps": 0,
                "decoupleTestPeriod": 12,
                "jamPin": -1,
                "jamPullup": "0",
                "mirror": "0",
                "invert2": "0",
                "stepper2": {
                "preheat": 190
        "uiLanguage": 0,
        "uiController": 0,
        "xMinEndstop": 4,
        "yMinEndstop": 4,
        "zMinEndstop": 4,
        "xMaxEndstop": 0,
        "yMaxEndstop": 0,
        "zMaxEndstop": 0,
        "x2MinEndstop": 0,
        "y2MinEndstop": 0,
        "x2MaxEndstop": 0,
        "y2MaxEndstop": 0,
        "motherboard": 316,
        "driveSystem": 0,
        "xMaxSpeed": 300,
        "xHomingSpeed": 40,
        "xTravelAcceleration": 300,
        "xPrintAcceleration": 300,
        "yMaxSpeed": 300,
        "yHomingSpeed": 40,
        "yTravelAcceleration": 300,
        "yPrintAcceleration": 300,
        "zMaxSpeed": 2,
        "zHomingSpeed": 2,
        "zTravelAcceleration": 150,
        "zPrintAcceleration": 50,
        "xMotor": {
            "name": "X motor",
            "step": "ORIG_X_STEP_PIN",
            "dir": "ORIG_X_DIR_PIN",
            "enable": "ORIG_X_ENABLE_PIN"
        "yMotor": {
            "name": "Y motor",
            "step": "ORIG_Y_STEP_PIN",
            "dir": "ORIG_Y_DIR_PIN",
            "enable": "ORIG_Y_ENABLE_PIN"
        "zMotor": {
            "name": "Z motor",
            "step": "ORIG_Z_STEP_PIN",
            "dir": "ORIG_Z_DIR_PIN",
            "enable": "ORIG_Z_ENABLE_PIN"
        "enableBacklash": "0",
        "backlashX": 0,
        "backlashY": 0,
        "backlashZ": 0,
        "stepperInactiveTime": 360,
        "maxInactiveTime": 0,
        "xMinPos": 0,
        "yMinPos": 0,
        "zMinPos": 0,
        "xLength": 1000,
        "yLength": 1500,
        "zLength": 900,
        "alwaysCheckEndstops": "0",
        "disableX": "0",
        "disableY": "0",
        "disableZ": "0",
        "disableE": "0",
        "xHomeDir": "-1",
        "yHomeDir": "-1",
        "zHomeDir": "-1",
        "xEndstopBack": 1,
        "yEndstopBack": 1,
        "zEndstopBack": 1,
        "deltaDiagonalRod": 445,
        "deltaAlphaA": 210,
        "deltaAlphaB": 330,
        "deltaAlphaC": 90,
        "deltaDiagonalCorrA": 0,
        "deltaDiagonalCorrB": 0,
        "deltaDiagonalCorrC": 0,
        "deltaMaxRadius": 150,
        "deltaRadiusCorrA": 0,
        "deltaRadiusCorrB": 0,
        "deltaRadiusCorrC": 0,
        "deltaXOffsetSteps": 0,
        "deltaYOffsetSteps": 0,
        "deltaZOffsetSteps": 0,
        "deltaSegmentsPerLine": 24,
        "stepperHighDelay": 0,
        "directionDelay": 0,
        "allowQuadstepping": "1",
        "doubleStepDelay": 0,
        "maxJerk": 20,
        "maxZJerk": 0.3,
        "moveCacheSize": 16,
        "moveCacheLow": 10,
        "lowTicksPerMove": 250000,
        "enablePowerOnStartup": "1",
        "echoOnExecute": "1",
        "sendWaits": "1",
        "ackWithLineNumber": "1",
        "killMethod": 0,
        "useAdvance": "0",
        "useQuadraticAdvance": "0",
        "powerInverting": 0,
        "mirrorX": 0,
        "mirrorXMotor": {
            "name": "Extruder 1",
            "step": "ORIG_E1_STEP_PIN",
            "dir": "ORIG_E1_DIR_PIN",
        "mirrorY": 0,
        "mirrorYMotor": {
        "mirrorZ": "0",
        "mirrorZMotor": {
        "mirrorZ3": "0",
        "mirrorZ3Motor": {
            "name": "Extruder 2",
            "step": "ORIG_E2_STEP_PIN",
            "dir": "ORIG_E2_DIR_PIN",
        "mirrorZ4": "0",
        "mirrorZ4Motor": {
            "name": "Extruder 3",
            "step": "ORIG_E3_STEP_PIN",
            "dir": "ORIG_E3_DIR_PIN",
        "dittoPrinting": "0",
        "featureServos": "0",
        "servo0Pin": 11,
        "servo1Pin": -1,
        "servo2Pin": -1,
        "servo3Pin": -1,
        "featureWatchdog": "1",
        "hasHeatedBed": "0",
        "enableZProbing": "1",
        "extrudeMaxLength": 160,
        "homeOrder": "HOME_ORDER_XYZ",
        "featureController": 8,
        "uiPrinterName": "Ciccio",
        "uiPrinterCompany": "Pasticcio",
        "uiPagesDuration": 4000,
        "uiHeadline": "",
        "uiDisablePageswitch": "1",
        "uiAutoReturnAfter": 30000,
        "featureKeys": "0",
        "uiEncoderSpeed": 1,
        "uiReverseEncoder": "0",
        "uiKeyBouncetime": 10,
        "uiKeyFirstRepeat": 500,
        "uiKeyReduceRepeat": 50,
        "uiKeyMinRepeat": 50,
        "featureBeeper": "0",
        "uiMinHeatedBed": 30,
        "uiMaxHeatedBed": 120,
        "uiMinEtxruderTemp": 170,
        "uiMaxExtruderTemp": 260,
        "uiExtruderFeedrate": 2,
        "maxBedTemperature": 120,
        "bedSensorType": 1,
        "bedSensorPin": "TEMP_1_PIN",
        "bedHeatManager": 0,
        "bedPreheat": 55,
        "bedUpdateInterval": 5000,
        "bedPidDriveMin": 80,
        "bedPidDriveMax": 255,
        "bedPidP": 196,
        "bedPidI": 33,
        "bedPidD": 290,
        "bedPidMax": 255,
        "bedDecoupleTestPeriod": 300,
        "caseLightPin": -1,
        "caseLightDefaultOn": "1",
        "bedSkipIfWithin": 3,
        "gen1T0": 25,
        "gen1R0": 100000,
        "gen1Beta": 4036,
        "gen1MinTemp": -20,
        "gen1MaxTemp": 300,
        "gen1R1": 0,
        "gen1R2": 4700,
        "gen2T0": 25,
        "gen2R0": 100000,
        "gen2Beta": 4036,
        "gen2MinTemp": -20,
        "gen2MaxTemp": 300,
        "gen2R1": 0,
        "gen2R2": 4700,
        "gen3T0": 25,
        "gen3R0": 100000,
        "gen3Beta": 4036,
        "gen3MinTemp": -20,
        "gen3MaxTemp": 300,
        "gen3R1": 0,
        "gen3R2": 4700,
        "userTable0": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "userTable1": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "userTable2": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "tempHysteresis": 0,
        "pidControlRange": 20,
        "skipM109Within": 2,
        "extruderFanCoolTemp": 50,
        "minTemp": 190,
        "maxTemp": 275,
        "minDefectTemp": -10,
        "maxDefectTemp": 290,
        "arcSupport": "1",
        "forceChecksum": "0",
        "sdExtendedDir": "1",
        "featureFanControl": "1",
        "fanPin": "ORIG_FAN_PIN",
        "featureFan2Control": "0",
        "fan2Pin": "ORIG_FAN2_PIN",
        "fanThermoPin": -1,
        "fanThermoMinPWM": 128,
        "fanThermoMaxPWM": 255,
        "fanThermoMinTemp": 45,
        "fanThermoMaxTemp": 60,
        "fanThermoThermistorPin": -1,
        "fanThermoThermistorType": 1,
        "scalePidToMax": "0",
        "zProbePin": 68,
        "zProbeBedDistance": 10,
        "zProbeDisableHeaters": "0",
        "zProbePullup": "0",
        "zProbeOnHigh": "0",
        "zProbeXOffset": -25,
        "zProbeYOffset": -40,
        "zProbeWaitBeforeTest": "0",
        "zProbeSpeed": 5,
        "zProbeXYSpeed": 100,
        "zProbeHeight": -1.92,
        "zProbeStartScript": "",
        "zProbeFinishedScript": "",
        "featureAutolevel": "1",
        "zProbeX1": 20,
        "zProbeY1": 20,
        "zProbeX2": 600,
        "zProbeY2": 20,
        "zProbeX3": 20,
        "zProbeY3": 600,
        "zProbeSwitchingDistance": 5,
        "zProbeRepetitions": 3,
        "zProbeMedian": "0",
        "zProbeEveryPoint": "",
        "sdSupport": "0",
        "sdCardDetectPin": -1,
        "sdCardDetectInverted": "0",
        "uiStartScreenDelay": 1000,
        "xEndstopBackMove": 5,
        "yEndstopBackMove": 5,
        "zEndstopBackMove": 2,
        "xEndstopRetestFactor": 3,
        "yEndstopRetestFactor": 3,
        "zEndstopRetestFactor": 3,
        "xMinPin": "ORIG_X_MIN_PIN",
        "yMinPin": "ORIG_Y_MIN_PIN",
        "zMinPin": "ORIG_Z_MIN_PIN",
        "xMaxPin": "ORIG_X_MAX_PIN",
        "yMaxPin": "ORIG_Y_MAX_PIN",
        "zMaxPin": "ORIG_Z_MAX_PIN",
        "x2MinPin": -1,
        "y2MinPin": -1,
        "x2MaxPin": -1,
        "y2MaxPin": -1,
        "deltaHomeOnPower": "0",
        "fanBoardPin": -1,
        "heaterPWMSpeed": 0,
        "featureBabystepping": "1",
        "babystepMultiplicator": 1,
        "pdmForHeater": "0",
        "pdmForCooler": "0",
        "psOn": "ORIG_PS_ON_PIN",
        "mixingExtruder": "0",
        "featureAxisComp": "1",
        "axisCompTanXY": 0,
        "axisCompTanXZ": 0,
        "axisCompTanYZ": 0,
        "retractOnPause": 2,
        "pauseStartCommands": "",
        "pauseEndCommands": "",
        "distortionCorrection": "1",
        "distortionCorrectionPoints": 3,
        "distortionCorrectionR": 100,
        "distortionPermanent": "1",
        "distortionEndDegrade": 1,
        "distortionXMin": 10,
        "distortionXMax": 990,
        "distortionYMin": 10,
        "distortionYMax": 1490,
        "sdRunOnStop": "",
        "featureRetraction": "1",
        "autoretractEnabled": "0",
        "retractionLength": 3,
        "retractionLongLength": 13,
        "retractionSpeed": 40,
        "retractionZLift": 0,
        "retractionUndoSpeed": 20,
        "filamentChangeXPos": 0,
        "filamentChangeYPos": 0,
        "filamentChangeZAdd": 2,
        "filamentChangeRehome": 1,
        "fanKickstart": 200,
        "servo0StartPos": -1,
        "servo1StartPos": -1,
        "servo2StartPos": -1,
        "servo3StartPos": -1,
        "uiDynamicEncoderSpeed": "1",
        "uiServoControl": 0,
        "killIfSensorDefect": "0",
        "jamSteps": 220,
        "jamSlowdownSteps": 320,
        "jamSlowdownTo": 70,
        "jamErrorSteps": 500,
        "jamMinSteps": 10,
        "jamAction": 1,
        "jamMethod": 1,
        "primaryPort": 0,
        "numMotorDrivers": 0,
        "motorDrivers": [
                "t": "None",
                "s": "",
                "invertEnable": "0",
                "invertDirection": "0",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "invertEndstop": "0",
                "minEndstop": "1",
                "endstopPullup": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
        "manualConfig": "",
        "zHomeMinTemperature": 0,
        "zHomeXPos": 999999,
        "zHomeYPos": 999999,
        "zHomeHeatHeight": 20,
        "zHomeHeatAll": "1",
        "zProbeZOffsetMode": 1,
        "zProbeZOffset": 0,
        "zProbeDelay": 0,
        "uiBedCoating": "0",
        "langEN": "1",
        "langDE": "0",
        "langNL": "0",
        "langPT": "0",
        "langIT": "0",
        "langES": "0",
        "langFI": "0",
        "langSE": "0",
        "langFR": "0",
        "langCZ": "0",
        "langPL": "0",
        "langTR": "0",
        "interpolateAccelerationWithZ": 3,
        "accelerationFactorTop": 80,
        "bendingCorrectionA": 0,
        "bendingCorrectionB": 0,
        "bendingCorrectionC": 0,
        "supportLaser": "0",
        "laserPin": -1,
        "laserOnHigh": "1",
        "laserWarmupTime": 0,
        "defaultPrinterMode": 0,
        "laserPwmMax": 255,
        "laserWatt": 2,
        "supportCNC": "0",
        "cncWaitOnEnable": 300,
        "cncWaitOnDisable": 0,
        "cncEnablePin": -1,
        "cncEnableWith": "1",
        "cncDirectionPin": -1,
        "cncDirectionCW": "1",
        "cncPwmMax": 255,
        "cncRpmMax": 8000,
        "cncSafeZ": 150,
        "startupGCode": "G1 Z15 F50 ; G28 ; G1 Z15 F50 ;",
        "jsonOutput": "0",
        "bedLevelingMethod": 1,
        "bedCorrectionMethod": 0,
        "bedLevelingGridSize": 3,
        "bedLevelingRepetitions": 2,
        "bedMotor1X": 0,
        "bedMotor1Y": 0,
        "bedMotor2X": 200,
        "bedMotor2Y": 0,
        "bedMotor3X": 100,
        "bedMotor3Y": 200,
        "zProbeRequiresHeating": "0",
        "zProbeMinTemperature": 150,
        "adcKeypadPin": -1,
        "sharedExtruderHeater": "0",
        "extruderSwitchXYSpeed": 100,
        "dualXAxis": "0",
        "boardFanSpeed": 255,
        "keepAliveInterval": 2000,
        "moveXWhenHomed": "0",
        "moveYWhenHomed": "0",
        "moveZWhenHomed": "0",
        "preheatTime": 30000,
        "multiZEndstopHoming": "0",
        "z2MinMaxPin": -1,
        "z2MinMaxEndstop": 0,
        "extruderIsZProbe": "0",
        "boardFanMinSpeed": 0,
        "doorPin": -1,
        "doorEndstop": 0,
        "zhomePreRaise": 0,
        "zhomePreRaiseDistance": 10,
        "dualXResolution": "0",
        "x2axisStepsPerMM": 100,
        "coolerPWMSpeed": 0,
        "maxFanPWM": 255,
        "raiseZOnToolchange": 0,
        "distortionLimitTo": 2,
        "automaticPowerup": 0,
        "hasTMC2130": "0",
        "TMC2130Sensorless": "0",
        "TMC2130Steathchop": "1",
        "TMC2130Interpolate256": "1",
        "TMC2130StallguardSensitivity": 0,
        "TMC2130PWMAmpl": 255,
        "TMC2130PWMGrad": 1,
        "TMC2130PWMAutoscale": "1",
        "TMC2130PWMFreq": 2,
        "TMC2130CSX": -1,
        "TMC2130CSY": -1,
        "TMC2130CSZ": -1,
        "TMC2130CSE0": -1,
        "TMC2130CSE1": -1,
        "TMC2130CSE2": -1,
        "TMC2130CurrentX": 1000,
        "TMC2130CurrentY": 1000,
        "TMC2130CurrentZ": 1000,
        "TMC2130CurrentE0": 1000,
        "TMC2130CurrentE1": 1000,
        "TMC2130CurrentE2": 1000,
        "TMC2130CoolstepTresholdX": 300,
        "TMC2130CoolstepTresholdY": 300,
        "TMC2130CoolstepTresholdZ": 300,
        "microstepX": 16,
        "microstepY": 16,
        "microstepZ": 16,
        "microstepE0": 16,
        "microstepE1": 16,
        "microstepE2": 16,
        "parkPosX": 0,
        "parkPosY": 0,
        "parkPosZ": 10,
        "uiAnimation": "0",
        "uiPresetBedTempPLA": 60,
        "uiPresetBedABS": 110,
        "uiPresetExtruderPLA": 190,
        "uiPresetExtruderABS": 240,
        "hasMAX6675": false,
        "hasMAX31855": false,
        "hasGeneric1": false,
        "hasGeneric2": false,
        "hasGeneric3": false,
        "hasUser0": false,
        "hasUser1": false,
        "hasUser2": false,
        "numExtruder": 1,
        "version": 100.2,
        "primaryPortName": ""
  • Any help?
    Id like to use repetier :-)
  • >QUESTION 1
    z min is 0. You are not supposed to go below z min so moves to z-2 are forbidden. No one does that normally - only to compensate other errors.
    Your slice code stopped before the first moves so can not see anything related to this. But all should have z 0 as start. So slicer starts with first layer height. If homing is too high so you need to go down 2mm that just means your z probe height is off by 2mm. With correct z probe height you end where you need to be.
    z offsets are 0 in slicers and in firmware for first extruder as well. First extruder is reference for Z and extruder 2 and z probe are all relative to this.
    >QUESTION 3 SD CARD
    You have
     "sdSupport": "0", resulting in
    #define SDSUPPORT 0
    must be 1 for sd card. Normally it gets activated by a controller. But it can also get deactivated by controller. In any case you need to activate it. As a test if sd support is gets compile din add in SDCard.cpp after
    #include "Repetier.h"
    #if SDSUPPORT
    a error message
    #error sd support active
    If compilation breaks with that message you know it is activated now and you can remove the message. If SDSS was correct it should then work.
  • The biggest problem is that I'm not able to upload the new firmware because of Pibot board!! Impossible to flash the  firmware with the latest version of the IDE. Doesn't recognize the board.
    With the only one working version of the IDE (1.6.5) I can only upload the 0.92 version of Repetier.
    Probably the only way to solve the problem is to set one by one the points of the mesh of the probing because after I execute the G32 S0 it always continues to print with wrong correction of the plane.
    Any help to delete completely stored mesh or to set manually one by one the probing points?
  • G32 does not store meshes. It creates a rotation matrix and uses it. Every new run deletes the old one. You can disable its usage so you just level bed physically which is the best solution anyway as it does not need to change Z for all xy moves. It is just not as comfortable but on the other side this is only needed once.
    What board type do you need for pibot? Isn't it a regular Mega2560 based board - that should work on all IDE versions. If it is a 1280/1284 based sanguino clone you might need to install the sanguino board.
  • Trying again without SD and it works...
    I'll solve this problem later... I hope.
    I did a G32 S0 to have a new matrix with more points and them M500 to save in Eprom
    This is the result:
    14:59:22.523 : N15 M322*20
    14:59:22.541 : Info:Autolevel matrix reset
    14:59:25.553 : N16 G28*36
    14:59:35.676 : N17 G32*46
    14:59:37.623 : X:0.00 Y:0.00 Z:0.000 E:0.0000
    14:59:42.644 : Z correction disabled
    14:59:42.644 : Info:Autoleveling disabled
    14:59:54.352 : Z-probe:13.957 X:20.00 Y:20.00
    15:00:06.460 : Z-probe:15.691 X:20.00 Y:286.00
    15:00:18.183 : Z-probe:15.215 X:20.00 Y:552.00
    15:00:31.058 : Z-probe:16.757 X:20.00 Y:818.00
    15:00:43.469 : Z-probe:16.107 X:20.00 Y:1084.00
    15:00:56.056 : Z-probe:16.356 X:20.00 Y:1350.00
    15:01:11.505 : Z-probe:15.695 X:166.00 Y:20.00
    15:01:21.741 : Z-probe:13.231 X:166.00 Y:286.00
    15:01:33.480 : Z-probe:15.221 X:166.00 Y:552.00
    15:01:44.851 : Z-probe:14.740 X:166.00 Y:818.00
    15:01:56.623 : Z-probe:15.257 X:166.00 Y:1084.00
    15:02:08.283 : Z-probe:15.117 X:166.00 Y:1350.00
    15:02:22.133 : Z-probe:13.271 X:312.00 Y:20.00
    15:02:31.665 : Z-probe:12.269 X:312.00 Y:286.00
    15:02:43.100 : Z-probe:14.817 X:312.00 Y:552.00
    15:02:54.776 : Z-probe:15.159 X:312.00 Y:818.00
    15:03:06.612 : Z-probe:15.334 X:312.00 Y:1084.00
    15:03:18.478 : Z-probe:15.417 X:312.00 Y:1350.00
    15:03:33.192 : Z-probe:14.418 X:458.00 Y:20.00
    15:03:44.676 : Z-probe:14.891 X:458.00 Y:286.00
    15:03:56.575 : Z-probe:15.434 X:458.00 Y:552.00
    15:04:08.891 : Z-probe:16.008 X:458.00 Y:818.00
    15:04:21.317 : Z-probe:16.137 X:458.00 Y:1084.00
    15:04:33.537 : Z-probe:15.857 X:458.00 Y:1350.00
    15:04:48.363 : Z-probe:14.580 X:604.00 Y:20.00
    15:05:00.086 : Z-probe:15.206 X:604.00 Y:286.00
    15:05:12.322 : Z-probe:15.879 X:604.00 Y:552.00
    15:05:25.083 : Z-probe:16.581 X:604.00 Y:818.00
    15:05:37.799 : Z-probe:16.535 X:604.00 Y:1084.00
    15:05:50.849 : Z-probe:16.974 X:604.00 Y:1350.00
    15:06:05.564 : Z-probe:14.418 X:750.00 Y:20.00
    15:06:17.208 : Z-probe:15.107 X:750.00 Y:286.00
    15:06:29.554 : Z-probe:16.026 X:750.00 Y:552.00
    15:06:42.016 : Z-probe:16.199 X:750.00 Y:818.00
    15:06:55.032 : Z-probe:16.938 X:750.00 Y:1084.00
    15:07:08.390 : Z-probe:17.343 X:750.00 Y:1350.00
    15:07:08.390 : plane: a = 0.0012 b = 0.0015 c = 13.8873
    15:07:08.390 : Transformation matrix: 0.999999 0.000000 -0.001164 -0.000002 0.999999 -0.001544 0.001164 0.001544 0.999998
    15:07:08.390 : Printer height:899.29
    15:07:08.390 : CurrentZ:13.89 atZ:14.60
    15:07:08.391 : Info:Autoleveling enabled
    15:07:08.391 : X:749.98 Y:1349.98 Z:16.845 E:0.0000
    Then I try to start printing but it seems that it applies a different compensation for the Z axis and when it moves to the center it starts to scratch to the plane.
    Is there a way to have a look at the matrix in the Eprom.
    It seems it applies different coordinates.
    This is my configuration h
       as you expect.
    #include "pins.h"
    #undef X_MAX_PIN
    #define X_MAX_PIN -1
    #define YAXIS_STEPS_PER_MM 32
    #define MAXTEMP 275
    #define ENDSTOP_PULLUP_Y_MAX false
    #define ENDSTOP_PULLUP_Z_MAX false
    #define DOOR_PIN -1
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    // Delta settings
    #define ZHOME_PRE_RAISE 1
    #define ZHOME_PRE_RAISE_DISTANCE 5
    #define MAX_JERK 20
    #undef PS_ON_PIN
    #define Z_PROBE_SWITCHING_DISTANCE 3
    #define Z_PROBE_REPETITIONS 2
    #define Z_PROBE_USE_MEDIAN 1
    #define Z_PROBE_HEIGHT 4.5
    #define Z_PROBE_X2 750
    #define Z_PROBE_Y3 1350
    #define BED_LEVELING_GRID_SIZE 6
    #define SDSUPPORT 0
    #undef SDCARDDETECT
    #define FEATURE_BEEPER 1
        "editMode": 2,
        "processor": 0,
        "baudrate": 115200,
        "xStepsPerMM": 80,
        "yStepsPerMM": 32,
        "xInvert": "0",
        "x2Invert": 0,
        "eepromMode": 1,
        "yInvert": "1",
        "y2Invert": 0,
        "zInvert": "0",
        "z2Invert": 0,
        "z3Invert": 0,
        "z4Invert": 0,
        "extruder": [
                "id": 0,
                "heatManager": 1,
                "pidDriveMin": 40,
                "pidDriveMax": 230,
                "pidMax": 255,
                "sensorType": 1,
                "maxFeedrate": 50,
                "invert": "0",
                "watchPeriod": 1,
                "pidP": 7,
                "pidI": 2,
                "pidD": 40,
                "advanceK": 0,
                "advanceL": 0,
                "waitRetract": 0,
                "stepsPerMM": 120,
                "coolerSpeed": 255,
                "xOffset": 0,
                "yOffset": 0,
                "zOffset": 0,
                "xOffsetSteps": 0,
                "yOffsetSteps": 0,
                "zOffsetSteps": 0,
                "stepper": {
                "jamPin": -1,
                "jamPullup": "0",
                "mirror": "0",
                "invert2": "0",
                "stepper2": {
                "preheat": 190
        "uiLanguage": 0,
        "uiController": 0,
        "xMinEndstop": 4,
        "yMinEndstop": 4,
        "zMinEndstop": 4,
        "xMaxEndstop": 0,
        "yMaxEndstop": 4,
        "zMaxEndstop": 4,
        "x2MinEndstop": 0,
        "y2MinEndstop": 0,
        "x2MaxEndstop": 0,
        "y2MaxEndstop": 0,
        "motherboard": 316,
        "driveSystem": 0,
        "xMaxSpeed": 300,
        "xHomingSpeed": 40,
        "yMaxSpeed": 300,
        "yHomingSpeed": 40,
        "zMaxSpeed": 2,
        "zHomingSpeed": 2,
        "xMotor": {
            "name": "X motor",
        "yMotor": {
            "name": "Y motor",
        "zMotor": {
            "name": "Z motor",
        "backlashX": 0,
        "backlashY": 0,
        "backlashZ": 0,
        "xMinPos": 0,
        "yMinPos": 0,
        "zMinPos": 0,
        "xLength": 1000,
        "yLength": 1500,
        "zLength": 900,
        "disableX": "0",
        "disableY": "0",
        "disableZ": "0",
        "disableE": "0",
        "xHomeDir": "-1",
        "yHomeDir": "-1",
        "zHomeDir": "-1",
        "xEndstopBack": 1,
        "yEndstopBack": 1,
        "zEndstopBack": 0,
        "deltaAlphaA": 210,
        "deltaAlphaB": 330,
        "deltaAlphaC": 90,
        "maxJerk": 20,
        "maxZJerk": 0.3,
        "moveCacheLow": 10,
        "sendWaits": "1",
        "killMethod": 0,
        "useAdvance": "0",
        "mirrorX": 0,
        "mirrorXMotor": {
        "mirrorY": 0,
        "mirrorYMotor": {
        "mirrorZ": "0",
        "mirrorZMotor": {
        "mirrorZ3": "0",
        "mirrorZ3Motor": {
        "mirrorZ4": "0",
        "mirrorZ4Motor": {
        "servo0Pin": 11,
        "servo1Pin": -1,
        "servo2Pin": -1,
        "servo3Pin": -1,
        "uiHeadline": "",
        "featureKeys": "0",
        "featureBeeper": "1",
        "bedSensorType": 1,
        "bedPreheat": 55,
        "bedPidP": 196,
        "bedPidI": 33,
        "bedPidD": 290,
        "bedPidMax": 255,
        "caseLightPin": -1,
        "gen1T0": 25,
        "gen1R0": 100000,
        "gen1Beta": 4036,
        "gen1MinTemp": -20,
        "gen1MaxTemp": 300,
        "gen1R1": 0,
        "gen1R2": 4700,
        "gen2T0": 25,
        "gen2R0": 100000,
        "gen2Beta": 4036,
        "gen2MinTemp": -20,
        "gen2MaxTemp": 300,
        "gen2R1": 0,
        "gen2R2": 4700,
        "gen3T0": 25,
        "gen3R0": 100000,
        "gen3Beta": 4036,
        "gen3MinTemp": -20,
        "gen3MaxTemp": 300,
        "gen3R1": 0,
        "gen3R2": 4700,
        "userTable0": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "userTable1": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "userTable2": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "minTemp": 190,
        "maxTemp": 275,
        "arcSupport": "1",
        "fanThermoPin": -1,
        "zProbePin": 68,
        "zProbeSpeed": 5,
        "zProbeX1": 20,
        "zProbeY1": 20,
        "zProbeX2": 600,
        "zProbeY2": 20,
        "zProbeX3": 20,
        "zProbeY3": 600,
        "sdSupport": "0",
        "xMaxPin": -1,
        "x2MinPin": -1,
        "y2MinPin": -1,
        "x2MaxPin": -1,
        "y2MaxPin": -1,
        "fanBoardPin": -1,
        "axisCompTanXY": 0,
        "axisCompTanXZ": 0,
        "axisCompTanYZ": 0,
        "sdRunOnStop": "",
        "jamSteps": 220,
        "jamMinSteps": 10,
        "jamAction": 1,
        "jamMethod": 1,
        "primaryPort": 0,
        "motorDrivers": [
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
        "manualConfig": "",
        "zProbeZOffset": 0,
        "zProbeDelay": 0,
        "langEN": "1",
        "langDE": "0",
        "langNL": "0",
        "langPT": "0",
        "langIT": "0",
        "langES": "0",
        "langFI": "0",
        "langSE": "0",
        "langFR": "0",
        "langCZ": "0",
        "langPL": "0",
        "langTR": "0",
        "laserPin": -1,
        "laserOnHigh": "1",
        "laserPwmMax": 255,
        "laserWatt": 2,
        "supportCNC": "0",
        "cncEnablePin": -1,
        "cncPwmMax": 255,
        "cncRpmMax": 8000,
        "cncSafeZ": 150,
        "startupGCode": "",
        "jsonOutput": "0",
        "bedMotor1X": 0,
        "bedMotor1Y": 0,
        "bedMotor2X": 200,
        "bedMotor2Y": 0,
        "bedMotor3X": 100,
        "bedMotor3Y": 200,
        "adcKeypadPin": -1,
        "dualXAxis": "0",
        "z2MinMaxPin": -1,
        "doorPin": -1,
        "doorEndstop": 0,
        "zhomePreRaise": 1,
        "zhomePreRaiseDistance": 5,
        "maxFanPWM": 255,
        "hasTMC2130": "0",
        "TMC2130CSX": -1,
        "TMC2130CSY": -1,
        "TMC2130CSZ": -1,
        "TMC2130CSE0": -1,
        "TMC2130CSE1": -1,
        "TMC2130CSE2": -1,
        "microstepX": 16,
        "microstepY": 16,
        "microstepZ": 16,
        "microstepE0": 16,
        "microstepE1": 16,
        "microstepE2": 16,
        "parkPosX": 0,
        "parkPosY": 0,
        "parkPosZ": 10,
        "uiAnimation": "0",
        "hasUser0": false,
        "hasUser1": false,
        "hasUser2": false,
        "numExtruder": 1,
        "version": 100.2,
  • As I already said, there is no matrix in eeprom/memory. We only store the rotation here.
    I see the difference is 3.386 mm between highest and lowest position, that is quite bad leveled.
    A even bigger problem is when you look into your measurements:
    Start here for x constant and see how y changes. It should be eithe rincreasing or decreasing but you get
    15:00:06.460 : Z-probe:15.691 X:20.00 Y:286.00  down
    15:00:18.183 : Z-probe:15.215 X:20.00 Y:552.00 up
    15:00:31.058 : Z-probe:16.757 X:20.00 Y:818.00 down
    15:00:43.469 : Z-probe:16.107 X:20.00 Y:1084.00 up
    15:00:56.056 : Z-probe:16.356 X:20.00 Y:1350.00 down
    This does not look like a flat bed. At X166 it continues
    15:01:21.741 : Z-probe:13.231 X:166.00 Y:286.00 up
    15:01:33.480 : Z-probe:15.221 X:166.00 Y:552.00 down
    15:01:44.851 : Z-probe:14.740 X:166.00 Y:818.00 up
    15:01:56.623 : Z-probe:15.257 X:166.00 Y:1084.00 down
    15:02:08.283 : Z-probe:15.117 X:166.00 Y:1350.00 up
    With such deviations you can not expect good results.
    Not the question is what is causing that. Is the bed really that bumpy, is the z probe unreliable or does it get disturbed? E.g. inductive probe gets disturbed when bed is heating. So in that case bed must be disabled to get proper measurements.
    What you can expect is that the plane swings between +/- 0.4mm too close and too far away. I doubt that even with G33 you will be able to compensate that. Also this is just a guess from some values it shows clearly your problem. Guess it comes from the big bed size. Here you can get many effects and it is hard to find a plane bed that big. You might also get bending effects from the weight of bed and also the x/y axis depending on your system. Have at least seen systems where extruder was mid x lower from own weight.
